Like Tree18Likes
 Old 08-27-2014, 05:15 PM   #1
Arrow New Product RE-RELEASE! JBR TRU - 3.0 and 3.5” Wide Path Intake Systems!!
Details:
The New JBR TRU-3.0 & 3.5” Wide Path Full Intake Systems are the only True 3” intake systems that extend from the MAF housing all the way to the transition at the turbo. Currently, all one piece metal intakes that are available from our competitors are 2.87” or 3.37"and all the other aluminum intakes that include a separate billet MAF housing start out at 3” but then quickly neck down to 2.87”. Our one piece design eliminates the need for unnecessary couplers and the joining of multiple sections that increase turbulence and friction which ultimately leads to reduced airflow. The thick, 5-ply, wire reinforced high temperature silicone construction is far superior at insulating the intake air from extreme engine temperatures. This translates in to lower boost air temperatures and more horsepower that no other aluminum intake can accomplish.
Every TRU-3.0 & 3.5" MAF housing has been machined from 6061-T6 to tolerances of +/-.001 and include a factory style air straightener for the most accurate signal to the MAF sensor. The air straightener is integrated in to the wall of the housing eliminating any reduction in ID like those that use honeycomb straighteners. There’s also no way for the straighener to come loose and be sucked in to the turbo like those that use pressed in blades. Our MAF housings are the lightest in the industry weighing in at only 9.1-9.8oz. The lighter housing significantly reduces heat soak, sheds heat quicker which lowers intake temperatures creating more power. Each MAF housing is beautifully anodized for a smooth, long lasting finish resistant to corrosion, even when subjected to the harshest environmental conditions.
All Tru Wide Path Intakes now include a 3.25” or 3.75” Dry-Flow air filter. JBR Dry Flow air filters flow 200% more air than the factory filter while providing superior engine protection. It uses both depth loading, capable of removing extremely fine particles (down to < 0.1 micron), and structural screen wire to enhance airflow capabilities. This design results in a performance air filter capable of increasing horsepower and torque! The three-dimensional synthetic filtering medium is washable and requires no oiling for years of trouble free service.
The Wide Path Full Intake system is designed to be run in recirc mode but, includes a plug for easy conversion to non-recir mode.
Includes:
  • Tru-3.0 or 3.5 Silicone Intake System and Billet Aluminum (3.0” ID or 3.5”) MAF Housing
  • Stainless T-Bolt Clamps
  • Plug to run in non-recirc mode
  • 3.25 or 3.75 Dry-Flow Filter (Washable uses No Oil)
rfinkle2 and BruhhWill like this.
The Following 20 Users Say Thank You to JBR For This Useful Post:
aromig (06-11-2016), BruhhWill (08-28-2014), Chief_Wiggum (08-27-2014), Code Monkey (08-27-2014), GARRETHEXTREME (08-27-2014), Hush (08-27-2014), Jeremy M (09-02-2014), Johnasaurus (08-29-2014), Johnny_Law (08-27-2014), Lex (08-28-2014), Mike@Stratified (08-28-2014), Pointless (09-16-2014), rfinkle2 (10-01-2014), season_of_ages (08-27-2014), SpeedRebirth (08-27-2014), SpeedThrizzle (08-28-2014), trancehead (09-04-2014), Voltwings (09-16-2014), YABBAMZR (09-07-2014), [R]usty (08-27-2014)
 Old 08-27-2014, 05:20 PM   #2
[R]usty's Avatar
Posts: 2,204   (View Stats)
Perfect timing, I was looking into upgrading to a 3" intake today. I'll be picking up one of these soon! Good stuff Jamie!
