Like Tree130Likes
 Old 06-04-2012, 02:51 PM   #1
Arrow New JBR 3.5" Wide Path Full Intake In Stock!!
James Barone Racing
Performance Aftermarket Parts & Accessories
MAZDASPEED 3
JBR 3.5" WP (wide Path) Full Intake System
Link to Product Page
The JBR 3.5" Wide Path Full Intake System is the only affordable solution for those seeking unrestricted flow from filter to turbo. The one piece design eliminates the need for unnecessary couplers and the joining of multiple sections that increase turbulence, friction and loss of airflow. Increased efficiency means lower BAT’s, reduced back pressure and increased performance from your turbo. From end to end the 3.375”cross sectional inside diameter of the Wide Path Intake is capable of flowing over 300 g/s on the stock KO4 turbo consistently at WOT while maintaining stable AFR’s. 4-ply reinforced couplers, stainless steel T-bolt clamps, thick walled silicone hose and a K&N Dry-Flow air filter make for a complete stock or big turbo intake solution. AP Tuning is required to run this intake.
Includes:
Full Intake/TIP 3.370" ID MAF
Recirc or non-recirc options available
Black Silicone VC Hose
Black Silicone WG Hose
2.25" x 3.5" Reducer Coupling (Stock Turbo) or 4" x 3.5" Reducer Coupling (Big Turbo)
T-Bolt Clamps
K&N Dry Flow Filter
The filters shipping with the kits are 3.5" black washable Dry-Flow filters. Dry-flow Air Filters are specially designed for tough off-road applications. They provide outstanding levels of filtration efficiency and capacity. K&N Air Filters are oil-free and their synthetic media is incredibly easy to clean. Even more impressive, they are so durable that they maintain their shape under even the most severe abuse.
The ECU will need to be relocated. I seriously recommend using 3M 2-side outdoor foam tape and attaching it to the top of the fuse box cover. There is no wiring harness modifications needed and if the fuse box cover and back of ECU are properly cleaned it will not come off. The fuses are still accessible as well. I've been running it this way for over 5 months and it is solid and looks really good too. I see no reason to spend money on some relocate kit for such a simple solution.
Air straighteners are not included. We have experienced no tuning related, performance related or trim related issues due to the lack of an air straightener. It is the responsibility of the purchaser to properly perform a MAF cal and tune for this intake. We will not be providing maps. I have priced these to allow plenty of room for the purchase of a honeycomb or other form of air straightener should you feel you need one. Honeycomb air straighteners for these intakes can be found here.
MAZDASPEED 6 Sorry guys this does not fit without the battery being relocated
Couplers are also sold separately should you decide to upgrade the stock turbo to a bigger turbo with a 4" inlet.
I know several of you wondered what it would sound like so here you go. Enjoy!
Fully Bolted 2011 MAZDASPEED3 W/ TurboXS RFL BOV
Stock 09' MAZDASPEED 3 w/ stock BPV
Stock 09' MAZDASPEED 3 w/ Vorge v2 PBV
Monotonous ONE likes this.
