Like Tree20Likes
 Old 04-09-2015, 10:58 AM   #1
Default New Product Release!! 2007 - 2013 Mazdaspeed 3 Under mounted FMIC Piping Kit!!
Details:
JBR Under Mounted FMIC Piping Kit, 2007* - 2013** Mazdaspeed 3 for TreadStone TR8, TR8L or TR6 Intercoolers
The OEM top mount intercooler is sufficient for stock horsepower but, for those wanting to make more, it simply isn't capable of providing the cooling capacity necessary. To make more power, the OEM top mounted intercooler needs to be removed and replaced with a larger front mounted intercooler. The JBR Under Mounted Front Mounted Intercooler Piping Kit for the 2007 – 2013 Mazdaspeed 3 makes that possible, easily and more effectively than any other piping kit on the market.
The JBR Under Mounted Hot Side Piping Kit is designed to fit all clocked OEM/BNR and most big turbo setups.
Routing the piping beneath the motor reduces the amount of hot side charge piping by 12-16% when compared to other kits on the market. Reducing the amount of piping decreases turbo spool up time, reduces boost temperatures and makes for an impressive, almost sleeper looking engine bay.
The JBR kit is constructed from mandrel bent 6061 aluminum piping and 7 layer hi-strength thick walled silicone hoses and couplers. All of which is tucked neatly above the belly pan.
Upon exiting the intercooler, the cool boost air enters another one piece, high strength, thick walled silicone hose and travels from there, all the way to the intake manifold. Silicone has a very low heat transfer coefficient so, the hot ambient air in and around the engine bay will not be able to penetrate through all of the layers of silicone therefore, the cold air you just spent $800 to get cool, will stay cool. All other kits currently on the market have several couplers, elbows, and connections long before ever reaching the intake manifold. Not only does that make for a difficult installation but the potential for leaks is drastically increased.
Application:
2009 – 2013 Mazdaspeed 3
Best when used with a Treadstone *TR8, TR8L or **TR6 Intercooler
All kits will include coolant and vacuum hose necessary to clock your turbo.
Features:
- Designed, Engineered and Manufactured in the USA
- Black wrinkle coated aluminum piping
- Mounting bracket to secure the piping beneath the motor
- 7 layer High strength, thick walled silicone hoses and couplers
- Stainless T-bolt clamps
JBR FMIC Piping Kit Includes:
- Hot and cold side piping
- BPV Adapter flange and mounting hardware
- 8 Stainless T-bolt clamps
- 1 mounting bracket for hot side piping
- 1' of coolant hose
- 1' of vacuum hose
- Waste gate actuator & coolant Pipe mounting brackets (OEM/BNR KIT) - TR8 and TR6 Mounting Brackets* (2007 - 2009 ONLY) - Installation instructions are available in our support section
- Shipping is free in the US & our Hassle Free Lifetime Warranty is included
* 2007 - 2009 Mazdaspeed requires core mounting brackets that are included with this kit
**2010 - 2013 Mazdaspeed with TR8 intercooler requires a crash bar. 2010 - 2013 TR6 intercooler requires mounting brackets but no crash bar.
The Following 17 Users Say Thank You to JBR For This Useful Post:
Addikted To Boost (05-26-2015), A_tired_goose (05-27-2015), Benis (04-12-2015), Big_Burd (04-11-2015), chrismazda6 (04-11-2015), Code Monkey (04-10-2015), dan7225 (05-20-2015), Dralphy (05-26-2015), kpuser1 (04-11-2015), Mauro_Penguin (04-09-2015), MD1032 (04-11-2015), mituc (04-12-2015), nomorecivic! (04-11-2015), ryguy 3 (04-10-2015), SpeedRebirth (04-09-2015), trancehead (04-09-2015), [R]usty (04-09-2015)
 Old 04-09-2015, 11:07 AM   #2
stoickiwi's Avatar
Posts: 235   (View Stats)
stoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the world
That looks awesome!
So much better looking and less clutter than all those over-the-top kits.
Great work
2012 MazdaSpeed3 with Tech
Stock AF
stoickiwi is offline   Reply With Quote
 Old 04-09-2015, 12:17 PM   #3
broda's Avatar
Posts: 375   (View Stats)
I wish I had a grand to drop on getting the whole setup + crash bar. Oh well...I'll just wait for my next tax return I guess lol
JBR likes this.
