 Old 01-08-2014, 08:21 PM   #1
revin-it02's Avatar
Posts: 58   (View Stats)
revin-it02 is just really nicerevin-it02 is just really nicerevin-it02 is just really nicerevin-it02 is just really nicerevin-it02 is just really nice
Default JBR stage 2 catch can question
I have an 08 speed3 and would love to run one of these catch can kits. I've had a can on every turbo vehicle I've owned and I really think it's a great piece of mind. However my 08 has had the "ventilation kit" installed for the smoking turbo warranty extension. Is the catch can now not necessary? I'm getting a bunch of conflicting info on what the ventilation kit does so I'm just trying to make sure.
Sorry for the noobish post!
revin-it02 is offline   Reply With Quote
 Old 01-08-2014, 08:28 PM   #2
derek13p's Avatar
Posts: 1,195   (View Stats)
derek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the world
Groans: 38
Depends on how you set it up.
A sealed can between the pcv and intake mani will have no effect on the turbo or CC pressure
06 MS6 & 06 MS6
The beauty is the beast
Daily driven
derek13p is offline   Reply With Quote
 Old 01-09-2014, 10:18 AM   #3
revin-it02's Avatar
Well, it'd be setup as the instructions say which I believe is placing it between those two. JBR, do you have any insight into this?
 Old 01-09-2014, 01:10 PM   #4
derek13p's Avatar
Groans: 38
If set up how I explained then you're good.
to tag people you put an @ then their screen name then ;
06 MS6 & 06 MS6
Daily driven
The Following 2 Users Say Thank You to derek13p For This Useful Post:
jm211 (01-09-2014), rfinkle2 (01-09-2014)
 Old 01-09-2014, 09:39 PM   #5
The configuration in our instructions will work perfect for your setup.
hope this helps.
Thx,
Jamie
Saikou Stage 2 Oil Catch Can Installed! aaronc7 MazdaSpeed 3 - How-To's 59 10-07-2009 03:59 PM
Page generated in 0.26130 seconds with 22 queries
