  • 1 Post By ahfunaki
 Old 08-03-2012, 07:59 AM   #1
Arrow New JBR MAZDASPEED 3/6 & CX7 Boost Tubes & Recirculation Hoses in Stock!!
James Barone Racing
Performance Aftermarket Parts & Accessories
JBR MAZDASPEED 3/6 and CX7 Boost Tubes and Recirculation Hoses
The JBR DISI Boost Tubes $60.00 Shipped (Domestic Only) International Shipping Available
LINK TO PRODUCT PAGE
The JBR DISI Boost Tubes are a direct silicone replacement for the soft rubber OEM tubes. Over time, the OEM hose will stretch, crack, show signs of deterioration and may split. Once leaks form, boost will be lost and serious engine drivability issues will occur run poorly and possibly cause the check engine light to come on.
The JBR DISI Boost Tubes are molded in the form of the original for a *direct replacement fit. They’re constructed out of five (5) layers of high performance silicone and four (4) layers of reinforcement to minimize any possible expansion under pressure and increase the spool time of the turbo. The JBR DISI Boost Tubes will easily outlast the life of the car, increase performance and add some color for a nice personalized touch.
*Does not fit the early model Mazdaspeed 6
Includes:
  • 1 set of DISI Boost Tubes
The JBR DISI Bypass Valve Return Hose $35.00 Shipped (Domestic Only) International Shipping Available
The JBR DISI Bypass Valve Return Hose is a direct silicone replacement for the OEM return hose. In less than a year the OEM hose will show signs of deterioration and cracking. Over time, leaks will form and what once was a smooth running engine will soon decline in performance and run poorly and possibly cause the check engine light to come on.
The JBR Bypass Valve Return Hose is molded in the form of the original for a direct replacement fit. It’s constructed out of five (5) layers of high performance silicone and four (4) layers of reinforcement. The JBR Bypass Return Hose will easily outlast the life of the car, increase performance and add some color for a nice personalized touch.
Includes:
  • 1 DISI Bypass Valve Return Hose
The Following 10 Users Say Thank You to JBR For This Useful Post:
08.5MS3 (08-03-2012), Carlo1170 (08-08-2012), Chief_Wiggum (08-03-2012), Code Monkey (01-25-2013), dereeek (08-03-2012), Dmurray06 (08-03-2012), Menace1 (01-26-2013), Raider (10-23-2012), speed_freak91 (08-19-2012), Vader (08-03-2012)
 Old 08-19-2012, 07:44 PM   #2
radbrad's Avatar
Posts: 538   (View Stats)
Works perfectly without any modification for cobb fmic bpv location and htp 3in inlet.
<a href="http://smg.photobucket.com/albums/v619/gtm153/car/?action=view&current=_MG_2611.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v619/gtm153/car/_MG_2611.jpg" border="0" alt="Photobucket"></a>
07Speed3
radbrad is offline   Reply With Quote
 Old 08-19-2012, 07:45 PM   #3
radbrad's Avatar
07Speed3
The Following 2 Users Say Thank You to radbrad For This Useful Post:
JBR (08-22-2012), SC_Galoot (08-23-2012)
 Old 10-22-2012, 07:52 PM   #4
qwerty4550's Avatar
Posts: 62   (View Stats)
qwerty4550 has a spectacular aura aboutqwerty4550 has a spectacular aura about
Over the weekend I installed a JBR Silicone Turbo Inlet Pipe and JBR Silicone Recirculation Tube. If I push the Recir pipe all the way onto the inlet pipe, it seems like the hose does not fit perfectly onto the BPV. Should I not push the hoses so they sit flush against one another on the TIP side?
2007 Mazdaspeed3
Power: COBB AP, CP-e TMIC, Mazdspeed CAI v1 w/straight, JBR TIH, Autotech Internals
Misc: JBR Recirc hose, JBR SSP+knob w/ TWM bushings, AWR rmm
qwerty4550 is offline   Reply With Quote
The Following User Says Thank You to qwerty4550 For This Useful Post:
JBR (10-23-2012)
 Old 10-23-2012, 07:49 AM   #5
Should be fine when the connections are flush.
Here are a few installed picks:
Post a couple of good pics and I'll try and help. The TIP may also need to be rotated a bit. It's tough to say with out seeing it.
