JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
| LinkBack | Thread Tools | Search this Thread | Display Modes |
05-29-2015, 12:57 PM | #1 |
Approved MSF Vendor Join Date: Sep 2009
Rep Power: 7119 Thanks: 7,203
(Thread Starter) | Neutral : +1 score New Product Release!! 2006-2013 MS3/6 & CX7 EGR Valve Delete Kit! The JBR EGR valve Delete Kit removes the entire EGR valve resulting in more horsepower and keeping carbon and soot build up from occurring in your DISI engine. The EGR System recirculates dirty, hot exhaust gasses back into the intake resulting in a significant build up of carbon deposits on the valves. This build up will eventually lead to a loss of compression, loss of horsepower and ultimately leading to costly and time-consuming repairs to correct the problem. By adding the *JBR EGR Valve Delete Kit and removing the EGR valve, horsepower is increased! Cooler, denser air makes more power and recirculating hot exhaust gasses back into the intake is robbing you of that power! Removing the valve also increases the space needed for going big turbo plus, it really makes for a clean looking engine build. Our EGR Valve Delete Plate is CNC machined from 1/2" 6061 aluminum and includes a brass coolant line fitting, a 304 stainless plug and all the necessary mounting hardware. Achieve the highest level of protection against carbon and soot build on your valves up by pairing the JBR EGR Valve Delete Kit with one of our Oil Catch Can Kits. Application: 2006 – 2013 Mazdaspeed 3/6 and CX7 Features:
JBR EGR Block Off Kit Includes:
*There is a possibility of an intermittent CEL from bypassing the EGR system. This will not effect engine performance or longevity. The CEL can be easily cleared with a scan tool such as the VeraTuner or the COBB AccessPORT. |
The Following 9 Users Say Thank You to JBR For This Useful Post: | Code Monkey (05-29-2015), Constantin (06-09-2015), ESA (05-31-2015), Gr8Speed (05-29-2015), Hush (06-10-2015), ItsNox (06-02-2015), Mauro_Penguin (06-03-2015), Thepedigree13 (06-02-2015), [R]usty (05-29-2015) |
05-30-2015, 01:45 AM | #2 |
Rep Power: 0 Thanks: 34
| Not Ranked : 0 score I am confused and have a noobish question about the delete kit. theres the option for the block off to be added, what is the difference between including the block off and not?
__________________ 2013 MS3 w/Tech Htp 3" one piece intake/TIP, Accesport V3, Autotech hpfp internals, JBR BSD/Baffle, JBR 88Duro Trilogy, CP-E QkSpl Catted downpipe, CP-E Triton CBE, Corksport Shortshifter |
05-30-2015, 04:07 AM | #3 |
Rep Power: 0 Thanks: 183
| Not Ranked : 0 score I just bought the "old" delete yesterday... Damnit I should have waited.
__________________ "Keep your head clear and suffer like a man" |
05-30-2015, 07:06 AM | #4 |
6 mods and some Kool-Aid Join Date: Mar 2008 Location: Jax, FL
Rep Power: 28977 Thanks: 20,271
| Not Ranked : 0 score Old method kept egr, just blocked it. This allows full removal of the Evil Gunky Reject. |
The Following 4 Users Say Thank You to Raider For This Useful Post: |
05-30-2015, 03:04 PM | #5 |
Thank you for offering the full delete option.