The Following 2 Users Say Thank You to broda For This Useful Post:
Castillo817 (04-10-2015), JBR (04-12-2015)
 Old 04-09-2015, 12:29 PM   #4
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
Groaned at 7 Times in 4 Posts
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
The Following 2 Users Say Thank You to MazdaspeedKills For This Useful Post:
kgb (04-09-2015), Rmurray603 (04-09-2015)
 Old 04-09-2015, 12:29 PM   #5
azarashi's Avatar
Posts: 709   (View Stats)
azarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the world
Fantastic, im weird and the one reason I don't want to go FMIC yet is cause I dont like the piping going over top.
2008 Mazdaspeed 3 GT - Cobb SRI, HKS BOV, Cobb AP V2, Sure RMM, EBC Front Rotors, Hawk HPS, ROCA PMM, Yokohama YK580, SenSen Rear shocks
Planned: Cobb TIP, Autotech HPFP, MattD RMM, Koni Street Shocks/struts
azarashi is offline   Reply With Quote
 Old 04-09-2015, 12:32 PM   #6
https://www.youtube.com/watch?v=CqKqTHw0j9w
 Old 04-10-2015, 06:01 AM   #7
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Outstanding!
I'm going to go order mine right awa...... wait, what?
Really?
Oh.
<<sigh>>
Oh well.....
<sniff>
340hp / 371tq
The Following 7 Users Say Thank You to TiGraySpeed6 For This Useful Post:
ESA (05-27-2015), mride23 (05-14-2015), OsOlOcO (06-07-2015), RedDevil13 (04-12-2015), robander3 (05-26-2015), Vansquish (05-25-2015), zenit (04-12-2015)
 Old 04-10-2015, 03:02 PM   #8
GCPhotographers's Avatar
Posts: 1,198   (View Stats)
great design. it works out for those who likes to keep people in the dark about your installs
2012 Black MazdaSpeed3
Fuel: 91 & 93 Octane /
COMING SOON
 Old 04-10-2015, 06:02 PM   #9
mazdamx3freak's Avatar
Posts: 219   (View Stats)
mazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond repute
@jbarone are you still going to offer us who already purchased your fmic kit any kind of discount on the hot side piping kit?
JBR likes this.
2008.5 CPW
JBR:3.5 intake, fmic, r51 Battery Box, Ancors, EGR Delete, Thermal Spacers, 5mm Wheel spacers, Shift plate.
Matt Dimond OCC, Autotech Internals, CNT catted downpipe, itv-22, Threadstone T8L FMIC,SU Turbosmart Bpv, SUv2 Rmm
mazdamx3freak is offline   Reply With Quote
The Following User Says Thank You to mazdamx3freak For This Useful Post:
JBR (04-11-2015)
 Old 04-11-2015, 04:08 PM   #10
Certainly...we will knock $15.00 off if you've purchased a FMIC piping kit from us in the past. Email us at Jamesbaroneracing@gmail.com with your order number after you order the under mount kit and we'll issue the refund. This offer is good through the end of May.
 Old 04-11-2015, 11:56 PM   #11
manu's Avatar
Posts: 80   (View Stats)
manu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of light
Groaned at 7 Times in 5 Posts
Too bad i ve just recently got installed a front intercooler and wont be able to get this JBR one for a while ..i guess until i ll ubgrade my turbo and then i ll need a bit bigger intercooler kit to support the bigger psi ..its no doubt that this kit is a lot smarter by definition in all aspects , very good job JBR!! U guys have also the best MM kit it was well worth to take down the previous "brand" and go with the 88Duro oh yeah
manu is offline   Reply With Quote
 Old 04-12-2015, 06:58 AM   #12
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I guess this kit will work with a larger inlet turbo (4") with just an adapter. If it does this kit may risk becoming the last FMIC piping kit you will ever need.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 04-12-2015, 09:29 AM   #13
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
What does the turbo Inlet have to do with anything?
mituc (04-12-2015)
 Old 04-12-2015, 10:23 AM   #14
mituc's Avatar
Groans: 111
You are right, that's on the intake side.
 Old 05-14-2015, 11:30 AM   #15
RusianKid's Avatar
Posts: 353   (View Stats)
RusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the world
This kit sure cleans up the engine bay!