The Following 118 Users Say Thank You to JBR For This Useful Post:
08.5MS3 (07-19-2012), 09speedaddict (06-04-2012), 3starmagnum (06-04-2012), 671 grains of reason (06-04-2012), adlpb (06-05-2012), AJ713 (06-18-2012), Alpha (03-11-2013), anavrinIV (06-04-2012), atvfreek (06-16-2012), bertrand_CX_7 (06-05-2012), Black Metal (06-04-2012), BlueStreak (07-26-2012), bmfms3 (07-31-2012), BobbleHead (06-23-2012), BoogadyBoo (06-06-2012), Boost Addict (06-23-2012), BPASPEED (06-04-2012), BrianB6 (06-04-2012), BudUMfan (06-19-2012), burntRice (06-22-2012), Caligula (12-29-2012), captain slow (06-05-2012), ccspeed3 (06-18-2012), charlesfist (06-27-2012), Chief_Wiggum (06-06-2012), ChimmyChong (06-06-2012), CWP_MS3 (01-03-2013), Dano (07-07-2012), dantes5823 (06-04-2012), Dash08 (06-04-2012), DingoDave (06-11-2012), Docnox (06-28-2012), Domino81 (08-03-2012), Downmented (06-21-2012), dpolseno41 (06-04-2012), Easter Bunny (06-05-2012), easy (06-04-2012), EdgeAutosport.com (06-04-2012), eljefe62 (12-28-2012), Eric28243 (07-05-2012), Etipp98 (06-06-2012), exentix (06-04-2012), Ezekiel81923 (06-05-2012), fooqr (06-04-2012), Gatorbait (06-04-2012), greenespeed (06-04-2012), Hamilton69 (06-04-2012), Hectik1 (07-04-2012), helmetface (06-04-2012), InFeXIoN (06-09-2012), irishking03 (06-16-2012), J'sSpeed3 (10-23-2012), jack_hammer (06-05-2012), jdub0802 (06-05-2012), jeopardy98 (06-04-2012), Jfishe (06-25-2012), jman46 (06-04-2012), josurr (06-04-2012), jracer (12-27-2012), jscape83 (06-27-2012), JTMS3 (06-06-2012), kmac (06-23-2012), Kydizzle (06-04-2012), LatinKraze (06-04-2012), lilred (06-05-2012), m249saw (06-04-2012), m4tic (06-04-2012), manelscout4life (07-26-2012), Mase (06-04-2012), meelo88 (04-30-2013), melbaro (06-04-2012), Menace1 (11-20-2012), Mistersix (06-06-2012), Monotonous ONE (06-04-2012), MS3 Ventura (09-10-2012), Ms3_Miami (07-03-2012), MS6 Sanchez (04-08-2013), Mythyk (06-05-2012), Nathan 6 (08-27-2012), nickm757 (06-05-2012), nighthawk358 (06-04-2012), NoRegrets (06-04-2012), NoTraction (06-30-2012), PapaBruno (06-29-2014), Pointless (06-05-2012), Pseud0logik (06-05-2012), Red (06-04-2012), rghispanic88 (06-04-2012), RichieRichness (08-27-2012), rolanblack (06-06-2012), ryno077 (06-06-2012), s1xstringmayhem (06-04-2012), Scoobs (06-04-2012), Sid3wayS (06-04-2012), silentwolf8 (06-05-2012), SLOWHATCH (06-04-2012), smoogs12 (06-04-2012), Snotrocket (06-06-2012), SofaKingAwesome (06-11-2012), speed14 (06-04-2012), Speed3eak (06-05-2012), SpeedNess (06-04-2012), SpeedRebirth (03-08-2013), Speed_j23 (06-18-2012), stp (06-04-2012), suparobg (08-16-2015), taf0422 (06-20-2012), tbot (06-09-2012), Tomas (07-19-2012), uncorked11 (06-04-2012), Vader (06-05-2012), vrspeed10 (07-04-2012), WAHBAM (07-26-2012), WhiteWidow (05-11-2013), xI Leveler Ix (06-28-2012), XxSmarTz (12-30-2014), Ziggo (06-04-2012), zxhoya (02-15-2013)
 Old 06-04-2012, 02:53 PM   #2
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Fucking sexy..
JBR (06-04-2012)
 Old 06-04-2012, 02:55 PM   #3
radbrad's Avatar
Posts: 538   (View Stats)
Ugh I wish I didn't just buy a new tip
07Speed3
radbrad is offline   Reply With Quote
The Following User Says Thank You to radbrad For This Useful Post:
JBR (06-04-2012)
 Old 06-04-2012, 02:56 PM   #4
Looks good Jamie
JBR (06-04-2012)
 Old 06-04-2012, 02:58 PM   #5
Red
Red's Avatar
Posts: 113   (View Stats)
Red has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond repute
Groaned at 3 Times in 1 Post
How long is pre order for?
2012 Velocity Red Mica w/Tech / JBR rear motor mount & SSP with weight / Cobb AP w/ CS stage 2 intake / auto tech internals / eBay one piece down pipe race pipe / turbo smart BPV / raceland coilovers / Motegi 18x8 et 40 with 235-40-18 tires
Red is offline   Reply With Quote
The Following User Says Thank You to Red For This Useful Post:
JBR (06-04-2012)
 Old 06-04-2012, 02:58 PM   #6
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
Looks great!
