  • 1 Post By
 Old 12-31-2013, 02:56 PM   #1
Originally Posted by Andrewbox View Post
Im interested to know what you had to modify also. Mine was a perfect fit.
I've seen both the HTP and JBR tray and they are practically the same thing. The only thing i like better about the HTP try is you mount the ECU horizontal vs. vertical. @jbarone; is there a way to change that or did I miss something on the install.
We chose to mount the ECU vertically because it requires NO modification to the wiring harness like it does when mounted horizontally. It's a lot easier to stock out and get warranty work done when you don't have to explain why the wiring harness was butchered.
-Jamie
Andrewbox (01-01-2014), JTMS3 (01-30-2014), Mauro_Penguin (01-01-2014)
MS6 Small Battery Tray HTP HTP (Hi-Tuned Performance) 21 01-16-2013 07:15 PM
Video: Friends videotape man "trapped" inside C6 Corvette with dead battery Haltech Automotive News 0 05-14-2011 08:10 AM
small battery kit question. Darksun280 MazdaSpeed 3 - Engine, Transmission & Driveline 6 01-11-2009 10:04 PM
Page generated in 0.24803 seconds with 21 queries
