  • 1 Post By JBR
 Old 04-12-2014, 05:56 PM   #1
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
Default JBR OEM replacement FSB bushings
Anyone have this issue when installing? The bushing itself is slightly bigger than OEM. It is 1.0" ID though. I am waiting for a call back. But in the mean time, I'd see if I just got the wrong one or somehow did something wrong.. Haha
My engine is out of the car so I figured it'd be a good time to tackle the FSB bushings.
tapatalkin
 Old 04-12-2014, 07:13 PM   #2
Were out if town so a call back won't be until Tuesday but what I do know is on some models the brackets need to be filed open a bit. They look very close in that picture so it should be pretty simple.
 Old 04-12-2014, 07:31 PM   #3
Edit.... You'll need to knock that collar over a bit. A few taps with a hammer and a flat head screw driver will do it. You'll be all set after.
mr.speedy3 likes this.
 Old 04-16-2014, 05:37 PM   #4
mr.speedy3's Avatar
So is that official? Or did I get a special case? Normally, fitting a hammer and flat head in this spot would be a huge pain in the ass.
 Old 04-16-2014, 05:44 PM   #5
Ferdball's Avatar
Posts: 1,340   (View Stats)
That bracket will last you a year, two tops. It's a shame they come with an upgraded RSB. It's also a shame that Corksport sells one, but for 8 million dollars.
My RSB is from Tri-Point. After the initial bracket broke, they charged me for an upgraded one. It's still good after about 4 years. Don't have a part number for you though.
 Old 04-16-2014, 05:50 PM   #6
mr.speedy3's Avatar
Thanks for the info. But this is for the front. I assume its the same story though lol
tapatalkin
 Old 04-16-2014, 06:00 PM   #7
Ferdball's Avatar
Some public service going on right here...
https://www.google.com/#q=site:mazda...en+rsb+bracket
 Old 04-17-2014, 07:05 AM   #8
On the oem front bar you will never need to replace that bracket. Let's get our facts straight here please.
 Old 04-17-2014, 07:34 AM   #9
Ferdball's Avatar
Huh? Not sure what you mean here.
 Old 04-17-2014, 07:46 AM   #10
You said the bracket will fail in a year...I'm saying it will not fail when used the OEM front bar.
Vader (04-17-2014)
 Old 04-17-2014, 07:11 PM   #11
Ferdball's Avatar
ah yes. I've heard no issues with front.
 Old 07-17-2014, 09:33 AM   #12
Ewind's Avatar
Posts: 235   (View Stats)
Ewind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond repute
Groaned at 6 Times in 4 Posts
Just replaced mine with JBR's front replacements as well and both bracket mount holes had to be widened in order for them to fit. It was well over 1/8"on each bracket on the opposite side of the collar.
Best bet for anyone doing this is to fit it and feel where the holes are and modify as needed. Every car will be different.
I couldn't get much into that space with the subframe on, so tapping the collar over wasn't going to work for me.
If you compare the jbr ones vs the oem you will notice they are substantially wider.
Did those and the upgraded rear sway mounts and like them very much.
Ewind is offline   Reply With Quote
GI: Corksport Shifter Linkage Bushings (Not Base Bushings) >>> Alpha Mazdaspeed3/6 General Discussion 134 03-09-2013 08:17 PM
SURE TORQ R6 bushings replacement ms6mil MazdaSpeed 6 - Engine, Transmission & Driveline 7 02-28-2013 07:39 PM
GI: Corksport Shifter Linkage Bushings (Not Base Bushings) >>> Alpha CorkSport 0 01-19-2012 11:33 AM
Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al Haltech Automotive News 0 03-27-2009 02:30 PM
TWM bushings bacarl MazdaSpeed 3 - Engine, Transmission & Driveline 15 08-12-2008 09:06 PM
Page generated in 0.52063 seconds with 24 queries