One question:
How well does this fit with the factory battery box in place?
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
The Following 8 Users Say Thank You to JacksonMS30 For This Useful Post:
BobbleHead (06-23-2012), helmetface (06-04-2012), JBR (06-04-2012), lilred (06-04-2012), NoRegrets (06-04-2012), SLOWHATCH (06-04-2012), smoogs12 (06-04-2012), themytb (06-04-2012)
 Old 06-04-2012, 02:59 PM   #7
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
Put me on the preorder list recirc and K04 adapter please.
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
The Following 2 Users Say Thank You to Black Metal For This Useful Post:
JBR (06-05-2012), sleepyspeed6 (06-05-2012)
 Old 06-04-2012, 02:59 PM   #8
ztnedman1's Avatar
Posts: 338   (View Stats)
ztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the world
Any idea if corksport cold air box will work with this?
2010 Velocity Red MS3 (140k+ miles) Intake/Exaust/AP selftuned(313/399 long time ago) - SOLD
2004 Corvette Z06
SCCA Bowling Green Match Tour - GS 1st place
SCCA Wilmington Champ Tour - GS 2nd place
SCCA National Championship - GS 3rd place
SCCA Grenada Match Tour - AS 1st place
ztnedman1 is offline   Reply With Quote
The Following User Says Thank You to ztnedman1 For This Useful Post:
 Old 06-04-2012, 03:00 PM   #9
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
So no recirc option for the bpv?
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
taf0422 (06-04-2012), themytb (06-04-2012)
 Old 06-04-2012, 03:07 PM   #10
No it will not fit the CS cold air box.
The pre-order will run up until we start shipping.
They will be available with a recirc connection or with out.
Thanks,
Jamie
 Old 06-04-2012, 03:08 PM   #11
fooqr's Avatar
Posts: 559   (View Stats)
fooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the world
I'm in!
08 MS3 GT (SSM). JBR WP intake, CS boost tubes, Forge v2 BPV, JBR TB/IM TIG, JBR TB coolant bypass, JBR EGR block-off, 3-bar MAP, PTP pill, bnoon bolt, SM OCC (MD kit) w/ Kat's heater, UR DP (ceramic cat), UR resonated TP/CBE, JBR SSP, SU shift bushings, JBR trilogy mounts (CRMO 88 RMM, 70 PMM/TMM), Koni yellows, JBR RSB, 2nd Fiamm, Stoptech SS lines, Hawk HPS, spin-on CX-9 oil filter, Fumoto valve, PP 5W-30, XT-M5-QS, tints, clear bra, Continental DWS, ITV22, DashHawk, AP, AT internals
There are no stupid questions, but there are stupid people and some of them ask questions.
- A. Funicello
fooqr is offline   Reply With Quote
 Old 06-04-2012, 03:09 PM   #12
snailD's Avatar
Posts: 3,039   (View Stats)
i believe i was told that the battery box will be fine, but the ecu will have to be relocated. as far as the relocation goes, jamie said the relocation kit is 3m tape lol, but i dont doubt it will work exceptionally well. @jbarone where do you suggest relocating the ecu to?
EDIT: seriously thinking about joining this group buy. will need to make a conscious decision in a few days
 Old 06-04-2012, 03:14 PM   #13
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
I'm keeping a watch on this and on my funds. I'll be getting one, the question is when.
Would you be able to ship with both the stock turbo and big turbo silicone adapters? I'll be buying this in preparation for a BT build but will have to use it on my stock turbo for a while
Blue Pu.
The Following 2 Users Say Thank You to anavrinIV For This Useful Post:
fooqr (06-04-2012), snailD (06-04-2012)
 Old 06-04-2012, 03:16 PM   #14
MS309's Avatar
Posts: 673   (View Stats)
MS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the world
Will this require relocating the ECU or does this somehow squeeze in ?
'11 CWP Speed3
More torque than your right arm.
MS309 is offline   Reply With Quote
 Old 06-04-2012, 03:19 PM   #15
snailD's Avatar
this also
 Old 06-04-2012, 03:29 PM   #16
dpolseno41's Avatar
Posts: 1,819   (View Stats)
Count me in for a purchase.
