  • 1 Post By JBR
 Old 05-09-2014, 06:01 PM   #1
Destined2race's Avatar
Posts: 34   (View Stats)
Destined2race has a spectacular aura aboutDestined2race has a spectacular aura about
Groaned at 6 Times in 4 Posts
Default JBR Boost tubes
Just wanted to leave feedback, order was processed and delivered fast. Products fit good and look good. The BPV tube I ordered was too long, not sure if I got the wrong one or if it says somewhere it might need to be shortened. Other than that great overall experience with my first buy from these guys.
2006 MS6 GT Red Mica - Cobb APv3, BNR S1, FreekTune, JBR 3 port BCS, Turbosmart BPV, Bosch 3bar map, CX Racing FMIC, JBR TIP, JBR EGR Delete and Block off Kits, Autotech HPFP, Circuit Werks 3" DP, Flowmaster cat back (previous owner), Modified AEM Cold Air (short ram cut) , CPE Injector seals/studs, Sickspeed OCC, NGK One Step Colders, Powder Coated Valve Cover Gloss Black, Ebay Tubular Manifold, CS Oil Cap, JBR Recirc Tube, Tinted Windows, H&R Springs, LED Tails, Metra Double Din Dash kit, Pioneer DD Touchscreen, JL c2 Comps, Jl Audio C2 6.5" Coax's, Jl 500/1, JL 300/4, 3 ID 10" subs custom installed, SVR800 Batt, JL Audio 2ga Kit, JL Audio Blue Rca's x3.
Destined2race is offline   Reply With Quote
 Old 05-09-2014, 07:24 PM   #2
macdiesel's Avatar
Posts: 825   (View Stats)
But what color did you order?
 Old 05-09-2014, 07:27 PM   #3
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
The recirc tube is meant to be trimmed to fit.
Too much hose is better than not enough.
The Following 8 Users Say Thank You to Agent_Orange For This Useful Post:
jack_hammer (05-24-2014), jm211 (05-10-2014), Mauro_Penguin (05-26-2014), Playaj (05-10-2014), Raider (05-09-2014), Rokusek (05-12-2014), Vansquish (05-09-2014), XxSmarTz (05-24-2014)
 Old 05-09-2014, 07:45 PM   #4
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
I thought about buying a set as well, do you know if they will fit on my regular 3?
The Following 2 Users Say Thank You to dooderek For This Useful Post:
jm211 (05-10-2014), smoogs12 (05-24-2014)
 Old 05-09-2014, 08:00 PM   #5
You need 2 sets for non-turbo.
CosmicArkie (05-10-2014), JgamB (05-16-2014), Mauro_Penguin (05-26-2014), MazdaBoy2.3 (05-09-2014), Playaj (05-10-2014), smoogs12 (05-24-2014)
 Old 05-09-2014, 08:49 PM   #6
You trollin me brah lol
The Following User Says Thank You to Destined2race For This Useful Post:
macdiesel (05-11-2014)
 Old 05-09-2014, 09:01 PM   #7
No doubt, but if your ordering a custom product that's suppose to be model specific... you definitely shouldn't have to worry about it being too short. But again I wasn't complaining, I figured it did, and wasn't a big deal just giving honest feedback
The Following User Says NO Thank You to Destined2race For This Un-useful Post:
Agent_Orange (05-09-2014)
 Old 05-09-2014, 10:09 PM   #8
The recirc hose is long on purpose. With all the various intercooler piping kits and bypass valves the added length can come in handy. A sharp razor knife makes quick clean work of shortening it.
Rokusek likes this.
The Following 11 Users Say Thank You to JBR For This Useful Post:
aaron88 (05-10-2014), Agent_Orange (05-09-2014), bstover17 (05-09-2014), Hargarbl (05-10-2014), Mauro_Penguin (05-26-2014), memin (05-24-2014), neotide87 (05-09-2014), Rokusek (05-12-2014), speed23 (05-09-2014), WAMBUSHHHH! (05-11-2014), XxSmarTz (05-24-2014)
 Old 05-09-2014, 10:49 PM   #9
neotide87's Avatar
Posts: 1,388   (View Stats)
neotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the world
I will be ordering JBR's recirc tube soon since I just noticed a crack on mine and the stealership wants 35$ for theirs. Good idea on making it longer on purpose.
2007 Mazdaspeed 3 Sport SSM
Corksport SRI / HPFP Internals / Front Arm Bar // Cp-e RMM 75d // JBR RSB / IM & TB Gaskets / Bypass Valve Hose // Cobb AP / Shifter Weight // SU Shifter Bushings // Sure TIP // Viper 5901
neotide87 is offline   Reply With Quote
 Old 05-10-2014, 05:15 AM   #10
For $35 you get a recirc hose in the color of your choice, protective clamps and free shipping.
Agent_Orange (05-10-2014), daytonabluez05 (05-13-2014), Mauro_Penguin (05-26-2014), neotide87 (05-14-2014), Rokusek (05-12-2014)
 Old 05-23-2014, 10:40 PM   #11
bryancregger's Avatar
Posts: 205   (View Stats)
bryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant future
I thought it was 1 per cylinder? And of course 4 BOV in conjunction in order to induce hyperdrive.
______________________
___________________________________
\\ 2010 MS3 \\ BNRS3 \\ Cobb SF Intake \\ CP-E TMIC \\ Corksport TIP \\ Cobb AP v2 \\ Autotech HPFP \\ ACT Clutch \\ JBR PMM and RMM \\ Corksport TMM Insert \\ JBR SSP \\ Corksport Catch Can \\ FREEKTUNED \\ Cobb 3 Port EBCS \\ Stoptech Slotted Rotors \\ JBR EGR Delete \\ 3 Bar MAP \\
bryancregger is offline   Reply With Quote
 Old 05-24-2014, 07:52 AM   #12
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
Op: you didn't order boost tubes. You fail
Sent from my LG-MS770 using Tapatalk
it's fun to do bad things
neotide87 (05-24-2014)
 Old 05-24-2014, 02:02 PM   #13
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Mine was the exact same length as my stock one. A Lil longer would have been good tho too.
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
Page generated in 0.50758 seconds with 29 queries
