Like Tree3Likes
  • 1 Post By rolanblack
  • 2 Post By jack_hammer
Closed Thread
 Old 05-14-2013, 08:11 AM   #1
LocoMazda's Avatar
Posts: 48   (View Stats)
LocoMazda is a splendid one to beholdLocoMazda is a splendid one to beholdLocoMazda is a splendid one to beholdLocoMazda is a splendid one to beholdLocoMazda is a splendid one to beholdLocoMazda is a splendid one to behold
Default JBR TIP rubbing after install
My TIP rubs on the master cylinder and the bracket that the wiring was hooked to. This is on a MS6.
There is no way to rotate the TIP to avoid the rubbing.
Is this a standard thing with this part?
LocoMazda is offline
 Old 05-14-2013, 08:17 AM   #2
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Mods: stock
faeker is offline
 Old 05-14-2013, 09:02 AM   #3
CU_Slik's Avatar
Posts: 130   (View Stats)
CU_Slik has a reputation beyond reputeCU_Slik has a reputation beyond reputeCU_Slik has a reputation beyond reputeCU_Slik has a reputation beyond reputeCU_Slik has a reputation beyond reputeCU_Slik has a reputation beyond reputeCU_Slik has a reputation beyond reputeCU_Slik has a reputation beyond reputeCU_Slik has a reputation beyond reputeCU_Slik has a reputation beyond reputeCU_Slik has a reputation beyond repute
I don't have a JBR, but mine does too.
06 LPM MS6 GT ~ COBB AP (OTS Stage 1) ~ SURE SRI ~ Corksport TIP ~ CPE TMIC ~ Autotech Fuel Pump Internals ~ SU Test Pipe ~ SURE RMM ~ SURE SSP ~ SURE Counterweight ~ NGK Plugs
07 Kawasaki Ninja 650R ~ Yoshimura Exhaust
**Sold** 04 Mazda 6s
CU_Slik is offline
 Old 05-14-2013, 12:04 PM   #4
You need to remove the wiring harness bracket off the transmission and you be fine. Some bend it out of the way. Either will work but I prefer to remove it.
-Jamie
JBR is offline
KusteLokal (05-14-2013), omgvance (05-15-2013)
 Old 05-15-2013, 01:21 PM   #5
LocoMazda's Avatar
-Jamie
I'll see what I can do w/that bracket, but that will not solve the issue w/the rubbing on the master cylinder.
 Old 05-15-2013, 05:57 PM   #6
I think if you make some adjustments to the TIP it will not rub. It does not rub in our shop car nor have we heard of any issues..
-Jamie
JBR is offline
 Old 05-17-2013, 12:13 PM   #7
LocoMazda's Avatar
-Jamie
I've talked to others that rub too.
I took care of the bracket, but still rubs on the master cylinder.
Originally Posted by rolanblack View Post
Sounds like it not all the way on. Make the tip is on the coupler right.
It is definitely all the way on.
Last edited by LocoMazda; 05-17-2013 at 12:13 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-15-2013, 07:24 PM   #8
rolanblack's Avatar
Posts: 2,110   (View Stats)
rolanblack is offline
 Old 05-17-2013, 05:43 PM   #9
rolanblack's Avatar
Could have your engine moved slightly?
Mfinlay04 likes this.
The Following User Says Thank You to rolanblack For This Useful Post:
Mfinlay04 (05-18-2013)
 Old 05-17-2013, 06:47 PM   #10
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
You're experiencing rubbing with jbr's tip? That sounds hot.
Mfinlay04 and JBR like this.
it's fun to do bad things
jack_hammer is offline
The Following 2 Users Say Thank You to jack_hammer For This Useful Post:
JBR (05-18-2013), Mfinlay04 (05-18-2013)
 Old 05-17-2013, 07:03 PM   #11
faeker's Avatar
Groans: 731
Still waiting for pics
sent with smiles and mouth hugs
Mods: stock
faeker is offline
 Old 05-18-2013, 01:20 AM   #12
Pseudonym's Avatar
Posts: 1,429   (View Stats)
this. seriously.
Cobb AP JBR SSP/SSB's
HTP 3 Incher Forge V2 BPV
eBay Test Pipe
SCUBA TUNED
Pseudonym is offline
Closed Thread
Rubbing issue forcedinduktion 2010 MS3 - Wheels & Tires 4 02-03-2013 06:08 PM
spacers + rubbing. TrueReddd MazdaSpeed 3/6 - Suspension & Brakes 15 06-21-2012 04:46 PM
Need help with rubbing jjfam1 MazdaSpeed 3/6 - Wheels & Tires 14 02-09-2012 11:02 AM
Why am I rubbing? Smily27 2010 MS3 - Wheels & Tires 17 07-13-2011 04:18 PM
225-45-18s, who else is rubbing? 4thStroke MazdaSpeed 3/6 - Wheels & Tires 14 07-07-2008 11:39 PM
Page generated in 0.34275 seconds with 26 queries