2010 Mazdaspeed3 w/tech
JBR (08-27-2014)
 Old 08-27-2014, 10:31 PM   #3
xliquidx's Avatar
Posts: 170   (View Stats)
xliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the world
Out of interest, is the old wide path maf housing made of the same material?
xliquidx is offline   Reply With Quote
 Old 08-28-2014, 06:28 AM   #4
No. Like other big intakes currently available it was made out of either 2.87" ID or 3.37" ID aluminum tube. They are now machined out of billet aluminum and have a an actual 3" or 3.5" ID from the inlet of the MAF and it continues all the way to the transition at the turbo.
Mauro_Penguin (09-02-2014)
 Old 09-06-2014, 02:45 PM   #5
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
So the difference between the Tru-3" WP and the previous 3" WP is only the MAF housing or are there differences in the silicone tubing as well? Basically I want to know if I can pair a Tru 3" WP with a GTX30 turbo.
I ordered a 3.0" IAS GT WP after I came across this thread a few days ago, but I now realize I just made a mistake.
The silicon is different as well.
mituc (09-06-2014)
 Old 09-06-2014, 02:49 PM   #6
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Yeah, asked a 3rd party to place the order for me, so I contacted them to place the order directly on the JBR site when they will get to that, so it's fixed.
And yes, according to the JBR site these intakes can be paired with GT turbos. Looks like I will finally move to a 3" intake, and I'll try to hack the CS air box to make all work together
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 09-06-2014, 03:48 PM   #7
08.5MS3's Avatar
Groans: 89
Why not move to a 3.5"?
 Old 08-27-2014, 10:54 PM   #8
Josegarcia020's Avatar
Posts: 177   (View Stats)
Josegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant future
You guys never cease to amaze!!
Josegarcia020 is offline   Reply With Quote
 Old 08-28-2014, 02:06 AM   #9
KCi
KCi's Avatar
Posts: 93   (View Stats)
Still no love for GT turbo 3" inlet. Please make one!
The Following 3 Users Say Thank You to KCi For This Useful Post:
Code Monkey (08-28-2014), Mauro_Penguin (08-28-2014), mituc (09-06-2014)
 Old 08-28-2014, 03:24 AM   #10
yourname2221's Avatar
Posts: 224   (View Stats)
yourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the world
I believe this is what I was sent just recently since I had waited for a redesign. Looks awesome, is there any improvement in fitment around the battery/ecu?
Installed: JBR SSP/RMM/RSB
Cobb APv3/EBCS
AT Internals
Bilstein Coilovers
SPC arms
UR
TP/DP
BNR S4, JBR Undermount w/TR8, 3.5" intake
OBX CBE
For dat racecar: Gold Caliper Paint
yourname2221 is offline   Reply With Quote
 Old 08-28-2014, 06:18 AM   #11
3" requires the outer ecu cover to be removed. 3.5" needs a battery box.
Last edited by JBR; 08-28-2014 at 06:19 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-28-2014, 11:28 AM   #12
[R]usty's Avatar
I'm excited to buy this. @Lex; I'll be purchasing a top up map once I get this and an EBCS installed.
JBR likes this.
JBR (09-03-2014), Lex (08-29-2014)
 Old 09-02-2014, 04:54 PM   #13
[R]usty's Avatar
Ordered! Can't wait to install!
JBR likes this.
JBR (09-03-2014)
 Old 09-02-2014, 08:17 PM   #14
igve2shtz's Avatar
Posts: 72   (View Stats)
igve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant future
Son of a b&#^@. I just ordered a WP 3" from RPM yesterday. Never even saw this was offered.
2006 MS6 Velocity Red Mica
SP63 built motor - SP63 9.5:1 Pistons - Manley Rods - JBR TRU-3" intake - BNR S3 - ETS 3.25" TMIC - Cobb XLE BPV - SP63 IM Port n' Polish - JBR TB TIG - JBR IM TIG - 3 Bar PnP (RPM) MAP - Autotech HPFP Internals - cp-e SafeSeals - NGK Plugs - Streetlite Flywheel - ACT 6 Puck Clutch - GrimmSpeed EBC - BSD - cp-e Catted Downpipe - Magnaflow CBE - cp-e RDM - cp-e Motor Mount - BC Coilovers - 215/45/18 Kuhmo 4x All-Season - Cobb Accessport V2- Prosport Premium Boost Gauge - Vent Pod - Dashhawk - Audiolink iPod Adapter
igve2shtz is offline   Reply With Quote
 Old 09-03-2014, 06:13 AM   #15
The MAF calibration for the New JBR TRU 3" intake can now be found here.
