Like Tree14Likes
  • 5 Post By JBR
  • 1 Post By fz6brian
  • 1 Post By JBR
  • 1 Post By Ksky90
  • 1 Post By Ksky90
  • 1 Post By Ksky90
  • 1 Post By JBR
  • 1 Post By HawkeyeGeoff
  • 1 Post By Franky-5-Fingaz
 Old 05-14-2015, 01:22 PM   #1
Arrow JBR has your MAC 35 Series 3-Port EBCS kits in stock!!
Details:
By request of the Mazdaspeed Community, JBR has put together an affordable *3-Port Electronic Boost Controller that utilizes the trusted MAC 35 series valve. No longer do you need to waste your time sourcing the valve, the fittings, the vacuum hose and the hardware separately to make up your own kit. We've done all the work for you and it's all right here in one complete kit at a very reasonable price.
The MAC 35 series is a direct solenoid operated 3-way poppet valve. It features a short stroke solenoid, a balanced poppet and powerful return spring. These features translate into high shifting forces, fast consistent response times, and long life. This valve provides extremely fast response and very high high flow all in a surprisingly small package.
We've made the installation as simple as possible too. It can easily be mounted in the OEM location and plugs directly in to the OEM wiring harness. With the 18" leads, it can be mounted most anywhere with the included mounting bracket, 36" of vacuum hose and mounting hardware.
Features:
- Designed and Manufactured in the USA
- Nickel plated vacuum fittings
- Complete kit ready to install
- OEM mounting location
Application:
2006 - 2013 Mazdaspeed 3/6 and CX-7
Includes:
-1 EBCS
-3 1/8" NPT 90 degree vacuum fittings
-1 1/8" NPT Plug
-5 Zip ties
-36" of vacuum hose
-2 Vacuum caps
-1 Vacuum T Connector
-Mounting bracket
-Mounting hardware
-Carries MAC manufacturers warranty
-Shipping is free in the US
*Proper tuning is required for 3-port mode
Zdraveca, Jtaylor, tegxsi and 2 others like this.
The Following 17 Users Say Thank You to JBR For This Useful Post:
Agent_Orange (05-22-2015), Amnesiac (05-22-2015), Hush (05-22-2015), impossible (05-27-2016), jack_hammer (05-22-2015), JgamB (05-22-2015), Justin@Freektune (05-22-2015), Mauro_Penguin (05-14-2015), MD1032 (05-29-2015), my2k13speed3 (05-14-2015), portetra000 (05-22-2015), Raider (09-29-2015), s1xstringmayhem (06-03-2015), tegxsi (05-22-2015), XxSmarTz (06-11-2015), Zdraveca (05-19-2015), [R]usty (05-22-2015)
 Old 05-22-2015, 05:30 AM   #2
knocturnal's Avatar
Posts: 266   (View Stats)
Must hazzzzz! Thank you for the affordable pricing. Some of us builders do have to put family first at times. This really helps
Mods:
Stratified Tuned Stage 2 OTS+
273whp/330wtq
SnailD Tuned on Meth
316whp/359wtq
412whp/373wtq
 Old 05-22-2015, 07:52 AM   #3
shamie's Avatar
Posts: 952   (View Stats)
Do you have any option for 1/4" fittings & hose?
The Following 2 Users Say Thank You to shamie For This Useful Post:
JBR (05-22-2015), udntknw (06-05-2015)
 Old 05-22-2015, 08:28 AM   #4
No there's not....We tested with the 1/4" fittings and line and found no improvement in response. The valve and 1/8" fittings flow plenty well enough.
 Old 05-22-2015, 10:56 AM   #5
shamie's Avatar
My only issue with the 1/8" is the fittings on the other end (TIP, WGA, and boost source) are usually 1/4".
 Old 05-22-2015, 11:00 AM   #6
portetra000's Avatar
Posts: 85   (View Stats)
portetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond repute
Details:
Features:
- Designed, Engineered and Manufactured in the USA
Application:
Includes:
-1 EBCS
-1 1/8" NPT Plug
-5 Zip ties
-36" of vacuum hose
-2 Vacuum caps
-Mounting bracket
-Mounting hardware
Take my money
2007 MS3/Black Mica/JBR 3.5 Aluminum Whale Penis/CP-E catted downpipe/JBR EBC/JBR EGR Blockoff/CX Racing BOV/Corksport cat back exhaust/Cobb lowering springs/AP Tuner/ Stage 2 -self tooned (E85 Stratafied Stage 2 tune for fun days)/JBR 88a RMM/shaved hatch/corksport mudflaps/Dip'd rims/aftermarket boom boom box
portetra000 is offline   Reply With Quote
 Old 05-22-2015, 11:07 AM   #7
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
@jbarone;
OEM mounting location?
Can you share pics of this or will you have an install guide in your support section?
2018 Audi RS3
2007 Acura TSX 6MT
JBR (05-22-2015)
 Old 05-22-2015, 01:10 PM   #8
Ksky90's Avatar
Posts: 1,026   (View Stats)
Ksky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the world
How does this compare to the other EBCS on the market? I.E CorkSport, Stratified, Grimmspeed, or Cobb? Just cheaper?
