Like Tree174Likes
 Old 01-29-2013, 11:54 AM   #41
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
And BTW, BSD will only intensify your vibes. Take that into consideration if you're in the market for mounts.
Essentially, the PMM added a lot of vibes. The trans mount added a lot of noise. Gears 1 and 2 are very noisy.
However, made the car crisp, connected,and I can really appreciate the rawness and feedback of stiff mounts. But everybody who rides in my car makes a comment about NVH.
Just saying...
Considering AWR buttfucked MS6 PMM buyers for years, knew his mount created a leveling issue and continued to sell them anyway, I'd say JBR is more than deserving of the communities business.
The Following 5 Users Say Thank You to I<3Groceries For This Useful Post:
Dizzy Turbo (01-29-2013), Downmented (02-04-2013), KusteLokal (01-29-2013), superskaterxes (01-29-2013), TiGraySpeed6 (01-29-2013)
 Old 01-29-2013, 12:03 PM   #42
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Bsd and pmm do not mix well at all. I think the duros you are making are fine
 Old 01-29-2013, 01:03 PM   #43
gigs2000's Avatar
Posts: 198   (View Stats)
gigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the world
Groans: 357
Groaned at 73 Times in 45 Posts
this is now on my buy list. amazing looking as always.
gigs2000 is offline   Reply With Quote
 Old 01-29-2013, 01:32 PM   #44
r3d
r3d's Avatar
Posts: 182   (View Stats)
r3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond repute
I like the looks of this mount, and I would believe it would perform the same.
For the passenger mount I would like to make a sugestion. Can you make a design similar to the stock mount in terms of load bearing and dissipation. In other words, make the bushing and the shaft to sit vertically instead of horizontally.
Building it from ground up:
r3d is offline   Reply With Quote
The Following User Says Thank You to r3d For This Useful Post:
DamagedGoods (01-30-2013)
 Old 01-29-2013, 03:56 PM   #45
LumberJack's Avatar
Looks good, always great quality from JBR! Love there products!
10.36@148 Fastest Gen 2
JBR (01-30-2013), Juyoung (04-13-2013)
 Old 01-29-2013, 04:04 PM   #46
jbmazda6's Avatar
Posts: 1,230   (View Stats)
jbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the world
PM'd about passenger mount Jamie
JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray
Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers
Sponsored By: JamesBaroneRacing.com
jbmazda6 is offline   Reply With Quote
The Following User Says Thank You to jbmazda6 For This Useful Post:
JBR (01-30-2013)
 Old 01-29-2013, 05:09 PM   #47
GunGuru727's Avatar
Posts: 3,486   (View Stats)
GunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the world
Groans: 38
Groaned at 20 Times in 14 Posts
@Lakespeed6;
Do it up son
FreekTuned 2006 CWP MazdaSpeed6
ATP EWG GTX3076r - HTP 3" Intake System - CPE Single Exit Exhaust
ATP Catless Down Pipe - CPE Differential Mount - CPE Top Mount Intercooler
JBR 80D Trilogy Mount Package - Grimmspeed EBCS Autotech Internals
Bosch 3 Bar Map Sensor - Bit Wise Plug n Play - GFB Hybrid BOV
Bilstein Struts - H&R Sport Lowering Springs - Cobb v3 - e85
Granite State Dyno 4/3/15: 363hp/370trq
2013 Plasma Blue Subaru STI Hatch
E85 FreekTune - Full Bolt-ons
5/14/14 - 12.4@110
2010 NASA Space Shuttle Silver GenPu
E85 FreekTune
EWG GTX3071r: 401HP/386TRQ
K04: 323HP/TachFail SAE
GunGuru727 is offline   Reply With Quote
The Following 2 Users Say Thank You to GunGuru727 For This Useful Post:
JBR (01-30-2013), Lakespeed6 (01-29-2013)
 Old 01-29-2013, 05:25 PM   #48
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I had an AWR 70 duro TMM for a week before the bushing shoulder disintegrated and the mount fell apart so I get that. AWR quickly sent me the 88 duro and sure enough, those bushings were strong enough for the load. It seemed to me the softer bushings were ok, but it was the softer shoulder material that couldn't sustain the lateral load. All I am saying, is there has to be a middle ground between race car and not race car. I would prefer if the motor/trans didn't shift around and pull on my shift cable as I was trying to find 3rd but I personally can't do 88 duro. I literally just pulled all 3 88 duro mounts off and went back to stock a few weeks ago. The difference was pretty damn significant but now my motor/trans is moving around again.