@igve2shtz; You WILL be receiving this new TRU intake. RPM has not updated their site yet.
-Jamie
Code Monkey and MOCO MS3 like this.
Code Monkey (09-04-2014), MOCO MS3 (09-03-2014)
 Old 09-03-2014, 06:40 AM   #16
igve2shtz's Avatar
-Jamie
This is fantastic. You guys [JBR] are amazing!
JBR likes this.
The Following User Says Thank You to igve2shtz For This Useful Post:
JBR (09-04-2014)
 Old 09-03-2014, 09:11 AM   #17
thepatient77's Avatar
Posts: 162   (View Stats)
thepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond repute
GJ @jbarone; It was worth the wait to get the new revision!!! Thanks!
JBR likes this.
thepatient77 is offline   Reply With Quote
The Following User Says Thank You to thepatient77 For This Useful Post:
JBR (09-04-2014)
 Old 09-03-2014, 09:56 AM   #18
MOCO MS3's Avatar
Posts: 644   (View Stats)
-Jamie
I was going to ask you if you got this done. You were running the new intake @ Mid-Ohio on Monday, right? I forgot about that until now!
Jamie can truly say that this product, along with everything else on his car was track tested, as he did a great job @ Mid-Ohio on Monday. Even got to work with Mazda Factory Driver and SpeedSource P2 Driver Tom Long..........Spec MIata is on the horizon!
JBR likes this.
JBR (09-04-2014)
 Old 09-04-2014, 07:22 AM   #19
King Scumbag's Avatar
Posts: 2,384   (View Stats)
I like that you grooved the MAF housing on the ends. Was having a battle with keeping the filter on the older MAF housing for a while.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
 Old 09-04-2014, 08:11 AM   #20
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
@jbarone;
What size is the inlet on the new Tru 3.5 WP?
Would love to get this intake for my upcoming BNR
2012 Velocity Red Mica
 Old 09-04-2014, 08:20 AM   #21
Originally Posted by Dimenus View Post
@jbarone;
It fits the new BNR, @Mike@Stratified; has confirmed that it fits. It's tight but it does fit.
Dimenus (09-04-2014), igve2shtz (09-05-2014)
 Old 09-04-2014, 08:22 AM   #22
For what it's worth I've instqlled the previous 3.5 silicone WP on the new BNR as well with minimal problems.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
The Following 2 Users Say Thank You to King Scumbag For This Useful Post:
Cevaes_64 (09-04-2014), Dimenus (09-04-2014)
 Old 09-04-2014, 08:45 AM   #23
Cevaes_64's Avatar
Posts: 1,066   (View Stats)
I have always had JBR intakes, TOP NOTCH PARTS, when i went BNR i went HTP... and have had a leak since then where the intake meets the turbo IDK if i received the wrong coupler but it fits... i love the one piece intakes, i ordered a new and stronger coupler from ebay if that doesnt solve it, i will be selling my HTP and getting this.
The Following User Says Thank You to Cevaes_64 For This Useful Post:
JBR (09-04-2014)
 Old 09-06-2014, 08:35 AM   #24
Atomic41's Avatar
Posts: 1,174   (View Stats)
Must I change my CPE CAI to this ... or the gain will be minimal ...
CAI vs Shortram ... CAI doesn't have the advantage over a shortram system ???
@jbarone;
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
 Old 09-06-2014, 12:59 PM   #25
GARRETHEXTREME's Avatar
Posts: 516   (View Stats)
GARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the world
No it doesn't have any advantage. Go with any SRI, it's better hands down.