__________________ "Keep your head clear and suffer like a man" | |
05-30-2015, 04:06 PM | #6 |
Rep Power: 0 Thanks: 0
| Not Ranked : 0 score What took you so long...lol
__________________ __________________ 2012 Black MazdaSpeed3 Power: GTX3076R IWG / COBB EBCS / Bosch MAP Sensor Adapter Harness / Bosch 3 Bar T-MAP MAP Sensor with IAT / JBR TRU-3.5 / DM EGR Delete Kit / FORGE V1 BPV / AUTOTECH HPFP INTERNALS / UR TBE / UR DP / UR SP / NGK IRIDIUM IX / COBB SW / UR FMIC / MD OCC V1 & V2 / BrassCraft Coolant Bypass / RC IM Mani / cp-e Exi Mani / ZZB REPLACEMENT / Handling: DM TMM / DM RMM / DM PMM / JBR FSB / JBR RSB / JBR RTA / CS FEL / SPC CAMBER ARMS / BCRacing COILOVERS / GTSPEC STB /FRONT EBC YELLOWS / FRONT EBC SLOTTED ROTORS / GOODRIDGE SSL / TWM STS /RPF1 17x9 Wheels / 225/45-17 Toyo Proxes S4 / ACT ZX4-HDG6 / Extra Safety: COBB AP V3 / AEM WIDEBAND FAILSAFE (AFR) / V1 / AEM TRU BOOST / CS Skidplate / Innovate Motorsports MTX-D: Oil Pressure & Temperature / Fuel: 91 & 93 Octane / Looks: VENTPOD / JTMS3 DUAL POD / RB MUD FLAPS / Black Glossified Dipped Stock Wheels / GV OPEN MOUTH GRILL / JBR SHIFT KNOB / Black Powder Coated Front Calipers with Green MazdaSpeed Decals / Green Cabin and Trunk 8K Lights / Green Demon Headlights with black painted housing and RBG halo rings / RC signature VC / JTMS3 Stealth Sub Enclosure with a 10" JL Swallow Sub / baysonR MS-Style Lip Kit / COMING SOON AEM METH KIT / Anti Laser Priority /CS Radiator Panel / CS Rear Chassis Brace / CS Mid-Chassis Brace / CS Hood Scoop / DYNO TUNED by HYPNOTIC 93 and STREET TUNED on 91 soon e85 mix Last edited by Agent_Orange; 06-02-2015 at 11:51 AM. Reason: quoting entire OP isn't necessary |
The Following User Says Thank You to GCPhotographers For This Useful Post: | JBR (06-02-2015) |
06-02-2015, 12:19 AM | #7 |
Rep Power: 0 Thanks: 89
| Not Ranked : 0 score @jbarone; just ordered, pretty stoked and why wasn't this done from the beginning😉
__________________ Too much for you |
The Following User Says Thank You to skoski17 For This Useful Post: | JBR (06-02-2015) |
06-02-2015, 11:29 AM | #8 |
| Not Ranked : 0 score How do you guys pass emissions with the deletion of the valve? Sorry in advance if it's a stupid question. |
The Following User Says Thank You to adman98 For This Useful Post: | JBR (06-02-2015) |
06-02-2015, 12:42 PM | #9 |
Rep Power: 0 Thanks: 101
| Not Ranked : 0 score you'll need to disable the code it throws using a tuner such as the accessport
__________________ 2007 Mazdaspeed 6 GT 2003 Ford Ranger XLT |
The Following User Says Thank You to ihasmazda For This Useful Post: | JBR (06-02-2015) |
06-02-2015, 12:47 PM | #10 |
06-02-2015, 02:23 PM | #11 |
The Following User Says Thank You to JBR For This Useful Post: | skoski17 (06-02-2015) |
06-02-2015, 02:26 PM | #12 |
Completely understand just pokin the bear.
