Like Tree8Likes
 Old 07-21-2012, 01:59 AM   #121
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
Absolutely! You definatley don't want a piece of that crud breakimg loose and finding its way in to the motor. I would get rid of the tube all together or clean it out and put the block off plate on.
OCC is also pretty important on the motors.
Thanks,
Jamie
Ordered
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline   Reply With Quote
 Old 07-21-2012, 08:09 AM   #122
Thanks!!
 Old 11-18-2012, 12:12 PM   #123
KevMS6's Avatar
Posts: 316   (View Stats)
I installed this but only fitted the plate and did not bother removing the tube and fitting plug... What / if any benefit is there from completely removing tube and fitting plug?
I've tried searching but can't find the answer...
Tuned with by
 Old 11-18-2012, 12:46 PM   #124
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
If the other end of the tube is open, your egr valve will be exhausting into your engine bay.
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
 Old 11-18-2012, 01:00 PM   #125
KevMS6's Avatar
It's not open, it's untouched... All I have done is fit the plate between block and tube.
What's the benefit of removing tube and fitting plug?
Tuned with by
 Old 11-18-2012, 01:04 PM   #126
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
He installed the plate over the valve opening at the block, but left the pipe attached to the intake manifold without plugging the hole.
Basically, you're gonna have a massive vacuum leak.
@KevMS6; You need to install the plug on the intake manifold side. Due to its design, both parts are required for this.
The plate blocks off the egr valve port at the block. The plug blocks the port on the intake manifold.
this forum serves 2 purposes
The Following 2 Users Say Thank You to Dash08 For This Useful Post:
breakfstincluded (11-18-2012), wolly6973 (11-19-2012)
 Old 11-18-2012, 01:42 PM   #127
KevMS6's Avatar
I have no leaks but will look into doing the job right, cheers
Tuned with by
 Old 11-18-2012, 02:13 PM   #128
Sig_Nasty's Avatar
Posts: 272   (View Stats)
Sig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the world
Groaned at 4 Times in 1 Post
Ordered on sometime last week. Cant wait!
Sig_Nasty is offline   Reply With Quote
 Old 11-19-2012, 07:32 AM   #129
What you have done is perfectly fine. There is no need to completely remove the tube. Some remove the tube to clean up how it all looks.
Thanks,
Jamie
Dash08 (11-20-2012), KevMS6 (11-19-2012), wolly6973 (11-20-2012)
 Old 02-05-2013, 09:30 PM   #130
jdm_mica's Avatar
Posts: 525   (View Stats)
Installed this on Sunday but didn't use any sealant. Would it really be worth it to go back and add some??
Cobb AP (Stratified Tuned)
Streetunit testpipe
Autotech internals
NGK LTR7Ix-11
Corksport RMM
Whiteline RSB+endlinks
HKS turbo timer
Prosport boost gauge+ventpod
 Old 02-06-2013, 05:58 AM   #131
Yes.
 Old 02-10-2013, 08:20 PM   #132
Jedtgill's Avatar
Posts: 25   (View Stats)
Jedtgill has a spectacular aura aboutJedtgill has a spectacular aura about
Groaned at 3 Times in 1 Post
as minimal as it is I am ordering this and your throttle body tig tomorrow I have a feeling I will be a return customer
JBR likes this.
Jedtgill is offline   Reply With Quote
The Following User Says Thank You to Jedtgill For This Useful Post:
JBR (02-12-2013)
 Old 02-12-2013, 11:38 AM   #133
crazyspeed6's Avatar
Posts: 74   (View Stats)
crazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud of
Just ordered this and the intake mani TIG, cant wait to get these installed and lower my BAT's. Thanks for the quality products!!
2006 Speed 6 - GTX3071, Cobb AP, CPE HPFP, CPE DP, HTP 3" Turbo Inlet, HTP 3" MAF Housing, CX FMIC, Greddy BOV, 3 Port EBC, JBR IM TIG, 3 Bar MAP, Corksport OCC, Stratified Tuned by Lex
STOCKING OUT
crazyspeed6 is offline   Reply With Quote
The Following User Says Thank You to crazyspeed6 For This Useful Post:
JBR (02-12-2013)
 Old 02-13-2013, 10:24 AM   #134
greatdane68's Avatar
Posts: 456   (View Stats)
I already ordered an OCC from you, and would like to get this too, but I don't want to have to deal with the code. I won't be fully bolted until next year though.
Oh well, looks like I'll be ditching the Hypertech and getting an AP next year too, along with this block off plate.
2010 Mazda Speed3
FREEKTUNED!
2003 Chevy S-10
2014 Toyota Camry
2011 Dodge Challenger R/T
1997 Geo Prizm
 Old 05-16-2013, 02:48 PM   #135
marianiman's Avatar
Posts: 478   (View Stats)
marianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the world
just ordered a egr blockoff.
marianiman is offline   Reply With Quote
 Old 12-31-2014, 11:08 AM   #136
bfak66's Avatar
Posts: 106   (View Stats)
bfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond repute
Got the blockoff plate on but didn't have a 22mm wrench to get the plug off. Will do that another time but it seems to be fine as is .
bfak66 is offline   Reply With Quote
 Old 01-11-2015, 11:30 AM   #137
liljae8's Avatar
Posts: 95   (View Stats)
liljae8 has a brilliant futureliljae8 has a brilliant futureliljae8 has a brilliant futureliljae8 has a brilliant futureliljae8 has a brilliant futureliljae8 has a brilliant futureliljae8 has a brilliant futureliljae8 has a brilliant futureliljae8 has a brilliant futureliljae8 has a brilliant futureliljae8 has a brilliant future
Doing this soon. I think it's a much needed mod fir these DI cars.
CS SRI/TIP, CS SSP, CS TMIC, Turbosmart Dualport, COBB AP V3, DDM HID kit 6000k, Autotech Internals, CPe Stage 2 RMM, JBR Cylinder Shift Knob, LED interior and license plate bulbs, yellow LaminX fogs, Blacked out Emblems, Blue Batmobile red-out tail lights, light smoked head lights, Gloss black vinyl roof, Bayson R spoiler lip extension, Rally Armor Mudflaps, CPe Towplate relocation license plate, Prosport Boost Gauge w/ Block8head defroster vent pod.
Yet to install: JBR OCC
liljae8 is offline   Reply With Quote
 Old 03-21-2015, 07:33 PM   #138
Minipax's Avatar
Posts: 18   (View Stats)
Minipax will become famous soon enough
Just bought one. I don't know why I didn't buy along with the goodies. Now I have to wait a week.
Minipax is offline   Reply With Quote
Stock Block BT build threads xcoldricex MazdaSpeed 3/6 - Big Turbo Builds 50 07-13-2010 08:37 AM
06' - 2011 MAZDA 5 Short Shift Plate Kits In Stock!! JBR JAMES BARONE RACING 4 06-18-2010 07:38 AM
06' - 2011 MAZDA 3 Short Shift Plate Kits In Stock!! JBR JAMES BARONE RACING 3 06-18-2010 07:38 AM
AEM Water/Meth Injection Kits In Stock Performance Racing Mazdaspeed3/6 General Discussion 3 04-10-2008 05:09 PM
Page generated in 0.38116 seconds with 33 queries
