Like Tree6Likes
  • 5 Post By JBR
  • 1 Post By King Scumbag
 Old 10-17-2013, 09:01 AM   #1
Default Morning Stiffy!
How Stiff is your.....Sway Bar?
Raider, kritz, 3starmagnum and 2 others like this.
The Following 29 Users Say Thank You to JBR For This Useful Post:
3starmagnum (10-17-2013), adamizme (10-17-2013), Agent_Orange (10-17-2013), alextheguineapig (10-17-2013), allo80 (10-18-2013), Code Monkey (10-17-2013), cshunter (10-21-2013), Cujo (10-22-2013), CWP_MS3 (10-17-2013), DoMiNic (10-17-2013), galens47 (10-17-2013), Hush (10-17-2013), Jabl3s (10-24-2013), King Scumbag (10-17-2013), kolosok17 (10-22-2013), magicka (10-21-2013), Mauro_Penguin (10-17-2013), mzr0818 (10-17-2013), R4LLY3 (10-22-2013), Raider (10-22-2013), simply_pandora (10-22-2013), snailD (10-21-2013), SpeedRebirth (10-17-2013), stevehuff (10-21-2013), taf0422 (10-17-2013), trancehead (10-17-2013), WetzMS3 (11-22-2013), YABBAMZR (10-17-2013), [R]usty (10-17-2013)
 Old 10-17-2013, 09:03 AM   #2
3starmagnum's Avatar
Posts: 348   (View Stats)
3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world
Yup, need me one of those buddy.. Soon!!!
2011 Mazdaspeed3
Power Mods: JBR 3" intake//CP-e top mount IC//AT internals//CS testpipe//NGK step colder plugs
Other mods: JBR 88 rmm//Swift springs//RA mud flaps//JBR ssp
STRATIFIED TUNED by Lex
3starmagnum is offline   Reply With Quote
 Old 10-17-2013, 09:04 AM   #3
trancehead's Avatar
Posts: 1,841   (View Stats)
Just greased her up. Stiff as day one
2012 CWP MS3
2014 SWP WRX
2014 SWP Mazda 3
The Following User Says Thank You to trancehead For This Useful Post:
 Old 10-17-2013, 10:19 AM   #4
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Full stiff.
Blue Pu.
 Old 10-17-2013, 10:30 AM   #5
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Now that I've seen these I'm full stiff
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 10-17-2013, 11:40 AM   #6
alextheguineapig's Avatar
Posts: 827   (View Stats)
What are possible causes for slight clunking noises on the bars Jaime? I know common causes are the lack of grease on the bar and end links, but I just had the bar and end links installed and they were greased when installed. What else might it be?
Other than the clunking, the bar is amazing! My car handles really flat and I love it. Great product, would buy again!
Edit: My bar is on the stiffest setting.
Current
SOLD!
2008 Sunlight Silver MS3:
BNR: S3 V2
Cobb: V3 AccessPort
Damond Motorsports: RMM
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 10-17-2013, 11:43 AM   #7
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Are you sure its the swaybar?
Did you try disconnecting an endlink and driving around carefully to see if the clunking is still present?
Pickles Tune in progress
 Old 10-17-2013, 11:56 AM   #8
I just got the car back yesterday, I broke a bolt and I had to have it extracted. I'll try tightening them down or driving without them attached later this weekend.
Current
SOLD!
BNR: S3 V2
Cobb: V3 AccessPort
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 10-17-2013, 11:49 AM   #9
lilred's Avatar
Posts: 5,792   (View Stats)
Clunking on mine was due to not enough man strengh to tighten the endlink lol once someone got in there and tightened up it was all good
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
himurax13 (10-17-2013), LumberJack (10-20-2013), Mauro_Penguin (10-17-2013)
 Old 10-17-2013, 12:00 PM   #10
himurax13's Avatar
Groans: 255
tapafuck
That wasn't me now was it?
 Old 10-17-2013, 11:52 AM   #11
[R]usty's Avatar
Posts: 2,204   (View Stats)
Should be no clunking, bar fitment is damn near perfect.
2010 Mazdaspeed3 w/tech
 Old 10-17-2013, 11:58 AM   #12
Make sure the bar is properly centered and not contacting the sub-frame and that the links are tight. There may be another cause unrelated to the bar as mentioned, usually is.
-Jamie
Had the pieces installed by a mechanic
There's the problem.