__________________ Too much for you Last edited by skoski17; 06-02-2015 at 02:26 PM. Reason: MSF Database - Automerged Doublepost | |
06-02-2015, 02:38 PM | #13 |
06-02-2015, 02:47 PM | #14 |
06-09-2015, 09:26 PM | #15 |
(Thread Starter) | Not Ranked : 0 score We did't expect these to sell so fast!! More came back from anodize today so all orders since Friday have shipped. Thanks!! |
The Following User Says Thank You to JBR For This Useful Post: | TRBLSM (06-10-2015) |
06-10-2015, 12:51 PM | #16 |
Rep Power: 0 Thanks: 6
| Not Ranked : 0 score I just ordered mine! Sent from Tapatalk
__________________ '06 Speed6 Cobb APv3 & SRI Corksport HPFP internals, downpipe (with added TurboX ceramic heat coating), Eibach's w/Koni's, TIP & BOV Rallyx'r sold: '00 Subaru 2.5RS |
The Following User Says Thank You to fornetti14 For This Useful Post: | JBR (06-10-2015) |
06-10-2015, 08:54 PM | #17 |
(Thread Starter) | Not Ranked : 0 score Thanks!! If it hasn't already shipped, it will tomorrow. |
06-11-2015, 01:03 AM | #18 |
| Not Ranked : 0 score Just some after install updates, all is well and working great. As usual, happy with the product. Not sure why, but my bolts were about 3/8" or so too long as you can see in my pic. Don't mean to blast ya in the open, just fyi. As you can see I just made due until I get around to shortening them. uploadfromtaptalk1434005863159.jpguploadfromtaptalk1434005870093.jpguploadfromtaptalk1434005892153.jpg
The Following User Says Thank You to skoski17 For This Useful Post: | JBR (06-11-2015) |
06-11-2015, 01:09 AM | #19 |
| Not Ranked : 0 score @jbarone; I'll except a meth injection kit for the excruciating back breaking labor of having to add the two nuts as reimbursement lol 😉
06-11-2015, 06:49 AM | #20 |
We'd be interested and in knowing what length bolts you have there? Anyone else run in to the this? | |
06-11-2015, 04:01 PM | #21 |
| Not Ranked : 0 score Will do as soon as I get a chance!
06-12-2015, 01:17 PM | #22 |
| Not Ranked : 0 score @jbarone; here are some pics I hope this helps. About an 1/8" too long I said 3/8" that was my bad, earlier mistake grabbing the wrong bolt lol. I posted a pic of the parts and it appears that the replacement plate is a little thinner.
06-12-2015, 01:41 PM | #23 |
(Thread Starter) | Not Ranked : 0 score I have no explanation for why yours won't thread in all the way. Our GEN 1 and GEN 2 shop cars both have these plates installed and i had no problems with the OEM bolt length. Our website report shows 1541 of these sold to date and this is the first time I've heard of this issue. The plate thickness has not changed since day one either. I'm perplexed... Again, anyone else run in to this problem? |
06-12-2015, 06:00 PM | #24 |
__________________ Too much for you | |
06-12-2015, 06:08 PM | #25 |
Is yours a 2007 built in 10/2006? Because if so, my Christine was built then, and the demon took over the being that is my car. Everything is evil on my car. True story. I bet if I had measured my egr bolts, they were short like yours. Maybe you have a demon in your car too. | |
06-12-2015, 06:15 PM | #26 |
@Raider; By the way, she's a 08
__________________ Too much for you Last edited by skoski17; 06-12-2015 at 06:15 PM. Reason: MSF Database - Automerged Doublepost | |
The Following User Says Thank You to skoski17 For This Useful Post: | Raider (06-12-2015) |
06-12-2015, 06:15 PM | #27 |
| Not Ranked : 0 score You need to do a leakdown test. |
06-12-2015, 06:16 PM | #28 |
We don't supply any bolts with that plate. Where did you get those bolts from? I thought the short one was one you cut? You're suppose to reuse the oem bolts. Now I'm super lost....Lol | |
06-12-2015, 06:27 PM | #29 |
| Not Ranked : 0 score @Raider; I know, trying to track down the tool. Its not consistent smoke, its at idle every once in a while. Its been this way every since I got her yrs ago. I did a comp. test and got 161 dry and I cant remember but I think 183 wet. Just waiting for the leak down tool. Might just buy one. Fingers are crossed when that day comes, she just turned 60k. @jbarone; I don't wanna lol
06-14-2015, 07:15 AM | #30 |
| Not Ranked : 0 score If you got your car used, it would explain the wonky bolts. Previous owner rigged it to sell. If not, weird. |
06-14-2015, 10:10 AM | #31 |
| Not Ranked : 0 score Used from a dealership, not stressing it. Just providing feed back as a good customer should
06-18-2015, 05:18 PM | #32 |
| Not Ranked : 0 score Thhought: we get the P0401 code with the secondary deleted. Is there an addition code with the primary or is it the same code?