TAPPPPPin
2008.5 Mazdaspeed3 GT
MODS:
ETS TMIC - Forge BPV - JBR Tru 3in Intake - JBR Boost/Bypass Hoses - Koni Yellows - Corksport CBE/Corksport Racepipe - Front Corksport FSB (Thanks Previous Owner) - JBR RSB - JBR STS/Heavy Weight Knob - Corksport Aluminum Skid Plate - JBR 88a RMM - Corksport LED Light Kit - Goodridge Braided SS Brake Lines - COBB AP - Corksport HPFP
Running on Freektune OTS+ Map
Possibly the first deaf MS3 owner here? hmmm...
GARRETHEXTREME is offline   Reply With Quote
 Old 09-07-2014, 01:43 AM   #26
sidekick's Avatar
Posts: 3,093   (View Stats)
Is the new MAF housing compatible with the previous silicone 3" intakes? And is there any reason to upgrade? I take it there is not any huge difference, but this one sure looks nice.
 Old 09-07-2014, 11:11 AM   #27
No, the new 3" will not fit the precious WP silicone.
And yes, we're seeing a noticeable difference in performance and with the tuning too.
@mituc; well put.
-Jamie
IMASA (09-07-2014), Mauro_Penguin (09-07-2014), mituc (09-07-2014)
 Old 09-09-2014, 12:04 AM   #28
Sinister_Speed3's Avatar
Posts: 180   (View Stats)
@mituc; well put.
-Jamie
Will the 3" fit the BNR S3v2 or just the 3.5" @jbarone;?
bonus season is near
Thanks
Sinister_Speed3 is offline   Reply With Quote
 Old 09-09-2014, 08:23 AM   #29
igve2shtz's Avatar
Thanks
Post #20 above from jbarone states that the Tru intakes will fit the BNR.
As he says, "It fits the new BNR, @Mike@Stratified; has confirmed that it fits. It's tight but it does fit"
Either the 3" or the 3.5" will fit, but you must order the OEM Turbo Inlet option (~2.25"). The BNR turbo inlet is about 2.5" so it just has to be stretched. The 3" or 3.5" option only refers to the size of the MAF housing.
 Old 09-08-2014, 02:40 AM   #30
mituc's Avatar
Groans: 111
I bit the bullet and ordered. I can't wait to see the differences as well as what I need to fabricate to pair this with the CS air box. I have a feeling that everything is going to be great on the intake side (less the airbox hacking which may need a new top and has nothing to do with the quality of the actual parts).
Mauro_Penguin (09-09-2014)
 Old 09-09-2014, 12:07 AM   #31
xliquidx's Avatar
I can't imagine true 3.5" versus the old 3.37 or whatever it was would make a lot of difference for smaller turbos like the bnr as it will run out of puff. Maybe high fueling e85 guys will benefit but is there really that much more flow available from the bnr?
 Old 09-09-2014, 08:54 AM   #32
Can't see it on the webpage but I assume that the new intakes (just like the old ones) come with a "mounting clamp" that we are supposed to secure to the stock mounting location on the side of the engine? This will not work on the MS6 with a BNR as the BNR is a bit wider than the k04 and pushes the intake out toward the driver side -- as pictured here, I used the mounting clamp on the filter and zip tied the intake to the bottom of the fuse box. This works but I cannot run a bigger filter, I used to run an AEM 7" dryflow, now it is no go.
 Old 09-11-2014, 09:38 AM   #33
The MAF calibration of the TRU 3.5" intake has been added HERE.
Thanks for all the orders for these new intakes as well. They have flown off the shelves and we're back to making more. Only a few left.