I would like to sacrifice some NVH and maybe have the engine/trans move around less as opposed to a lot of NVH and no movement. JBR, is there anyway to offer a softer duro in your design? I will buy a mount and if you ship me different duros, I will happily be a guinea pig to find a happy medium. I can swap that mount in like 30 minutes now.
MINI H1 6.0 - CAR LED TAILS
DamagedGoods (01-29-2013), Rainmens (01-29-2013)
 Old 01-29-2013, 05:30 PM   #49
SIXual Panda's Avatar
Posts: 2,363   (View Stats)
Groans: 56
@jbarone;
Are you making all 3 mounts for us MS6 guys? Because if you are, I will happily ditch my sure order for them. But I want to make sure i do it before they start shipping the sure ones... Which. MIGHT be sometime in the next couple months. LOL
6ixof1 likes this.
I envy your ass raping.
The Following 2 Users Say Thank You to SIXual Panda For This Useful Post:
JBR (01-30-2013), KusteLokal (01-30-2013)
 Old 01-29-2013, 05:39 PM   #50
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
now i dont have a 6, but from what i know about the trilogy mounts on the 3, heres my .02. the pmm (which you will have 70 or 80 duro) is where MOST of the vibes came from. for those of your more sensitive to this, go softer. the trans mount really didnt add any additional vibes. im sure jamie has done testing on this.
JBR (01-30-2013)
 Old 01-30-2013, 11:27 AM   #51
Yes all three. We have had the rear for a long time.
Originally Posted by r3d View Post
For the passenger mount I would like to make a suggestion. Can you make a design similar to the stock mount in terms of load bearing and dissipation. In other words, make the bushing and the shaft to sit vertically instead of horizontally.
Yes, that's how it will be. It's the only way to do it and have it not fail.
Last edited by JBR; 01-30-2013 at 11:27 AM. Reason: MSF Database - Automerged Doublepost
Dizzy Turbo (01-30-2013), Jh8909 (01-30-2013), rob ms6gt (02-16-2013), Speed_j23 (01-31-2013), TiGraySpeed6 (01-30-2013)
 Old 01-30-2013, 11:45 AM   #52
Will there be a discount for buying all three when these come out? If not I'm gonna order your rmm today
The Following User Says Thank You to Dizzy Turbo For This Useful Post:
JBR (01-30-2013)
 Old 01-30-2013, 12:02 PM   #53
I'm sure there will be but honesty, I've not thought that far ahead. If you need the rear mount now go ahead and order, save your order # and I'll adjust the price of your future order to match the deal.
GunGuru727 likes this.
The Following 8 Users Say Thank You to JBR For This Useful Post:
alphasaur (09-02-2013), DickFitzwell (02-26-2013), Dizzy Turbo (01-30-2013), Don06speed6 (01-30-2013), dot584 (02-05-2013), exentix (01-30-2013), GunGuru727 (01-30-2013), r3d (01-31-2013)
 Old 01-30-2013, 12:19 PM   #54
If by need you mean I haven't got any parts in the mail for a few weeks then yes, I need it. Thank you, looking forward to getting these
JBR (01-30-2013)
 Old 01-30-2013, 12:26 PM   #55
sidekick's Avatar
Posts: 3,093   (View Stats)
I don't see MS6 mounts as an option anywhere in the motor mounts section. I only see 3/MS3 mounts.
SIXual Panda (01-30-2013), the public enemy (01-31-2013)
 Old 01-30-2013, 12:30 PM   #56
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Groans: 62
This is why we love you Jamie! Keep up the great work!
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
The Following User Says Thank You to Don06speed6 For This Useful Post:
JBR (01-30-2013)
 Old 01-30-2013, 01:14 PM   #57
Just ordered the rmm
JBR (01-30-2013)
 Old 01-30-2013, 01:56 PM   #58
Shipping shortly.
 Old 01-30-2013, 02:19 PM   #59
That's awesome! Thanks
JBR (01-31-2013)
 Old 01-31-2013, 07:55 PM   #60
rolanblack's Avatar
Posts: 2,110   (View Stats)
Jamie... you just gave ms6 guys nothing but chubbies. Hahaha
The Following 2 Users Say Thank You to rolanblack For This Useful Post:
edmsmallcash (02-13-2013), JBR (01-31-2013)
 Old 01-31-2013, 08:14 PM   #61
rolanblack (01-31-2013)
 Old 01-31-2013, 08:15 PM   #62
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
waaaant
Performance:
Stratified Tune in progress
JBR (01-31-2013)
 Old 01-31-2013, 08:31 PM   #63
I need to fix up that section of our site. It's confusing. I'll get on it.