 Old 06-04-2012, 03:33 PM   #17
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
this looks great too lol!
 Old 06-04-2012, 03:38 PM   #18
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
I will pick this up once I get a BIGGER turbo.
Looks fantastic Jamie!
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 06-04-2012, 03:41 PM   #19
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Hmmm...seksi. Count me in for one when I go BT later this year!
The Following User Says Thank You to tbot For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 04:28 PM   #20
m4tic's Avatar
Posts: 4,928   (View Stats)
MS6 fitment?
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
JBR (06-05-2012)
 Old 06-04-2012, 08:44 PM   #21
m4tic's Avatar
Originally Posted by m4tic View Post
MS6 fitment?
@jbarone
2017 Daytona 392
2007 MS6 w/ Cheez
JBR (06-05-2012)
 Old 07-04-2012, 08:41 PM   #22
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
Subbing for future mod. And another jbr Pc that's pure sex
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
 Old 06-04-2012, 11:03 PM   #23
razorscs's Avatar
Posts: 391   (View Stats)
razorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the world
MS6 fitment?
+1
2007 MS6- BNR S3, HTP 3" Intake, 3 Bar MAP, DO Meth, CP-E Catted DP, Autotech Internals, SRI, ETS TMIC, Sure Sidewinder, Sure Charge Tubes, Lex tuned, BC Coils, Sure RMM, JBR SSP, Dreadnaught, Whiteline RSB
2008 Mazdaspeed3- Totalled!
razorscs is offline   Reply With Quote
The Following User Says Thank You to razorscs For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 04:35 PM   #24
BPASPEED's Avatar
Posts: 1,891   (View Stats)
Groans: 60
Add me to the list.
The Following User Says Thank You to BPASPEED For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 04:42 PM   #25
Ziggo's Avatar
Posts: 3,843   (View Stats)
Add me for the initial group as well.
2.5" coupler and no recirc.
Love the pricing, and I am sure the product is great. Is there an air straightener included?
Zigatapatalka
Ask Me About My:
JBR (06-05-2012)
 Old 06-04-2012, 04:44 PM   #26
s1xstringmayhem's Avatar
Posts: 809   (View Stats)
s1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the world
This is fucking sexy!!!! Put me on the pre-order list!!
Stock.
s1xstringmayhem is offline   Reply With Quote
The Following User Says Thank You to s1xstringmayhem For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 04:49 PM   #27
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Very nice looking and fair price. Wish it fit with a cold air box. Even if it took some modifying.
Any chance of @jbarone making a cold air box for this intake in the future?
The Following User Says Thank You to SLOWHATCH For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 04:57 PM   #28
Mase's Avatar
Posts: 1,282   (View Stats)
Mase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the world
Groans: 143
Groaned at 14 Times in 14 Posts
You know im in.
2014 Mazda 6 Grand Touring. Bone stock...
Old car: 2011 Speed 3 /w Tech Pkg. Cobb AP, CPE DP & CBE, JBR Whale Penis Intake, SSP, Motor Mount Trio, and Heavy Shift Knob /w silver vein!, Autotech internals, KSport Konrol Pro Coilovers, Corksport Interior LED's, LED Foglights and LED Rear Bumper Lights. Freek Tuned 50/50 e85
Mase is offline   Reply With Quote
The Following User Says Thank You to Mase For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 05:00 PM   #29
Dr. Speed's Avatar
Posts: 610   (View Stats)
Dr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the world
Does this intake change the stock MAF housing diameter? (will it need a tune to run right?)
Dr. Speed is offline   Reply With Quote
The Following User Says Thank You to Dr. Speed For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 05:18 PM   #30
snailD's Avatar
Yes. It's a 3.5 in maf not a 2.56in or w.e the stock is
The Following User Says Thank You to snailD For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 05:03 PM   #31
dantes5823's Avatar
Posts: 6,576   (View Stats)
damn it! just as i go BT. Maybe ill part with my setup at a later date.
