Like Tree6Likes
  • 1 Post By GCPhotographers
  • 1 Post By skoski17
  • 1 Post By ihasmazda
  • 1 Post By adman98
  • 1 Post By fornetti14
 Old 05-29-2015, 12:57 PM   #1
Arrow New Product Release!! 2006-2013 MS3/6 & CX7 EGR Valve Delete Kit!
Details:
The JBR EGR valve Delete Kit removes the entire EGR valve resulting in more horsepower and keeping carbon and soot build up from occurring in your DISI engine.
The EGR System recirculates dirty, hot exhaust gasses back into the intake resulting in a significant build up of carbon deposits on the valves. This build up will eventually lead to a loss of compression, loss of horsepower and ultimately leading to costly and time-consuming repairs to correct the problem.
By adding the *JBR EGR Valve Delete Kit and removing the EGR valve, horsepower is increased! Cooler, denser air makes more power and recirculating hot exhaust gasses back into the intake is robbing you of that power! Removing the valve also increases the space needed for going big turbo plus, it really makes for a clean looking engine build.
Our EGR Valve Delete Plate is CNC machined from 1/2" 6061 aluminum and includes a brass coolant line fitting, a 304 stainless plug and all the necessary mounting hardware.
Achieve the highest level of protection against carbon and soot build on your valves up by pairing the JBR EGR Valve Delete Kit with one of our Oil Catch Can Kits.
Application:
2006 – 2013 Mazdaspeed 3/6 and CX7
Features:
  • Designed, Engineered and Manufactured in the USA
  • Black anodized finish for long-lasting corrosion-free protection
  • Increases space for larger turbos - Simple bolt on kit
JBR EGR Block Off Kit Includes:
  • EGR valve delete plate
  • Coolant line fitting
  • Coolant line plug
  • 2, 8mm x 1.25mm bolts
  • 2, 8mm lock washers
  • 1, clamp
*There is a possibility of an intermittent CEL from bypassing the EGR system. This will not effect engine performance or longevity. The CEL can be easily cleared with a scan tool such as the VeraTuner or the COBB AccessPORT.
The Following 9 Users Say Thank You to JBR For This Useful Post:
Code Monkey (05-29-2015), Constantin (06-09-2015), ESA (05-31-2015), Gr8Speed (05-29-2015), Hush (06-10-2015), ItsNox (06-02-2015), Mauro_Penguin (06-03-2015), Thepedigree13 (06-02-2015), [R]usty (05-29-2015)
 Old 05-30-2015, 01:45 AM   #2
havocforming's Avatar
Posts: 30   (View Stats)
havocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond repute
I am confused and have a noobish question about the delete kit. theres the option for the block off to be added, what is the difference between including the block off and not?
2013 MS3 w/Tech
Htp 3" one piece intake/TIP, Accesport V3, Autotech hpfp internals, JBR BSD/Baffle, JBR 88Duro Trilogy, CP-E QkSpl Catted downpipe, CP-E Triton CBE, Corksport Shortshifter
havocforming is offline   Reply With Quote
 Old 05-30-2015, 04:07 AM   #3
Shwa's Avatar
Posts: 322   (View Stats)
I just bought the "old" delete yesterday... Damnit I should have waited.
 Old 05-30-2015, 07:06 AM   #4
Old method kept egr, just blocked it. This allows full removal of the Evil Gunky Reject.
Constantin (06-09-2015), JBR (05-30-2015), Kellerspeed3 (06-14-2015), Shwa (05-30-2015)
 Old 05-30-2015, 03:04 PM   #5
Shwa's Avatar
It is what I would have preferred to do, that's why bummer.
Thank you for offering the full delete option.
 Old 05-30-2015, 04:06 PM   #6
GCPhotographers's Avatar
Posts: 1,198   (View Stats)
What took you so long...lol
JBR likes this.
2012 Black MazdaSpeed3
Fuel: 91 & 93 Octane /
COMING SOON
Last edited by Agent_Orange; 06-02-2015 at 11:51 AM. Reason: quoting entire OP isn't necessary
JBR (06-02-2015)
 Old 06-02-2015, 12:19 AM   #7
skoski17's Avatar
Posts: 1,235   (View Stats)
@jbarone; just ordered, pretty stoked and why wasn't this done from the beginning😉
JBR likes this.
Too much for you
skoski17 is offline   Reply With Quote
The Following User Says Thank You to skoski17 For This Useful Post:
JBR (06-02-2015)
 Old 06-02-2015, 02:23 PM   #8
We've been so busy. We have a machining window so, we're wrapping back around getting to some things that are long overdue.
skoski17 (06-02-2015)
 Old 06-02-2015, 11:29 AM   #9
adman98's Avatar
Posts: 49   (View Stats)
adman98 is a name known to alladman98 is a name known to alladman98 is a name known to alladman98 is a name known to alladman98 is a name known to alladman98 is a name known to all
How do you guys pass emissions with the deletion of the valve? Sorry in advance if it's a stupid question.
adman98 is offline   Reply With Quote
The Following User Says Thank You to adman98 For This Useful Post:
JBR (06-02-2015)
 Old 06-02-2015, 12:42 PM   #10
ihasmazda's Avatar
Posts: 1,011   (View Stats)
you'll need to disable the code it throws using a tuner such as the accessport
JBR likes this.