JBR likes this.
"RACING IS AN ADDICTION CURED ONLY BY POVERTY"
RusianKid is offline   Reply With Quote
The Following 10 Users Say Thank You to RusianKid For This Useful Post:
Addikted To Boost (05-26-2015), Awal (05-15-2015), A_tired_goose (05-27-2015), dan7225 (05-20-2015), G1sdaname (05-19-2015), JBR (05-14-2015), JgamB (05-17-2015), Killer95GT302 (05-14-2015), mazdaspeedmyk (05-14-2015), Murcielago311 (05-14-2015)
 Old 05-14-2015, 12:39 PM   #16
Looks so stock and sleeper too.
I was wondering when we'd see someone post. We've sold so many of these. Hope to see more.
 Old 05-14-2015, 12:44 PM   #17
Killer95GT302's Avatar
Posts: 198   (View Stats)
Killer95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond repute
Would love to have my 6 engine bay looking like that - everything so easily worked on
2006 Mazdaspeed6 - Bone Stock!
1995 Mustang GT - Turbocharged / Motor work
Killer95GT302 is offline   Reply With Quote
The Following User Says Thank You to Killer95GT302 For This Useful Post:
ESA (05-27-2015)
 Old 05-14-2015, 01:22 PM   #18
RusianKid's Avatar
Now I just need to paint the valve cover and clean my engine bay!
 Old 05-19-2015, 05:40 PM   #19
G1sdaname's Avatar
Posts: 519   (View Stats)
G1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the world
I'll be posting pictures of install, hopefully soon.
CP-E Catted TBE | COBB: AP, RMM, EBCS | AutoTech Internals | Wheels - Montegi R116
BNR3 | JBR: Tru 3.0 Intake, Under-engine FMIC piping, SSP | TR8 | TurboSmart BPV
MilTuned - e85
Next up: Make more money for Meth (2x)
-Gabe-
G1sdaname is offline   Reply With Quote
The Following User Says Thank You to G1sdaname For This Useful Post:
JBR (05-19-2015)
 Old 05-19-2015, 05:45 PM   #20
G1sdaname's Avatar
@jbarone; with BNR3 is the waste gate actuator mounting bracket needed?
MilTuned - e85
-Gabe-
 Old 05-19-2015, 08:46 PM   #21
RusianKid's Avatar
No you don't
The Following 2 Users Say Thank You to RusianKid For This Useful Post:
G1sdaname (05-19-2015), JBR (05-19-2015)
 Old 05-20-2015, 11:57 AM   #22
As mentioned The BNR S2 and S3 do not need the actuator bracket we offer. They can be clocked with actuator bracket they come with. The BNR S1 does require the bracket we offer.
-Mike
G1sdaname (05-22-2015)
 Old 05-25-2015, 11:22 AM   #23
G1sdaname's Avatar
Anyone have a picture of a clocked BNR3? The JBR instructions show a stock turbo being clocked and the small difference is throwing me off, on step 6 page 4 I can't determine if that's how it should look or if that's where I start before clocking.
This is after clocking the turbo as you can see the actuator bracket doesn't fit like this.
Here is a picture of the instructions.
This is how I figure it actually fitting, but I'm likely wrong.
MilTuned - e85
-Gabe-
 Old 05-25-2015, 12:11 PM   #24
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
SuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond repute
I am getting all excited. This is a killer set up.
2013 Genpu GT, 245/40 Direzzas, CS SRI+TIP,CS TP+CB, CS TMIC, CS FP Internals, CS 80a RMM, CS BPV, Accessport V3, Tuned by Nishan
SuckSqueezBangBlow is offline   Reply With Quote
 Old 05-25-2015, 12:32 PM   #25
shamie's Avatar
Posts: 952   (View Stats)
That would shoot it up at your windshield.
 Old 05-25-2015, 03:02 PM   #26
G1sdaname's Avatar
I'm hopeless , you are right if I picture it installed it definitely don't make sense.
Sent from my iPhone
MilTuned - e85
-Gabe-
 Old 05-25-2015, 05:45 PM   #27
RusianKid's Avatar
Sent from my iPhone
Please keep us updated on your findings.