Thanks,
Jamie
qwerty4550 (10-23-2012)
 Old 10-23-2012, 10:39 AM   #6
qwerty4550's Avatar
Thanks,
Jamie
Here is a picture of where the recirc hose meets the bpv. Cell phone pic, so hopefully it isn't too bad.
2007 Mazdaspeed3
 Old 10-23-2012, 12:09 PM   #7
It's tough to tell but it appears that the hose is not rotated to the angle of the BPV. That and the intake may be pushing the TIP back towards the rear of the car a bit. I think there are some adjustments that need to be made. The tube we make is actually a wee bit longer and the exact same shape as stock so something is in need of adjustment.
Thanks,
Jamie
 Old 10-23-2012, 01:10 PM   #8
qwerty4550's Avatar
For a point of reference, where should the JBR logo be? I believe my hose had 1 logo and it is where the Recirc hose meets the TIH. I dont believe the TIH is being pushed back by the intake, but I will check it out.
2007 Mazdaspeed3
 Old 10-23-2012, 01:48 PM   #9
The logo must be at the end closest to the BPV. Ignore the location in the second pic above. The logo location in that pic is a mistake. I think you may have the hose on backwards. Sorry for the confusion.
Jamie
qwerty4550 (12-03-2012)
 Old 12-03-2012, 09:59 AM   #10
SparkySparks's Avatar
Posts: 1,314   (View Stats)
@jbarone; Just installed your boost tubes and the hot side boost tube has a kink in it when I tighten the intercooler down. I tried change the way I had it indexed but didn't help any. I will try and get a picture of it for you when I get home.
On Order:
Coming Soon:
DIY Projects:
 Old 12-03-2012, 08:43 PM   #11
qwerty4550's Avatar
Jamie
I fixed this a while back and it is working great now. With the silicone tube I get a nice more audible feedback from the bpv as well. The whooosh sound is pure sex.
2007 Mazdaspeed3
JBR (12-04-2012)
 Old 01-25-2013, 11:23 AM   #12
ahfunaki's Avatar
Posts: 764   (View Stats)
ahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the world
I'm having this same issue. I can't get the hot side to fit right at all. There is a gap on the bottom and the top won't go on all the way.
I have a Street Unit TMIC and it has a little lip on the lnlet of the TMIC and I think this might be part of my problem?
Here is a pic. And the only way I could get the clamp to fit was like this.
@jbarone;
File Type: jpg WPFHNML4YKrJdpLGUfRya_k5sxXnHu6Mc-ras6Aou3A[1].jpg (60.2 KB, 217 views)
[ 2010 Black Mica Speed3 w/tech package ]
go | COBB AccessPORT | Autotech HPFP Internals | TurboXS Catless Downpipe | TurboXS Race Pipe | Ultimate Racing Catback w/Magnaflow Resonator | Corksport Urethane Exhaust Hangers |
JBR Boost Tubes | cp-e Nviscid Pipe | cp-e XcelNANO SRI | cp-e HeliHose | cp-e Stage 1 xFlex RMM | JBR SSB | RDS-05 Rear Sway Bar |
Torque Solutions Delrin Shift Knob | Block8Head Dual Defrost Pod | Aeroforce Interceptor | Prosport Evo Boost Gauge
show | BC Racing BR Coilovers w/Koyo | SPC Rear Camber Arms | Avid.1 AV-06 18x8 +42 225/40 | 2011+ Tech Headlights | Corksport Tow Plate |
Morimoto 5000k bi-xenon / 3000k fogs | 3BSpec Switchbacks | Corksport LED Rear Bumper Lights | S204 STi Lip
ahfunaki is offline   Reply With Quote
 Old 01-25-2013, 11:57 AM   #13
I have no experience with that intercooler but it looks like the hose is not on all the way.
 Old 01-25-2013, 03:17 PM   #14
ahfunaki's Avatar
It isn't on all the way because it doesn't fit right. Adjusted and took a few more pics. Now it's even worse.
Anyone else have a Street Unit TMIC that can chime in on fitment?
 Old 01-25-2013, 03:18 PM   #15
ahfunaki's Avatar
 Old 01-26-2013, 10:12 AM   #16
Standsideways's Avatar
Posts: 363   (View Stats)
Standsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the world
ohh fail.
you guys didnt think these were made for the stock intercooler?