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
The Following User Says Thank You to ihasmazda For This Useful Post:
JBR (06-02-2015)
 Old 06-02-2015, 12:47 PM   #11
adman98's Avatar
I don't have a tuner now, so I'll renew my reg this month and then get it and have a year to get a tuner. Thanks for that.
JBR likes this.
JBR (06-02-2015)
 Old 06-02-2015, 02:26 PM   #12
skoski17's Avatar
There's way around emissions 😉
Completely understand just pokin the bear.
Too much for you
Last edited by skoski17; 06-02-2015 at 02:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-02-2015, 02:38 PM   #13
adman98's Avatar
There's way around emissions ��
Don't leave me hanging with that comment.
 Old 06-02-2015, 02:47 PM   #14
skoski17's Avatar
I wouldn't do that, check your pm
Too much for you
 Old 06-09-2015, 09:26 PM   #15
We did't expect these to sell so fast!! More came back from anodize today so all orders since Friday have shipped. Thanks!!
TRBLSM (06-10-2015)
 Old 06-10-2015, 12:51 PM   #16
fornetti14's Avatar
Posts: 47   (View Stats)
fornetti14 has much to be proud offornetti14 has much to be proud offornetti14 has much to be proud offornetti14 has much to be proud offornetti14 has much to be proud offornetti14 has much to be proud offornetti14 has much to be proud offornetti14 has much to be proud offornetti14 has much to be proud of
I just ordered mine!
Sent from Tapatalk
JBR likes this.
'06 Speed6
Cobb APv3 & SRI
Corksport HPFP internals, downpipe (with added TurboX ceramic heat coating), Eibach's w/Koni's, TIP & BOV
Rallyx'r sold: '00 Subaru 2.5RS
fornetti14 is offline   Reply With Quote
The Following User Says Thank You to fornetti14 For This Useful Post:
JBR (06-10-2015)
 Old 06-10-2015, 08:54 PM   #17
Sent from Tapatalk
Thanks!! If it hasn't already shipped, it will tomorrow.
 Old 06-11-2015, 01:03 AM   #18
skoski17's Avatar
Just some after install updates, all is well and working great. As usual, happy with the product. Not sure why, but my bolts were about 3/8" or so too long as you can see in my pic. Don't mean to blast ya in the open, just fyi. As you can see I just made due until I get around to shortening them.
uploadfromtaptalk1434005863159.jpguploadfromtaptalk1434005870093.jpguploadfromtaptalk1434005892153.jpg
JBR likes this.
Too much for you
JBR (06-11-2015)
 Old 06-11-2015, 06:49 AM   #19
Attachment 203060Attachment 203061Attachment 203062
We've never seen that issue before. Those bolts should thread right in and tighten up the plate just fine.
We'd be interested and in knowing what length bolts you have there?
Anyone else run in to the this?
 Old 06-11-2015, 04:01 PM   #20
skoski17's Avatar
Will do as soon as I get a chance!
Too much for you
 Old 06-11-2015, 01:09 AM   #21
skoski17's Avatar
@jbarone; I'll except a meth injection kit for the excruciating back breaking labor of having to add the two nuts as reimbursement lol 😉
Too much for you
 Old 06-12-2015, 01:17 PM   #22
skoski17's Avatar
@jbarone; here are some pics I hope this helps. About an 1/8" too long I said 3/8" that was my bad, earlier mistake grabbing the wrong bolt lol. I posted a pic of the parts and it appears that the replacement plate is a little thinner.
Too much for you
 Old 06-12-2015, 01:41 PM   #23
I have no explanation for why yours won't thread in all the way. Our GEN 1 and GEN 2 shop cars both have these plates installed and i had no problems with the OEM bolt length. Our website report shows 1541 of these sold to date and this is the first time I've heard of this issue. The plate thickness has not changed since day one either. I'm perplexed...
Again, anyone else run in to this problem?
 Old 06-12-2015, 06:00 PM   #24
skoski17's Avatar
I have an odd ball car I guess lol its noticeably shorter in the pic, the oem bolt to the bolt you supplied. It happens, no sweat off my back just thought I would share the info. On a separate note... Any sales coming up on your meth inj. kits by chance? My bats are screaming living in a area where 103-105 is normal haha
Too much for you
 Old 06-12-2015, 06:08 PM   #25
Is yours a 2007 built in 10/2006? Because if so, my Christine was built then, and the demon took over the being that is my car. Everything is evil on my car. True story. I bet if I had measured my egr bolts, they were short like yours. Maybe you have a demon in your car too.