Had a Big Turbo '13 Speed3 WMI and 400 ponies.
Now I have a '13 WRX and zero ponies
Ksky90 is offline   Reply With Quote
 Old 05-22-2015, 06:00 PM   #9
Ahhh...I think I see where there's some confusion here. The threaded part of the fitting is 1/8" NPT. The actual vacuum nipple is 3/16", the same as the waste gate, bypass valve and the vent port on the turbo inlet pipe.
AwAfrican (07-16-2016), impossible (05-27-2016), Mauro_Penguin (05-22-2015)
 Old 05-22-2015, 08:07 PM   #10
fz6brian's Avatar
Posts: 99   (View Stats)
fz6brian has a reputation beyond reputefz6brian has a reputation beyond reputefz6brian has a reputation beyond reputefz6brian has a reputation beyond reputefz6brian has a reputation beyond reputefz6brian has a reputation beyond reputefz6brian has a reputation beyond reputefz6brian has a reputation beyond reputefz6brian has a reputation beyond reputefz6brian has a reputation beyond reputefz6brian has a reputation beyond repute
Dam your irresistible pricing!
Order placed.
JBR likes this.
09 CWP MS3
AP V3, AT HPFP, CPE DP SRI TIP & RMM, Forge V2 BPV, JBR SSP & DMM & PMM 3 port EBCS, Damond OCC, TR8 FMIC
Bilstein struts, Moog endlinks, Energy Suspension swabar bushings
fz6brian is offline   Reply With Quote
The Following User Says Thank You to fz6brian For This Useful Post:
JBR (05-22-2015)
 Old 05-22-2015, 08:52 PM   #11
speedfreak44's Avatar
Posts: 1,391   (View Stats)
I was eyeballing this piece a few days ago on the website. Price is perfect. Need to find a reason to purchase now
The line up:
 Old 05-22-2015, 08:54 PM   #12
@jbarone;
Mounts on the ear where the coolant line is bolted.
Mauro_Penguin likes this.
EwMPS (08-26-2017), Mauro_Penguin (05-22-2015), tegxsi (05-22-2015)
 Old 05-22-2015, 08:56 PM   #13
Because it's 10% off with webcode MEM2015 is a pretty good reason.
Chief_Wiggum (05-23-2015), Mauro_Penguin (05-22-2015), MD1032 (05-29-2015), portetra000 (05-27-2015), speedfreak44 (05-22-2015), udntknw (06-05-2015)
 Old 05-22-2015, 09:08 PM   #14
Wait I missed that part...is that on your website? All products?!
The line up:
 Old 05-22-2015, 09:10 PM   #15
JBR's Memorial Day Sale Starts NOW!!
 Old 05-22-2015, 09:11 PM   #16
Fuck man you make me not want to eat this week
The line up:
 Old 05-29-2015, 08:51 PM   #17
fz6brian's Avatar
Got it, installed it, tuned for it and wrote revision tune to play with tomorrow. I took off the TIP to get a little more room to work. Mounting it on the coolant line bracket is nice and neat but makes getting on the hose clamp on the TIP a bit more difficult.
JBR likes this.
09 CWP MS3
JBR (05-29-2015)
 Old 06-02-2015, 12:19 PM   #18
Ksky90's Avatar
I installed mine on the tip stud. Looks stock and blends in well.
JBR likes this.
The Following User Says Thank You to Ksky90 For This Useful Post:
JBR (06-02-2015)
 Old 06-03-2015, 04:30 PM   #19
Ksky90's Avatar
Mind the mess, I am painting my valve cover. Looks good and blends in well. I approve. Thanks Jamie!
JBR likes this.
The Following 2 Users Say Thank You to Ksky90 For This Useful Post:
impossible (05-27-2016), JBR (06-03-2015)
 Old 06-03-2015, 09:24 PM   #20
Looks great!! You've got several other nice parts there too. Post some finished pics. Better yet, email me some nice ones and I'll post them up on our Facebook page.
impossible (05-27-2016), Ksky90 (06-04-2015)
 Old 06-03-2015, 09:26 PM   #21
Ksky90's Avatar
You got it chief!
Funnily enough I used to have mostly CorkSport stuff. Now its yours and I much prefer your products. Always the best stuff!
JBR likes this.
JBR (06-03-2015)
 Old 06-03-2015, 09:33 PM   #22
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
I believe the newish corksport EBCS, is based on the newer bullet-style EBCS from MAC.
I know Perrin also has used that bullet style mac valve for their EBCS for quite some time now.
So my question is, I kind of thought that bullet valve would become the basis for any new EBCS that might come out.
Since the JBR is the traditional block shaped MAC valve like Cobb/Grimm/Stratified, does that mean you found that the newer bullet style mac valve isn't much better?
 Old 06-04-2015, 05:50 PM   #23
We tested the bullet valve and we were unable able to capture any measurable data to support that it performed any better than the 35xx series. We took that data when we met with MAC and asked the very same question. The response was "This is a rather crude application to need or use a valve as advanced as the bullet valve". With that, we elected to not pursue the use of it.