@jbarone, may be good to add an intercooler fitment disclaimer for these if you havent lol.
ahfunaki- you may wanna use a smaller width worm gear clamp on areas like that rather than a t bolt clamp.
Standsideways is offline   Reply With Quote
 Old 01-26-2013, 10:20 AM   #17
ahfunaki's Avatar
Originally Posted by Standsideways View Post
ohh fail.
So what does work with aftermarket intercoolers then? I wasn't aware of any special tubes?
And for the time being I'm just going to put my stock intercooler back on until I figure out the right way to go about this.
Standsideways likes this.
 Old 01-26-2013, 10:33 AM   #18
ide be looking to the manufacturer of your intercooler for that info..or SEARCH.
its the same deal with phelonic spacers on intake mani's, sometimes the hoses arent even close to fitting afterward with the new space taken up.
 Old 01-26-2013, 10:51 AM   #19
Menace1's Avatar
Posts: 946   (View Stats)
Menace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the world
Groaned at 40 Times in 21 Posts
I would measure your length, diameter, and angle, then buy a universal silicone hose.
Silicone Hose
Silicone Hose
Mishimoto Universal Couplers: JSC Speed
2012 MS3 / Cobb AP/ JBR / STRATIFIED Stage 1 Tuned / Stock K04 / CPE HPFP / Maisonvi Heavy Shift Knob / JBR Powerpath Intake / JBR TIP / JBR BT / JBR BVH / JBR 88D RMM /
FOR NOW...
Menace1 is offline   Reply With Quote
The Following User Says Thank You to Menace1 For This Useful Post:
Standsideways (01-26-2013)
 Old 01-26-2013, 08:35 PM   #20
ahfunaki's Avatar
ohh fail.
You find me an upgraded TMIC manufactured by any company that requires a special sized tube for installation. Or find me a set of boost tubes that state they won't work with aftermarket TMIC's.
 Old 01-27-2013, 03:56 AM   #21
Looks like youve got one.
 Old 01-27-2013, 04:26 AM   #22
Get rid of the wide t bolt clamps on stuff like that, look at the pic...Use worm
Gear clamps.
Looking at the pic ide agree with jamie, you dont have it on properly.
There fuckin silicone boost tubes not sloppy limp dick hoses.
http://www.onpointdyno.com/?p=2676
Click the link, GO TO THE BOTTOM AND READ ABOUT why you waste your $ on fail t bolt clamps.
You should not be using those clamps and you dont have the hose on properly.
Jbr got it right.
Sasha Anis from onpoint/genesis racing-
"Forget T-bolt clamps. They are way too wide to do a good job of creating a sharp clamp on the piping and in many situations there is not enough depth from the rolled bead to the throttle body / intercooler for proper clamp engagement after the bead. This is asking for trouble! Always use high quality stainless steel clamps. Home Depot sells Trident clamps and they are fantastic"
Just your clamps alone are contributing to your headache, they are too big and wide and when you tighten them they will work the hose off the hump(ESPECIALY WITH SILICONE HOSES LIKE THAT)...like explained in the link above.
Last edited by Standsideways; 01-27-2013 at 04:26 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-27-2013, 07:08 AM   #23
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
None of the bigger tmic's require the user to change the stock boost tubes. There's no reason why these shouldn't fit since they are direct replacements for OEM. I would get it further down on the outlet and see about getting the tmic inlet side further into the tube.
tappy-tap-tappytalk
Mods: stock
 Old 01-27-2013, 09:10 AM   #24
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
To me it looks like it should slide on a little more to the TMIC. If your OEM boost tubes fit then I see no reason the JBR ones shouldn't fit. You can always take them off and compare side by side with OEM. Either way good luck and I hope it all gets sorted out.
 Old 01-27-2013, 02:17 PM   #25
I had to trim mine a little shorter as they were about half an inch longer on both sides of the bend when compared to the stock tube. I'm fine with having to do a little trimming as you can always remove material but never add it. From your pictures the way your tube is kinked looks like mine did but I had mine pushed all the way down on the turbo and the intercooler.
Sent from my SPH-L710 using Tapatalk 2
On Order:
Coming Soon:
DIY Projects:
Page generated in 0.46255 seconds with 29 queries