__________________ __________________ 2012 Black MazdaSpeed3 Power: GTX3076R IWG / COBB EBCS / Bosch MAP Sensor Adapter Harness / Bosch 3 Bar T-MAP MAP Sensor with IAT / JBR TRU-3.5 / DM EGR Delete Kit / FORGE V1 BPV / AUTOTECH HPFP INTERNALS / UR TBE / UR DP / UR SP / NGK IRIDIUM IX / COBB SW / UR FMIC / MD OCC V1 & V2 / BrassCraft Coolant Bypass / RC IM Mani / cp-e Exi Mani / ZZB REPLACEMENT / Handling: DM TMM / DM RMM / DM PMM / JBR FSB / JBR RSB / JBR RTA / CS FEL / SPC CAMBER ARMS / BCRacing COILOVERS / GTSPEC STB /FRONT EBC YELLOWS / FRONT EBC SLOTTED ROTORS / GOODRIDGE SSL / TWM STS /RPF1 17x9 Wheels / 225/45-17 Toyo Proxes S4 / ACT ZX4-HDG6 / Extra Safety: COBB AP V3 / AEM WIDEBAND FAILSAFE (AFR) / V1 / AEM TRU BOOST / CS Skidplate / Innovate Motorsports MTX-D: Oil Pressure & Temperature / Fuel: 91 & 93 Octane / Looks: VENTPOD / JTMS3 DUAL POD / RB MUD FLAPS / Black Glossified Dipped Stock Wheels / GV OPEN MOUTH GRILL / JBR SHIFT KNOB / Black Powder Coated Front Calipers with Green MazdaSpeed Decals / Green Cabin and Trunk 8K Lights / Green Demon Headlights with black painted housing and RBG halo rings / RC signature VC / JTMS3 Stealth Sub Enclosure with a 10" JL Swallow Sub / baysonR MS-Style Lip Kit / COMING SOON AEM METH KIT / Anti Laser Priority /CS Radiator Panel / CS Rear Chassis Brace / CS Mid-Chassis Brace / CS Hood Scoop / DYNO TUNED by HYPNOTIC 93 and STREET TUNED on 91 soon e85 mix |
06-19-2015, 11:54 AM | #33 |
06-19-2015, 02:07 PM | #34 |
__________________ __________________ 2012 Black MazdaSpeed3 Power: GTX3076R IWG / COBB EBCS / Bosch MAP Sensor Adapter Harness / Bosch 3 Bar T-MAP MAP Sensor with IAT / JBR TRU-3.5 / DM EGR Delete Kit / FORGE V1 BPV / AUTOTECH HPFP INTERNALS / UR TBE / UR DP / UR SP / NGK IRIDIUM IX / COBB SW / UR FMIC / MD OCC V1 & V2 / BrassCraft Coolant Bypass / RC IM Mani / cp-e Exi Mani / ZZB REPLACEMENT / Handling: DM TMM / DM RMM / DM PMM / JBR FSB / JBR RSB / JBR RTA / CS FEL / SPC CAMBER ARMS / BCRacing COILOVERS / GTSPEC STB /FRONT EBC YELLOWS / FRONT EBC SLOTTED ROTORS / GOODRIDGE SSL / TWM STS /RPF1 17x9 Wheels / 225/45-17 Toyo Proxes S4 / ACT ZX4-HDG6 / Extra Safety: COBB AP V3 / AEM WIDEBAND FAILSAFE (AFR) / V1 / AEM TRU BOOST / CS Skidplate / Innovate Motorsports MTX-D: Oil Pressure & Temperature / Fuel: 91 & 93 Octane / Looks: VENTPOD / JTMS3 DUAL POD / RB MUD FLAPS / Black Glossified Dipped Stock Wheels / GV OPEN MOUTH GRILL / JBR SHIFT KNOB / Black Powder Coated Front Calipers with Green MazdaSpeed Decals / Green Cabin and Trunk 8K Lights / Green Demon Headlights with black painted housing and RBG halo rings / RC signature VC / JTMS3 Stealth Sub Enclosure with a 10" JL Swallow Sub / baysonR MS-Style Lip Kit / COMING SOON AEM METH KIT / Anti Laser Priority /CS Radiator Panel / CS Rear Chassis Brace / CS Mid-Chassis Brace / CS Hood Scoop / DYNO TUNED by HYPNOTIC 93 and STREET TUNED on 91 soon e85 mix | |
06-19-2015, 02:23 PM | #35 |