Ksky90 likes this.
The Following 10 Users Say Thank You to JBR For This Useful Post:
Addikted To Boost (06-04-2015), breakfstincluded (06-04-2015), impossible (05-27-2016), ItsNox (06-04-2015), JgamB (06-06-2015), Johnny_Law (07-09-2016), Mauro_Penguin (06-04-2015), MD1032 (06-05-2015), Raider (06-05-2015), XxSmarTz (06-11-2015)
 Old 06-04-2015, 06:01 PM   #24
Thanks for the explanation, I wonder would mac would consider an exemplary application for that valve then lol
 Old 06-04-2015, 06:17 PM   #25
Hi-speed automation is one commonly used area for it.
breakfstincluded (06-04-2015), ItsNox (06-04-2015)
 Old 06-05-2015, 04:49 AM   #26
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
That's nice that you at least looked into the bullet valve to determine whether it was worthwhile at any rate.
What a nice little kit with a great price. This will save a lot of people some time and money.
2007 Mazdaspeed3 GT
impossible (05-27-2016), JBR (06-06-2015)
 Old 06-05-2015, 09:02 AM   #27
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Damn. Haha I was making these for a while....good price man!
JBR likes this.
Silver 2007 Speed3 GT
JBR (06-06-2015)
 Old 06-06-2015, 12:42 PM   #28
Sinister_Speed3's Avatar
Posts: 180   (View Stats)
How well will this work with stock 2 port setting? Does it require and special changes to the tune? I just broke my ecbs, wanted to see if this is a better option than cheap/expensive mazda replacements. @jbarone;
Thanks in advance, I am going to try and get this ordered today if it is a better alternative
Sinister_Speed3 is offline   Reply With Quote
 Old 06-06-2015, 12:42 PM   #29
Ksky90's Avatar
If you use it in bleed/2port mode it functions the same as the stock solenoid.
JBR (06-06-2015)
 Old 06-06-2015, 06:43 PM   #30
Just ordered it after a frustrating day of install. I am going to assume based off other 3-port/2 port installs that the left goes to the TIP and the right goes to the wastegate (based on the picture in the first post)
-nick
The Following User Says Thank You to Sinister_Speed3 For This Useful Post:
JBR (06-06-2015)
 Old 06-11-2015, 04:55 PM   #31
When I look at the stratified 2 port bleed mode it shows a "restrictor" from the boost source. Do I need to run one? Does the t set up need to be the same as well? I did not see a 2 port set up in the instructions @jbarone;
Thanks
 Old 06-13-2015, 07:49 AM   #32
fz6brian's Avatar
Thanks
The k04 has a restrictor pill in the nipple on the turbo compressor housing. 2 port needs the restrictor. Search for grimmspeed instructions, they show how to hook it up in 2 port. You can hook it up to the stock hoses. The second port on the WGA acts like a T in the stock system. I just don't remember what port goes where. Or you can cap off one of the ports on the WGA and put a T in the line from the boost source (w/restrictor pill) to the WGA.
Hope that makes sense to you.
09 CWP MS3
 Old 07-09-2016, 01:44 PM   #33
Franky-5-Fingaz's Avatar
Posts: 25   (View Stats)
Franky-5-Fingaz is a jewel in the roughFranky-5-Fingaz is a jewel in the roughFranky-5-Fingaz is a jewel in the roughFranky-5-Fingaz is a jewel in the rough
Just installed mine earlier today (3-port); made the necessary changes to WGDC in my tune, and set off to begin the adventure. Already i can see the boost reacting more responsively. Starting at 15 WGDC is no fun it looks like the highest boost i could get on the initial run was 11 PSI (normal for the first run with the extremely lower WGDC, right?). I'll start moving it up and see how it goes.
One thing I would recommend; include more Zip-Ties!! (You can never have enough zip-ties).
Great solenoid from what i'm seeing so far Mr. James Barone, keep up the good work.
JBR likes this.
Franky-5-Fingaz is offline   Reply With Quote
The Following User Says Thank You to Franky-5-Fingaz For This Useful Post:
JBR (07-09-2016)
 Old 01-10-2017, 08:12 AM   #34
Just completed building 100 more EBCS kits!
Varomnia (01-10-2017)
 Old 02-23-2018, 03:05 PM   #35
hichamaziz's Avatar
Posts: 9   (View Stats)
hichamaziz can only hope to improve
thank you for post it interesting for me
hichamaziz is offline   Reply With Quote
The Following User Says NO Thank You to hichamaziz For This Un-useful Post:
JSmith (02-23-2018)
 Old 03-30-2018, 07:14 AM   #36
Shenika's Avatar
Posts: 2   (View Stats)
Shenika is an unknown quantity at this point
Heeeeey and thank you for the affordable pricing.Some of us builders do have to put family first at times this
 really helps
Shenika is offline   Reply With Quote
Page generated in 0.57361 seconds with 35 queries
