Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
(Thread Starter) | Not Ranked : 0 score Details: Designed with a wide range of adjustabilty, the JBR coilover suspension kit lets you ride to work and carve up the town in maximum style and comfort. Then, when the weekend comes and you're preparing to grid, fine-tune all four corners and transform your Mazda from a mean street machine into a corner hugging track beast. With 32 points of compression and rebound adjustment as well as being fully height adjustable, these coilovers are the only choice when it comes to use on the street and the track. The JBR front coilovers include camber plates machined from 6061 aluminum and anodized for a sleek look and corrosion protection. They're then fitted with nickel plated steel adjustment plates with pillow ball mounts for smooth, quite operation that will last a lifetime. The front dampers are of a mono-tube construction with 32 points of compression and rebound adjustment. They carry a 24 month warranty and are fully re-buildable. The entire front assembly is height adjustable from -.5" to -2.95". In the rear you'll find another mono-tube damper also with 32 points of compression and rebound adjustment. Included with the rear dampers are upper mounts machined from 6061 aluminum, secured to the damper with soft yet very durable rubber bushings. They also carry a 24 month warranty and are fully rebuildable. The lower mount for the rear dampers are again machined from 6061 aluminum with nickel plated steel sleeves and rubber bushings. The rear height adjustment is achieved with adjustable spring perches that bolt in to the lower control arm providing a range of adjustment from -.5" to -2.95". The front and rear springs are made from high quality metal alloy spring steel which undergoes a cold winging process followed by induction hardening and tempering to maintain spring rates, maximize fatigue life and minimize deformation. The front springs are 7.5K and the rear springs are 4.5K *Applications Available:
*Product images and options may vary slightly by model. Features:
Includes:
| The Following 8 Users Say Thank You to JBR For This Useful Post: | akurma (06-17-2016), Code Monkey (06-17-2016), hartlch (01-08-2017), mazdaspeedmyk (06-17-2016), monkey.bones.007 (06-17-2016), Puddin15 (06-18-2016), Shwaykid (06-21-2016), Thepedigree13 (06-22-2016) |
(Thread Starter) | Not Ranked : 0 score We're making more of these! |
![]() Join Date: Feb 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 139
| Not Ranked : 0 score Wow great price! How long are they on sale for? I really dislike the ride quality of my Koni STR.Ts and I'd love to buy me a set of these come tax season. Sent from my STV100-1 using Tapatalk |
| The Following User Says Thank You to thrisnospork For This Useful Post: | JBR (01-06-2017) |
Suspension packages will be coming soon too. | |
| The Following 2 Users Say Thank You to JBR For This Useful Post: | thrisnospork (01-06-2017), Varomnia (01-07-2017) |
![]() Join Date: Jan 2009 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() Thanks: 1
Sent from my SM-G935T using Tapatalk
__________________ //2008.5 SUNLIGHT SILVER MAZDASPEED 3 GT//COBB ACCESS PORT VERSION 3//AUTOTECH FUEL PUMP INTERNALS//C-PE DELTA FRONT MOUNT INTERCOOLER//GREDDY TI-C 80MM TURBO BACK EXHAUST//CP-E CATLESS DOWNPIPE//FLEX INNOVATIONS BIG 3 + GROUNDING KIT//HKS GROUNDING KIT//JAMES BARONE RACING OIL CATCH CAN//JAMES BARONE RACING TRU-TORSION.125 ADJUSTABLE REAR SWAY BAR//EIBACH PRO SPRINGS//RAYS ENGINEERING MAZDASPEED 3 WHEELS 18X7.5 52.5 OFFESET//NEXXEN 225 40 18//COBB SHORT RAM INTAKE//COBB TURBO INLET PIPE//COBB SHORT SHIFTER//COBB SHIFTER WEIGHT//STREET UNIT SHIFTER BUSHINGS//TWM GLOSS BLACK SHIFTER KNOB//AKEBONO FRONT + REAR BRAKE PADS//OSRAM XENARC NIGHTBREAKER D2S 5500K HEADLIGHT BULBS//OPTILUX HALOGEN FOG LIGHT BULBS//ROCKFORD FOSGATE 4G AMP KIT//KICKER SOLO BARIC L7 12"//CRUNCH 2000W AMP//AUDIOCONTROL LC2I LINE OUTPUT CONVERTER//TORQUE SOLUTION EXHAUST HANGERS//THESPEEDLINE LED SIDE MARKERS//THESPEEDLINE REAR + SIDE SMOKE LED REAR + SIDE REFLECTORS//THESPEEDLINE HEATED BLUE CONVEX SIDE MIRRORS//CUSTOM CARBON FIBER REAR WING LIP//BAYSON R CUSTOM CARBON FIBER EYE LIDS//WHITE LINE FRONT + REAR ADJUSTABLE ENDLINKS//RALLY ARMOR UR MUDFLAPS// | |
(Thread Starter) | Not Ranked : 0 score Yup!! |
![]() Join Date: May 2012 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 62
__________________ 12' black mica w/tech: BNR S4 V2; CM STG 2 WMI; DAMOND TB SPACER; GUARDIAN ANGEL V3; KOZMIC OCC; CP-E SAFE SEALS; DAMOND EGR DELETE; WHITEWIDOW INTAKE GASKET; Cobb AP V3 CP-E Xcel XL SRI; CP-E 4" TIP; CP-E Catted DP; CP-E Cat-back exhaust; CP-E TMIC; Cobb BPV; JBR EBCS; Cobb RMM; CorkSport HPFP internals; JBR turbo hoses; NGK (6510) LTR7IX-11 Iridium IX Spark Plugs; JBR short shifter; JBR Small battery tray; Optima 51r Battery Rice--CorkSport interior lights and carbon fiber hood scoop ETH/METH tune by Stratified in progress | |
| The Following User Says Thank You to flyhigh For This Useful Post: | ThOrZwAr (02-28-2017) |
| Not Ranked : 0 score Those are sexy. Suspension packages you say?? I'll be here waiting. My sig needs all things suspension.
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score Swift springs option?
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
(Thread Starter) | Not Ranked : 0 score What are you looking for? We can get most any spring rate from our manufacturer. |
| Not Ranked : 0 score I give up
| Mazda 3 suspension on Mazdaspeed 3 | Sp15shak | 2010 MS3 - Suspension & Brakes | 13 | 02-15-2016 03:28 PM |
| JBR MAZDASPEED 3/6 & CX7 BSD's and Oil Pan Baffle Kits In Stock!! | JBR | JAMES BARONE RACING | 5 | 08-22-2012 12:26 PM |
| 06' - 2011 MAZDA 5 Short Shift Plate Kits In Stock!! | JBR | JAMES BARONE RACING | 4 | 06-18-2010 07:38 AM |
| 06' - 2011 MAZDA 3 Short Shift Plate Kits In Stock!! | JBR | JAMES BARONE RACING | 3 | 06-18-2010 07:38 AM |