| Not Ranked : 0 score You can turn off via scan toll or Cobb. Emissions wise... you will not pass. However that goes for almost the majority of the bolt ons people perform to these cars now a days. Now if you do not have to worry about emissions, (like myself), then have at it or... do the common thing and buy buy buy and when it comes time to smog, return to stock. I am not trying to start a debate, just giving you my experience with another great product from JBR.
09-20-2015, 01:04 PM | #36 |
Rep Power: 0 Thanks: 37
| Not Ranked : 0 score What is the point in the "Coolant line plug"? i noticed your instructions for installation does not include this plug. is this for turbos that do not require water cooling?
__________________ 2010 Mazdaspeed3 Tech JBR Power Path Stage II / Double Adjustable Short Shifter / Solid Shifter Bushings Cobb Accessport v3 / XLE BPV / Cobb Knob Damond Motorsports License Plate Tow Mount / EGR Delete Ultimate Racing Test Pipe Autotech Fuel Pump Internals CP-E XFlex Stage2 RMM Stratified Stage 3 93oct OTS+ |
09-20-2015, 01:23 PM | #37 |
Rep Power: 0 Thanks: 201
| Not Ranked : 0 score I'm not sure if anyone else has experienced this, but I have an 06 ms6 and the hose coming off the egr valve ended up being too short to work with the delete. It didn't appear to to be cut but I suppose that's a possibility. I ended up running out and buying a longer hose.
__________________ -2006 Speed6- PTE5862 Tial 44mm ewg Cpe exhaust mani, Relentless PnP Intake mani Fmic w/ tr8 +All the things Tuned by: Will Dawson @Purple Drank |
09-20-2015, 01:27 PM | #38 |
__________________ 2010 Mazdaspeed3 Tech JBR Power Path Stage II / Double Adjustable Short Shifter / Solid Shifter Bushings Cobb Accessport v3 / XLE BPV / Cobb Knob Damond Motorsports License Plate Tow Mount / EGR Delete Ultimate Racing Test Pipe Autotech Fuel Pump Internals CP-E XFlex Stage2 RMM Stratified Stage 3 93oct OTS+ | |
09-20-2015, 01:29 PM | #39 |
| Not Ranked : 0 score The hose length issue may have been just my car, or maybe on other 06's. I was wondering about the little plug myself.
02-16-2017, 08:07 AM | #40 |
(Thread Starter) | Not Ranked : 0 score Plenty more of these now in stock. All back orders have shipped! |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread | Thread Starter | Forum | Replies | Last Post |
Product Release! ? CorkSport Adds Mazdaspeed 6 Rear Sway Bar to Product Line-Up | CorkSport | CorkSport | 47 | 04-22-2014 11:53 PM |
Product Release! CorkSport Oil Catch Can Development and Release Notes | CorkSport | CorkSport | 118 | 03-25-2014 05:20 PM |
Limited product release | AustinK | CorkSport | 6 | 07-24-2013 09:16 PM |
Product Release! CorkSport Lanyard | AustinK | CorkSport | 0 | 04-08-2013 12:15 PM |