It will make it much easier on the future clocked BNRs
The Following User Says Thank You to RusianKid For This Useful Post:
Awal (05-27-2015)
 Old 05-25-2015, 09:16 PM   #28
G1sdaname's Avatar
Found this diagram and the EM connects from top. so yes it's definitely pointing in the wrong direction.
So from the instructions it should be facing this way but the problem is the actuator bracket doesn't fit correctly.
This hole doesn't align to bolt up the bracket.
@jbarone; can you please point me in the right direction on clocking the BNR3? Thanks
Sent from my iPhone
MilTuned - e85
-Gabe-
 Old 05-25-2015, 10:28 PM   #29
G1sdaname's Avatar
Ok maybe it does fit after you start bending things.
Sent from my iPhone
MilTuned - e85
-Gabe-
The Following 3 Users Say Thank You to G1sdaname For This Useful Post:
Addikted To Boost (05-26-2015), Awal (05-27-2015), JgamB (05-29-2015)
 Old 05-26-2015, 07:48 AM   #30
^^You nailed it Sir!^^
Tweaking and adjusting the actuator arm will be necessary for the bracket to come in to place.
Awal (05-27-2015), G1sdaname (05-26-2015), RusianKid (05-26-2015)
 Old 05-26-2015, 08:27 AM   #31
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Sent from my iPhone
could you elaborate on which part of the arm you bent to make it work?
09 MGM MS3
 Old 05-26-2015, 08:57 AM   #32
G1sdaname's Avatar
I didn't bend the rod, I just placed the bolt on the right hand side of the picture and forced the bracket to be able to fit the second screw. JBarone says you can bend the rod but I haven't tried it yet. Likely need to bend the tip of the rod upwards and should give a little better clearance so it doesn't feel so forced.
Sent from my iPhone
MilTuned - e85
-Gabe-
 Old 05-26-2015, 09:13 AM   #33
This will do it.
Bend the main section of the rod up and the very end down a bit.
Addikted To Boost (05-26-2015), Awal (05-27-2015), ryguy 3 (05-26-2015)
 Old 05-26-2015, 09:16 AM   #34
Sent from my iPhone
I see, so the rod probably just twisted a little inside the WGA. Good to know thanks.
09 MGM MS3
 Old 05-26-2015, 09:24 AM   #35
You can loosen the jamb nut on the actuator rod to get the end to rotate if needed.
G1sdaname likes this.
 Old 05-26-2015, 09:26 AM   #36
RusianKid's Avatar
@jbarone;
Do you have any information on clocking the corksport turbo?
 Old 05-26-2015, 09:27 AM   #37
@jbarone;
LOL...no
I think they would be better situated to address those questions.
Mauro_Penguin (05-27-2015)
 Old 05-26-2015, 09:32 AM   #38
ahh ok thats a better solution, I'll be picking up this kit in the near future then. @jbarone; I emailed you some feedback on the regular fmic piping over the weekend.
09 MGM MS3
 Old 05-26-2015, 09:35 AM   #39
Cool!!
Yes, I've received your email. We're digging out from the holiday weekend and I will likely reply shortly.
 Old 05-26-2015, 11:27 AM   #40
RusianKid's Avatar
LOL...no
Maybe the better question is...
Do you think the Corksport turbo is compatible with your kit, but I am glad to bring humor to your day instead.
JBR (05-27-2015)
New Product Release!! Raider's Air Damn 2007 - 2009 Mazdaspeed 3 Raider JAMES BARONE RACING 67 12-29-2017 02:24 PM
New Product Release! JBR FMIC Crash Bar for 2010 - 2013 Mazdaspeed 3 JBR JAMES BARONE RACING 15 03-27-2017 08:25 AM
GI: JBR Under Mounted Hot Side Piping Kit 2007 - 2013 Mazdaspeed 3 JBR JAMES BARONE RACING 94 06-07-2016 10:00 AM
New Product Release! JBR FMIC Piping Kit, 2007 - 2009 Mazdaspeed 3 JBR JAMES BARONE RACING 13 02-08-2015 04:38 PM
New Product Release! JBR FMIC Piping Kit, 2010 - 2013 Mazdaspeed 3 JBR JAMES BARONE RACING 19 01-25-2015 09:37 PM
Page generated in 0.58719 seconds with 37 queries