-Jamie
Gr8Speed (09-11-2014), JgamB (09-11-2014), Mauro_Penguin (09-11-2014), rfinkle2 (10-01-2014)
 Old 09-16-2014, 06:48 AM   #34
Atomic41's Avatar
My mechanic guy said i waste my money to change my cpe cai to the full 3" intake because my stock turbo can't take more air that he do right now and my cpe cai is already giving way to much ... for the K04
What you think about this ???
 Old 09-16-2014, 07:06 AM   #35
08.5MS3's Avatar
Groans: 89
http://stratifiedauto.com/blog/a-tec...turbocharging/
The Following 3 Users Say Thank You to 08.5MS3 For This Useful Post:
Easter Bunny (09-16-2014), JBR (09-16-2014), Mauro_Penguin (09-16-2014)
 Old 09-16-2014, 08:49 AM   #36
Atomic41's Avatar
So let's go 3.5" with a small battery box ... or it's overkill for my little K04 ?
 Old 09-16-2014, 08:52 AM   #37
A lot of guys go with the 3.5 on the k04. We sell a lot of them for the stock turbo, not over kill.
 Old 09-16-2014, 03:22 PM   #38
[R]usty's Avatar
My new intake was just delivered to my front door. Can't wait to get home!
djrich26 (12-20-2014)
 Old 09-22-2014, 10:05 AM   #39
mituc's Avatar
Groans: 111
Here's the JBR Tru 3" intake fitted with all OEM parts: OEM battery tray, OEM ECU covers, ...and the CorkSport Air Box for the Cobb SRI!
I threw the battery tray in place with the ECU still bolted to it. The tray is a bit kinked but I could screw the bolts nuts in. WIN!
I thought I was lucky, so I king of forced my luck with the tools I had. the CS air box seemed to be almost perfectly aligned with the MAF location.
We added a rubber grommet (a strut mount from a Smart ForFour) which happened to have the right inner diameter. The idea was to prevent the MAF housing from vibrating against the air box. If it's also sealing it, even better. Epic WIN!
After some time of screwing around with the air box and the air filter we test fit it. Mega WIN!! I was feeling like drinking a beer, even though I drink like 2-3 beers a year.
Time to throw the battery in and put everything together! Galactic WIN!
Job done with all parts. ...out of superlatives... no, wait: Romanian WIN!
The intake seems to be a bit kinked after the PCV feed but not by much. The air box is pushing the MAF housing against the softer part of that silicone tube, but when I will work in that area again I know what I have do to.
Also, the air filter has a larger diameter in the smaller cone area so the top of the air box is also pushing that a bit down. But that's rubber and will kink just fine.
The Stratified MAF cal is -3.1% - +1.6% in the range I logged, just like my old MAF cal for the Cobb SRI. i didn't push the car today for a WOT log because the laptop battery was almost done. Thank you @Lex and @Mike@Stratified for your work on this.
The Following 7 Users Say Thank You to mituc For This Useful Post:
aackthpt (05-10-2015), aromig (11-29-2014), JBR (09-22-2014), juxt3r (09-25-2014), Mauro_Penguin (09-22-2014), Mike@Stratified (09-23-2014), TMOtester (09-22-2014)
 Old 09-16-2014, 05:00 PM   #40
Atomic41's Avatar
Somebody try a 51R battery in Canada ...
I just want to know if the 51R battery can tough our cold winter -30 to sometimes -40.
Because maybe I wanna try 51R battery tray with a 3.5'' True intake to have the best intake possible to compare to my CPE CAI right now and see how my speed3 will answer to that modification.
Thanks for your help
P.S. Do you have recommendation for a model of 51R that better than other ?
New Product Release…JBR 3.5" Wide Path IAS Full Silicone Intake Systems for MAZDASPEED 3/6 JBR JAMES BARONE RACING 51 03-27-2014 08:12 PM
New Product Release - JBR 2.0L SkyActiv Short Ram Intake Systems For Mazda 3 and CX-5 JBR JAMES BARONE RACING 9 03-17-2014 10:16 AM
Page generated in 0.63935 seconds with 39 queries
