 Old 03-07-2013, 12:26 PM   #1
Prediluted's Avatar
Posts: 45   (View Stats)
Prediluted has a reputation beyond reputePrediluted has a reputation beyond reputePrediluted has a reputation beyond reputePrediluted has a reputation beyond reputePrediluted has a reputation beyond reputePrediluted has a reputation beyond reputePrediluted has a reputation beyond reputePrediluted has a reputation beyond reputePrediluted has a reputation beyond reputePrediluted has a reputation beyond reputePrediluted has a reputation beyond repute
Default JBR Short Throw Plate Problems
I installed a JBR short throw plate, weight, and bushings a couple months ago. (Christmas gifts from the Fiance). At first install it was very tight, nice short throws.
However I noticed lately that it has loosened up again, not as long as stock but almost there.
I played around with the plate over the weekend, but it does not appear to have shifted or bent the plate/bolt and I could not get it to tighten back up.
I am wondering if I stretched a cable or if anyone else has ideas as to what could cause this to happen? I am pretty sure I could not stretch a steel cable...
Any ideas?
Prediluted is offline   Reply With Quote
 Old 03-08-2013, 06:44 PM   #2
jm211's Avatar
Posts: 943   (View Stats)
I noticed this when i installed my SURE stuff.
felt really tight then loosened up over a week or so...
When I mean loosened up, I mean the cage doesn't feel as tight anymore. It is still as short as before.
Maybe your just used to it and now it doesn't feel short.
Try removing and drive with it stock. I'm sure you will re-appreciate the plate! Or you can get another short throw for in the cockpit, like from CS.
Now that is a short shift!
 Old 03-08-2013, 07:00 PM   #3
stevehuff's Avatar
Posts: 419   (View Stats)
stevehuff is the leader of the worldstevehuff is the leader of the worldstevehuff is the leader of the worldstevehuff is the leader of the worldstevehuff is the leader of the worldstevehuff is the leader of the worldstevehuff is the leader of the worldstevehuff is the leader of the worldstevehuff is the leader of the worldstevehuff is the leader of the worldstevehuff is the leader of the world
This also happened on my TWM in my TC. Retighten and you should be fine.
stevehuff is offline   Reply With Quote
 Old 03-08-2013, 08:05 PM   #4
Kdawg207's Avatar
Posts: 2,389   (View Stats)
Or follow the how to on adjusting
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
 Old 03-09-2013, 06:51 AM   #5
Jhornbrook's Avatar
Posts: 708   (View Stats)
Jhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the world
Groaned at 6 Times in 4 Posts
Get the twm full replacement and I guarantee you'll feel like your shifting a miata. Mine is so short and nice. You do need to relighten and adjust things every so often though.
Sent from my iPhone using Tapatalk 2
Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC//
Jhornbrook is offline   Reply With Quote
 Old 03-09-2013, 07:04 AM   #6
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
You're probably just used to it now. The only thing I'd check is to make sure the riser/stud bolt is nice and tight and not loose on the plate. Otherwise, it's probably just you getting used to it.
Stealth01
2006 Mazdaspeed6 GT
The Following 3 Users Say Thank You to Stealth01 For This Useful Post:
chuckms6 (03-09-2013), Jhornbrook (03-09-2013), L3THAL6 (03-09-2013)
 Old 03-09-2013, 09:27 AM   #7
Retightening helps. Red loctite is needed for sure.
Short Shift Plate Problems SleeperHatch JAMES BARONE RACING 37 08-15-2011 01:22 PM
Ok, JBarone Short Throw Shift Plate (STSP) is TOTALLY WORTH IT! goathearder 2010 MS3 - Engine, Transmission & Driveline 16 06-24-2010 11:47 AM
Snazzy short throw shift plate darth vader MazdaSpeed 3 - Engine, Transmission & Driveline 26 09-25-2009 03:19 PM
Page generated in 0.43692 seconds with 26 queries