The Following User Says Thank You to dantes5823 For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 05:36 PM   #32
RobLoMS3's Avatar
Posts: 21   (View Stats)
RobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of light
+1 for recirc and k04!!
Sent from my PG86100 using Tapatalk 2
2008 MS3 AEM CAI, COBB TIP, HKS CB, TURBOXS BPV, COBB FMIC, JBR RMM, JBR OCC, CP-E CATTED DP, TB TIG, SnailD Tune E85
RobLoMS3 is offline   Reply With Quote
The Following User Says Thank You to RobLoMS3 For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 05:37 PM   #33
m249saw's Avatar
Posts: 718   (View Stats)
m249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the world
+1 on the airflow straightener.
Sent from my DROID RAZR using Tapatalk 2
2012 Subaru STi Wagon, Dark Grey Metallic. Stock as fuck.
m249saw is offline   Reply With Quote
The Following User Says Thank You to m249saw For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 06:35 PM   #34
Enter the 36 Chambers
NoRegrets's Avatar
Posts: 612   (View Stats)
i will be getting this intake in the future... need to upgrade the brake system first
Tuned by Nishan
SP63 Longblock
The Following User Says Thank You to NoRegrets For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 06:38 PM   #35
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Fucking LOL @ WP intake!!!
I sure hope that's in the model number because that's awesome!!!
this forum serves 2 purposes
The Following User Says Thank You to Dash08 For This Useful Post:
JBR (06-05-2012)
 Old 06-04-2012, 06:43 PM   #36
fooqr's Avatar
I didn't even notice that at first. That's fantastic! Need a plausible explanation, though. Wide Path? Whole Piece? Wind Pummeler?
Sent from my DROID2 using Tapatalk 2
- A. Funicello
The Following 2 Users Say Thank You to fooqr For This Useful Post:
Dash08 (06-05-2012), JBR (06-05-2012)
 Old 06-04-2012, 06:46 PM   #37
m249saw's Avatar
Whale Penis
The Following 4 Users Say Thank You to m249saw For This Useful Post:
JBR (06-05-2012), lilred (06-05-2012), snailD (06-04-2012), WAHBAM (09-04-2012)
 Old 06-04-2012, 06:55 PM   #38
I <3 your mom
Dash08's Avatar
Groans: 293
Originally Posted by m249saw View Post
Whale Penis
^^Thank you captain obvious. He was talking about a marketing cover up.
I like wide path. That's a good one.
The Following 3 Users Say Thank You to Dash08 For This Useful Post:
fooqr (06-05-2012), JBR (06-05-2012), SLOWHATCH (06-04-2012)
 Old 06-04-2012, 06:59 PM   #39
m249saw's Avatar
My bad, didnt pick up the sarcasm.
The Following 2 Users Say Thank You to m249saw For This Useful Post:
 Old 06-04-2012, 07:35 PM   #40
Wide Path, that's a great cover.
Dash08 (06-04-2012), exentix (06-04-2012), fooqr (06-05-2012), lilred (06-05-2012), SLOWHATCH (06-04-2012), snailD (06-04-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f493/new-jbr-3-5-wide-path-full-115502/
Turboaufladung - [ALLE] Luftansaugung OEM, SRI, CAI, JBR Wide Path im Bezug zur Luftmasse und Verwendung - Seite 2 This thread Refback 07-18-2013 12:06 PM
Complete tip/sri - DFW Mazdas This thread Refback 06-06-2012 05:57 PM
Report: Nissan to remain "patient" with Titan full-size truck Haltech Automotive News 0 10-21-2011 02:10 PM
Full 3" intake with Cobb maf? zx2man MazdaSpeed 3/6 - Big Turbo Builds 8 06-14-2010 03:45 PM
REPORT: Ford Transit Connect arriving in U.S. with full interiors that get stripped to comply with "Chicken Law" Haltech Automotive News 0 09-22-2009 12:40 PM
VIDEO: Full version of Audi Super Bowl commercial, "Chase" Haltech Automotive News 1 02-01-2009 07:09 PM
All-new 2009 Dodge Ram Named "Full-Size Pickup Truck of Texas" Haltech Automotive News 0 11-13-2008 08:30 AM
Page generated in 1.06333 seconds with 51 queries