Last edited by JBR; 10-17-2013 at 11:58 AM. Reason: MSF Database - Automerged Doublepost
alextheguineapig (10-17-2013), Mauro_Penguin (10-17-2013), snailD (10-21-2013), trancehead (10-17-2013)
 Old 10-17-2013, 12:10 PM   #13
-Jamie
Yeah I'll have to get under there later and give it a look. Thanks Jaime!
Current
SOLD!
BNR: S3 V2
Cobb: V3 AccessPort
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
The Following User Says Thank You to alextheguineapig For This Useful Post:
 Old 10-20-2013, 11:17 PM   #14
LumberJack's Avatar
Such a sexy bar, full stiffy commencing!
10.36@148 Fastest Gen 2
 Old 10-21-2013, 11:22 PM   #15
mertz's Avatar
Posts: 71   (View Stats)
mertz has much to be proud ofmertz has much to be proud ofmertz has much to be proud ofmertz has much to be proud ofmertz has much to be proud ofmertz has much to be proud ofmertz has much to be proud ofmertz has much to be proud ofmertz has much to be proud of
Mine is in transit from Edge expected delivery Thursday. Have had the JBR motor mounts on for a couple weeks now, really looking forward to the RSB.
mertz is offline   Reply With Quote
 Old 10-22-2013, 09:49 AM   #16
King Scumbag's Avatar
Posts: 2,384   (View Stats)
Good stuff man, you won't be disappointed! Got any questions let us know. But with @jbarone;s detailed instructions you shouldn't need to ask any
JBR likes this.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
JBR (10-22-2013)
 Old 10-22-2013, 06:43 AM   #17
tikous360's Avatar
Posts: 182   (View Stats)
tikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the world
Medium Stiffy and I love it
tikous360 is offline   Reply With Quote
 Old 10-22-2013, 09:41 AM   #18
simply_pandora's Avatar
Posts: 2,605   (View Stats)
simply_pandora is the leader of the worldsimply_pandora is the leader of the worldsimply_pandora is the leader of the worldsimply_pandora is the leader of the worldsimply_pandora is the leader of the worldsimply_pandora is the leader of the worldsimply_pandora is the leader of the worldsimply_pandora is the leader of the worldsimply_pandora is the leader of the worldsimply_pandora is the leader of the worldsimply_pandora is the leader of the world
Groaned at 56 Times in 11 Posts
Want/need but can't has yet :'(
Sent while watching the weather change... again..
2007 Mazda Mazdaspeed 3 -- Black Mica
¤Rear Cat Delete¤HTP 3" full Intake¤Grimmspeed EBCS¤KMD Internals¤Cobb Accessport (tune in progress)¤
JBR 88 Duro RMM¤Sure Torq S3 Passenger Mount¤SU Billet TMM¤
¤JBR Solid Shifter Bushings¤CPE Tow Plate¤JBR Rear Sway Bar¤
Status: Comatose
simply_pandora is offline   Reply With Quote
 Old 11-22-2013, 03:49 PM   #19
SrananBuru's Avatar
Posts: 85   (View Stats)
SrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond repute
Any chance on a blue finish?
SrananBuru is offline   Reply With Quote
 Old 11-22-2013, 03:50 PM   #20
PM for details.
 Old 11-22-2013, 03:52 PM   #21
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
I absolutly LOVE mine! FULL STIFFY!!!
Though, i have to say, i'm jelly of the giant JBR logo those ones.
99 miata: sold
 Old 11-22-2013, 04:26 PM   #22
T2J
T2J's Avatar
T2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the world
Groaned at 3 Times in 1 Post
I'm only half chub at the moment, but I'll be on the fullest stiffness now
09 CWP MS3
GT3071R
TUNED BY NISHAN
T2J is offline   Reply With Quote
 Old 11-22-2013, 05:18 PM   #23
Matrix311's Avatar
Posts: 2,133   (View Stats)
Well now that I just fully built my engine and went forged. I might have to start working on the suspension. All I have currently is koni struts with h&r springs. No changes to sway bars, end links, bushings or camber arms in back. This could get fun.
 Old 11-22-2013, 08:09 PM   #24
JgamB's Avatar
Posts: 2,566   (View Stats)
I'm driving just a paltry tuned K04, but this is my next mod. I hope Jamie has a nice stocking stuffer deal for the RSB, it's on my very short list.
 Old 11-22-2013, 09:04 PM   #25
Playaj's Avatar
I second this!
to be installed :
3 Port EBCS
Autotech internals
Corksport Pmm
Test pipe
Bad morning what_the MazdaSpeed 3/6 - Wheels & Tires 6 05-17-2010 04:20 PM
Page generated in 0.44841 seconds with 38 queries