 Old 06-12-2015, 06:15 PM   #26
skoski17's Avatar
So far everything has been odd, I wouldn't doubt it for one second. The whole smoke out the tail pipe thing has been following me around and I took all the proper steps just to get a letter recently saying certain vin mazdas had a recall that the oil feed lines to the turbo were just slightly too big. Well, the plus is I even bought a new turbo because of the smoke. Still smoking lol Now I am making my own bolt to feed less oil. If this don't work, maybe it's part of our early bird curse. Because Racecar I guess.
@Raider; By the way, she's a 08
Too much for you
Last edited by skoski17; 06-12-2015 at 06:15 PM. Reason: MSF Database - Automerged Doublepost
Raider (06-12-2015)
 Old 06-12-2015, 06:16 PM   #27
LOL.... Wait!
We don't supply any bolts with that plate. Where did you get those bolts from? I thought the short one was one you cut? You're suppose to reuse the oem bolts. Now I'm super lost....Lol
 Old 06-12-2015, 06:15 PM   #28
You need to do a leakdown test.
 Old 06-12-2015, 06:27 PM   #29
skoski17's Avatar
@Raider; I know, trying to track down the tool. Its not consistent smoke, its at idle every once in a while. Its been this way every since I got her yrs ago. I did a comp. test and got 161 dry and I cant remember but I think 183 wet. Just waiting for the leak down tool. Might just buy one. Fingers are crossed when that day comes, she just turned 60k.
@jbarone; I don't wanna lol
Too much for you
 Old 06-14-2015, 07:15 AM   #30
If you got your car used, it would explain the wonky bolts. Previous owner rigged it to sell. If not, weird.
 Old 06-14-2015, 10:10 AM   #31
skoski17's Avatar
Used from a dealership, not stressing it. Just providing feed back as a good customer should
Too much for you
 Old 06-18-2015, 05:18 PM   #32
Thhought: we get the P0401 code with the secondary deleted. Is there an addition code with the primary or is it the same code?
COMING SOON
 Old 06-19-2015, 11:54 AM   #33
skoski17's Avatar
If it helps any... I have been running this product sense the day it was released. I have the same code and can be disabled so your cel goes away. To my knowledge, that should be the only cel that pops up however somebody correct me if I am wrong @jbarone;
Too much for you
 Old 06-19-2015, 02:07 PM   #34
It will never go away officially and if deleted or turned off officially, emissions failure is high.
COMING SOON
 Old 06-19-2015, 02:23 PM   #35
skoski17's Avatar
You can turn off via scan toll or Cobb. Emissions wise... you will not pass. However that goes for almost the majority of the bolt ons people perform to these cars now a days. Now if you do not have to worry about emissions, (like myself), then have at it or... do the common thing and buy buy buy and when it comes time to smog, return to stock. I am not trying to start a debate, just giving you my experience with another great product from JBR.
Too much for you
 Old 09-20-2015, 01:04 PM   #36
AnubisFSU's Avatar
Posts: 117   (View Stats)
AnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond repute
What is the point in the "Coolant line plug"? i noticed your instructions for installation does not include this plug. is this for turbos that do not require water cooling?
2010 Mazdaspeed3 Tech
JBR Power Path Stage II / Double Adjustable Short Shifter / Solid Shifter Bushings
Cobb Accessport v3 / XLE BPV / Cobb Knob
Damond Motorsports License Plate Tow Mount / EGR Delete
Ultimate Racing Test Pipe
Autotech Fuel Pump Internals
CP-E XFlex Stage2 RMM
Stratified Stage 3 93oct OTS+
AnubisFSU is offline   Reply With Quote
 Old 09-20-2015, 01:23 PM   #37
Stryker125's Avatar
Posts: 386   (View Stats)
Stryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the world
I'm not sure if anyone else has experienced this, but I have an 06 ms6 and the hose coming off the egr valve ended up being too short to work with the delete. It didn't appear to to be cut but I suppose that's a possibility. I ended up running out and buying a longer hose.
-2006 Speed6-
PTE5862 Tial 44mm ewg
Cpe exhaust mani, Relentless PnP Intake mani
Fmic w/ tr8
+All the things
Tuned by: Will Dawson @Purple Drank
Stryker125 is offline   Reply With Quote
 Old 09-20-2015, 01:27 PM   #38
AnubisFSU's Avatar
Just installed mine and the hose was on the shorter side but I managed to get the house on and its leak free so far. Still wondering what the plug is for though... It's not mentioned in the instructions.
 Old 09-20-2015, 01:29 PM   #39
Stryker125's Avatar
The hose length issue may have been just my car, or maybe on other 06's. I was wondering about the little plug myself.
-2006 Speed6-
Fmic w/ tr8
+All the things
 Old 02-16-2017, 08:07 AM   #40
Plenty more of these now in stock. All back orders have shipped!
Product Release! CorkSport Oil Catch Can Development and Release Notes CorkSport CorkSport 118 03-25-2014 05:20 PM
Limited product release AustinK CorkSport 6 07-24-2013 09:16 PM
Product Release! CorkSport Lanyard AustinK CorkSport 0 04-08-2013 12:15 PM
Page generated in 0.58766 seconds with 31 queries
