  • 1 Post By JBR
 Old 12-30-2013, 08:16 PM   #1
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Default JBR Small Battery Box and the HTP 3.5"
Thanks @jbarone;
I never got a chance to review and thank Jamie for this solid piece. I can't believe that I was actually able to fit the 3.5" with the regular battery but I'm glad I got the 51R battery tray for the ms6.
If you have the HTP 3.5" intake with the JBR small battery box you gotta watch out for these things sticking out and fucking up your intake.... (circled in red on the JBR image)
Here is my setup you can see how close it is to the 3.5" intake... (after cuts have been made)
I know I should have double checked for clearance in there with the bigger intake pipe, but space was so tight I assumed it was all good.
This is the hole it made in my intake, luckily it didn't go all the way through. I ended up cutting off a piece of the hook end of the bracket rod and smoothed it out with a dremel. I also added inlet caps to the ends to prevent any further damage.
I am extremely satisfied with this, and hopefully this thread will provide as a reference for people or just something to look out for.
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
Mauro_Penguin (12-31-2013)
 Old 12-30-2013, 09:22 PM   #2
hatchedspeed3's Avatar
Posts: 1,966   (View Stats)
I didn't have any issues with my intake getting "poked", but the battery tie down had to be modified, even with a small battery. Otherwise, great product JBR.
2009 CWP MS3 1-23-2014
ms6mil (12-30-2013)
 Old 12-31-2013, 07:22 AM   #3
Ok, I'm confused....a couple of days ago you PM me complaining that you had to modify the battery tie down, I asked what you had to do and for pictures, neither of which I received, you're continuing to complain and in your signature it says you have an HTP battery box.
What's up with that?
 Old 12-31-2013, 09:19 AM   #4
first off, it was never a fucking complaint. Second, typo in my sig. Sorry for not getting you the pics right away, I've been taking care of my son because my wife has a concussion. Asshole.
The Following User Says NO Thank You to hatchedspeed3 For This Un-useful Post:
NeoKraSH (01-08-2014)
 Old 12-31-2013, 10:06 AM   #5
First of all sorry about your wife, that sucks.
But it was a complaint or you would not have PM'd me and how was I suppose to know you had a typo in your sig? I was not attacking you I was just confused. Simmer, I just want to help.
KCi likes this.
Mauro_Penguin (01-01-2014), NeoKraSH (01-08-2014)
 Old 12-31-2013, 10:15 AM   #6
I PMed you because I simply wanted to let you know I had a small issue, but was still happy with the product. I'm lookin for the pics now to send to you.
OP, sorry for the threadjack
 Old 12-31-2013, 08:44 AM   #7
Andrewbox's Avatar
Posts: 667   (View Stats)
Andrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the world
Im interested to know what you had to modify also. Mine was a perfect fit.
I've seen both the HTP and JBR tray and they are practically the same thing. The only thing i like better about the HTP try is you mount the ECU horizontal vs. vertical. @jbarone; is there a way to change that or did I miss something on the install.
Black Mica 2013 Mazdaspeed 3 w/ tech
GTX3076r EWG | CP-E ΔCore | CP-E Triton | CP-E LTRmani | CP-E DP
AUTOTECH HPFP | HTP 3.5" | GFB RESPONS
GRIMMSPEED EBC | CORKSPORT SSP | K-SPORT COILS
JBR CAMBER ARMS | JBR SWAY BAR | JBR MOUNTED
JBR TIGs | JBR ERG | JBR 51r TRAY
Andrewbox is offline   Reply With Quote
 Old 12-31-2013, 02:56 PM   #8
We chose to mount the ECU vertically because it requires NO modification to the wiring harness like it does when mounted horizontally. It's a lot easier to stock out and get warranty work done when you don't have to explain why the wiring harness was butchered.
-Jamie
Andrewbox (01-01-2014), JTMS3 (01-30-2014), Mauro_Penguin (01-01-2014)
 Old 12-30-2013, 09:34 PM   #9
Andrewbox's Avatar
This only affects the MS6
The Following 2 Users Say Thank You to Andrewbox For This Useful Post:
Domino81 (12-31-2013), ms6mil (12-30-2013)
 Old 12-30-2013, 09:39 PM   #10
ms6mil's Avatar
Groans: 307
I'm assuming you caught this beforehand? I should have seen it I was just too eager to get it in and moving.
PTE5862 - TBD
 Old 12-30-2013, 09:42 PM   #11
Andrewbox's Avatar
I've had mine in for months. the MS3 one has about 6" of clearance.
Maybe try flipping the hook the other way around?
Last edited by Andrewbox; 12-30-2013 at 09:42 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-31-2013, 01:41 AM   #12
had no such luck with that either.
MS6 Small Battery Tray HTP HTP (Hi-Tuned Performance) 21 01-16-2013 07:15 PM
Video: Friends videotape man "trapped" inside C6 Corvette with dead battery Haltech Automotive News 0 05-14-2011 08:10 AM
small battery kit question. Darksun280 MazdaSpeed 3 - Engine, Transmission & Driveline 6 01-11-2009 10:04 PM
Page generated in 0.34449 seconds with 23 queries