Rear Motor Mount 80a Durometer [MS6MollyRMM] - $90.00 : James Barone Racing, Custom Fabrication
sidekick (01-31-2013)
 Old 01-31-2013, 08:55 PM   #64
Groans: 56
And the rmm only comes in 80 duro right?
The Following User Says Thank You to SIXual Panda For This Useful Post:
JBR (01-31-2013)
 Old 01-31-2013, 09:01 PM   #65
Yes.
After talking with @superskaterxes; tonight I'm gonna consider 80's for the trans too. Consider being the key word.
-Jamie
Alpha (02-05-2013), DamagedGoods (02-03-2013), OsOlOcO (02-27-2013), sidekick (01-31-2013), SIXual Panda (02-01-2013), superskaterxes (02-01-2013)
 Old 01-31-2013, 09:09 PM   #66
sidekick's Avatar
I think the problem is that I was looking under the billet mounts.
BTW, I wouldn't consider an 88a trans mount, but when the time comes, an 80a mount would probably be my first choice. Just throwing that out there for you to gauge interest.
Alpha (02-05-2013), JBR (01-31-2013)
 Old 02-01-2013, 04:43 AM   #67
s1xstringmayhem's Avatar
Posts: 809   (View Stats)
s1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the world
I would much rather have an 80d trans mount too. I dd my car and I don't have a vagina so if I can avoid making my car into a giant vibrator I will. Plus, if it does turn into a vibrator, my wife will actually want to drive my car which is bad fucking news. Don't get me wrong though Jamie, I'm buying your shit either way lol.
Stock.
s1xstringmayhem is offline   Reply With Quote
The Following 2 Users Say Thank You to s1xstringmayhem For This Useful Post:
6ixof1 (02-07-2013), JBR (02-01-2013)
 Old 02-01-2013, 06:28 AM   #68
I would love 80a for all mounts
JBR (02-01-2013)
 Old 02-01-2013, 02:09 PM   #69
Several big announcements coming in the next couple of days......
Jh8909 likes this.
The Following 7 Users Say Thank You to JBR For This Useful Post:
BrianB6 (02-02-2013), Code Monkey (02-01-2013), Dizzy Turbo (02-01-2013), Don06speed6 (02-01-2013), exentix (02-01-2013), Jh8909 (02-01-2013), s1xstringmayhem (02-01-2013)
 Old 02-01-2013, 02:37 PM   #70
Jh8909's Avatar
Posts: 1,457   (View Stats)
Groans: 130
Groaned at 8 Times in 7 Posts
You guys are all pussies. I'd take aluminum inserts if they were available
The Following 2 Users Say Thank You to Jh8909 For This Useful Post:
Captain KR (02-01-2013), Code Monkey (02-02-2013)
 Old 02-01-2013, 03:44 PM   #71
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
They're as close as your local machine shop....
Have at it!
Geez, after all, even regular 6 owners on 6Club are making aluminum sub-frame bushings, you should be able to organize your own stiff mounts
Prepping as dedicated track car - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
theschrum likes this.
340hp / 371tq
The Following 10 Users Say Thank You to TiGraySpeed6 For This Useful Post:
amggilly305 (02-01-2013), Code Monkey (02-02-2013), Easter Bunny (02-07-2013), gigs2000 (02-02-2013), Jh8909 (02-01-2013), KusteLokal (02-01-2013), ms3blackmica (02-04-2013), sidekick (02-04-2013), SpeedRebirth (02-02-2013), superskaterxes (02-04-2013)
 Old 02-02-2013, 09:46 AM   #72
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
LOL? Same shit happened to my 70a AWR RMM. Shit tore at the edges. AWR send over some 88s and its been a champ ever since. Funny thing is that I cant notice any additional NVH. 70 duro is obviously way too soft for the MS6 on any of these mounts.
Question though... after reading through this thread it sees as though the TMM wont really increase NVH as long as you dont couple it with the PMM, even with the 88 duro bushing. Is this a fair assessment?
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
 Old 02-03-2013, 06:26 AM   #73
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
it will increase the N, not so much the VH.
Blue Pu.
The Following 3 Users Say Thank You to anavrinIV For This Useful Post:
Caligula (02-03-2013), exentix (02-03-2013), JBR (02-04-2013)
 Old 02-04-2013, 08:55 AM   #74
Jamie asked me to get these posted for you guys.
