 Old 04-09-2014, 07:21 AM   #1
scapone4's Avatar
Posts: 179   (View Stats)
scapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud of
Default JBR Stage 2 Rubbing
After installing the the stage 2, I realized the TBolt clamps are rubbing against the ECU Wire cover and the battery box with the Tbolts in the position shown on the instructions. Did anyone else have this problem and just change the orientation of the clamps. Mine are positioned just as the picture shows. I'll post up how its rubbing in a few minutes as well. Anybody have the same issue?
scapone4 is offline   Reply With Quote
 Old 04-09-2014, 07:25 AM   #2
There is a bracket that goes under one of the clamps on the right, bolts to where stock TIP used to be, and that holds it far from the ECU. I do not see it used in this pic.
King Scumbag (04-09-2014), trancehead (04-09-2014)
 Old 04-09-2014, 07:32 AM   #3
scapone4's Avatar
Really? I don't know where said bracket is. Bracket comes with intake or is already on car? ImageUploadedByTapatalk1397050306.812313.jpg
I attached the picture of where it's rubbing.
 Old 04-09-2014, 07:33 AM   #4
scapone4's Avatar
O nvm. I know what you're talking about. The one that you slip under the clamp?
The Following User Says Thank You to scapone4 For This Useful Post:
Raider (04-09-2014)
 Old 04-09-2014, 07:42 AM   #5
yup
 Old 04-09-2014, 09:55 AM   #6
King Scumbag's Avatar
Posts: 2,384   (View Stats)
yup
@Raider; he definately has that bracket there if you look closely. I am trying to remember if I had the same problem. I may have just rotated the clamps down a little bit.
ninja edit. that is not your pic in the OP!
Ninja on Ninja edit: Yes check for the clamp @Raider; desribed. Slides under the clamp on the front of the TIP and bolts to the nippl/bolt used for the stock turbo inlet mounting bracket
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
Raider (04-09-2014)
 Old 04-09-2014, 01:22 PM   #7
scapone4's Avatar
Yea that's not my pic in the OP. Second one is. I was just using that showing how I oriented my clamps. I'll just reorient the clamps should be fine. Thanks guys
 Old 04-09-2014, 01:24 PM   #8
So, did you use the clip thing already, or no?
 Old 04-09-2014, 02:14 PM   #9
scapone4's Avatar
Yea thats on.
 Old 04-09-2014, 02:19 PM   #10
[R]usty's Avatar
Posts: 2,204   (View Stats)
Rotate the clamps, no biggie. Mine is close but not touching.
2010 Mazdaspeed3 w/tech
 Old 04-13-2014, 10:49 AM   #11
scapone4's Avatar
Simple fix. Thanks guys
Need help with rubbing jjfam1 MazdaSpeed 3/6 - Wheels & Tires 14 02-09-2012 11:02 AM
tire rubbing maddocx240 Mazdaspeed3/6 General Discussion 21 12-06-2011 11:48 AM
Why am I rubbing? Smily27 2010 MS3 - Wheels & Tires 17 07-13-2011 04:18 PM
Stock and Rubbing (Help Plz) KayWhy MazdaSpeed 3/6 - Wheels & Tires 7 08-30-2009 06:44 AM
225-45-18s, who else is rubbing? 4thStroke MazdaSpeed 3/6 - Wheels & Tires 14 07-07-2008 11:39 PM
Page generated in 0.30616 seconds with 24 queries