JBR MAZDASPEED 6 TMM Installed....Discuss!
I'll update the OP and continue to provide updates. More good stuff to come.
-Jennifer
The Following 12 Users Say Thank You to JBR For This Useful Post:
08.5MS3 (02-07-2013), amggilly305 (02-04-2013), bazzarino (02-04-2013), Captain KR (02-04-2013), Dizzy Turbo (02-04-2013), Easter Bunny (02-07-2013), exentix (02-04-2013), Jh8909 (02-04-2013), robertof (02-04-2013), sidekick (02-04-2013), SIXual Panda (02-04-2013), taf0422 (03-07-2013)
 Old 02-04-2013, 09:43 AM   #75
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Good shit, that thing looks damn sexy too.
JBR likes this.
700HP CLUB
11.479@124mph
#DIX
The Following User Says Thank You to Downmented For This Useful Post:
JBR (02-04-2013)
 Old 02-04-2013, 09:52 AM   #76
Jh8909's Avatar
Groans: 130
Well, I just called up SURE and canceled my pre-order for the S6 side mounts so that I can get these new mounts from jbr!
JBR and edmsmallcash like this.
The Following 6 Users Say Thank You to Jh8909 For This Useful Post:
amggilly305 (02-04-2013), Dizzy Turbo (02-04-2013), Downmented (02-04-2013), JBR (02-04-2013), KusteLokal (02-04-2013), superskaterxes (02-04-2013)
 Old 02-04-2013, 11:56 AM   #77
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
Is there an approx timeframe when these are coming out.
My stockers are starting to go!
1990 Nissan Skyline GTR
1991 White BMW 325ic
The Following User Says Thank You to Lakespeed6 For This Useful Post:
JBR (02-04-2013)
 Old 02-04-2013, 01:25 PM   #78
I was told the TMM should be ready to ship in approx. 35 days or less, no ETA on the PMM. We should have a pretty good idea on that mount in a week or so.
-Jennifer
6ixof1 (02-07-2013), BrianB6 (02-05-2013), Dizzy Turbo (02-04-2013), Downmented (02-04-2013), Easter Bunny (02-07-2013), Lakespeed6 (02-04-2013), Lost hawaiian (02-04-2013), s1xstringmayhem (02-04-2013)
 Old 02-04-2013, 02:56 PM   #79
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
God that looks sexy.
Props to JBR on this. I love my MS3 mounts.
QFT because that right there is taking care of your customers!
www.tunedbynishan.com
Dizzy Turbo (02-04-2013), Jh8909 (02-04-2013)
 Old 02-04-2013, 04:36 PM   #80
stuntz89's Avatar
Posts: 169   (View Stats)
stuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the world
thank you @jbarone; i need th TMM right now
#3527. On genpus for winter >=)
5zigen Hyper 5ZR for summer
Magnaflow CBE, CPE Catted DP, Corksport stage 2 SRI w/Corksport TIP, Turbosmart Dual Port BOV, 8000k HID Foglights,Block8head Vent pod w/52mm Prosport Boost Gauge, AWR RMM, AWR Passenger Side MM, JBR TMM, Bilstein HD Shocks Rear, Koni Sport Shocks Front, H&R Sport Springs, STI front lip, 35%Tint all around, Cobb AP, ACT 6 Puck Disc w/ ACT prolite Flywheel, Motul M300 Trans Fluid,PTP CDFP internals, Whiteline RSB, Corksport Rear Diff Mount, JDMGOODIE OEM Vent Visors, Mirimoto Mini HD Bixenon Projectors, ETS TMIC, Tuned by boost_creep ...
Tune in progress 8)
im on my way
h
stuntz89 is offline   Reply With Quote
The Following 3 Users Say Thank You to stuntz89 For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f493/new-jbr-mazdaspeed-6-side-mounts-coming-136508/
SURE vs AWR Pass side MM - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 04-24-2013 02:37 PM
Prepping as dedicated track car - Page 33 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-01-2013 04:40 PM
JBR Mazda 3 and MAZDASPEED 3 Passenger Side Motor Mounts in Stock!! JBR JAMES BARONE RACING 20 03-27-2015 07:42 AM
JBR side mounts topher3134 Gen2 MS3 General Discussion 15 08-25-2011 07:37 PM
CP-E Released driver-side/passenger-side Engine mounts for the GenPu AZRushki 2010 MS3 - Engine, Transmission & Driveline 19 06-10-2011 09:48 AM
Page generated in 0.61017 seconds with 44 queries
