 Old 08-05-2015, 12:26 PM   #1
Arrow New Product Release!! 2013+ Focus ST Double Adjustable Front Sway Bar
Details:
The JBR Tru-Torsion Front Sway Bar Kit is one of the most effective ways to improve handling without negatively affecting ride quality or increasing NVH. It's 28.6mm in diameter and offers two settings to choose from that provide a 85% or 99% increase in stiffness to resist body-roll. The adjustability allows for fine tuning and makes this sway bar kit the perfect choice whether you’re already running a JBR Rear Sway Bar or any another manufactures bar.
The JBR Front Sway Bar Kit is CNC bent and includes stiff polyurethane bushings for instant suspension response. All of the necessary hardware is included making for a direct factory replacement while ensuring a perfect OEM-like fit. The bushing brackets also include built-in grease fittings to make maintenance quick and simple.
The JBR Front Sway Bar Kit is compatible with stock and most aftermarket end links.
Features:
  • 28.6mm diameter bar, 3.6mm larger than stock
  • 1.2lbs lighter than stock
  • (296 lbs/in & 318 lbs/in (85% & 99%) increase in roll stiffness, user adjustable
  • Stiffer polyurethane bushings and bushing brackets
The JBR Sway Bar Kit Includes:
  • JBR adjustable front sway bar
  • New bushings and brackets
  • Installation grease
Gr8Speed (08-05-2015), Mauro_Penguin (08-06-2015), [R]usty (08-05-2015)
New Product Release!! 2014+ Mazda 3, 6 and CX-5 Double Adjustable Front Sway Bar JBR JAMES BARONE RACING 1 07-31-2015 08:22 PM
New Product Release!! Mazda 3, Mazdaspeed 3 and Focus ST Adjustable Rear Toe Arms JBR JAMES BARONE RACING 1 04-29-2015 11:24 AM
New Product Release!! GEN 2 JBR MAZDASPEED 3 Adjustable Front Sway Bar JBR JAMES BARONE RACING 15 01-27-2015 05:08 PM
New Product Release - MS3 GEN 2 RHD Double Adjustable Short Shifter! Now Available JBR JAMES BARONE RACING 0 01-27-2015 01:20 PM
New Product Release!! GEN 1 JBR MAZDASPEED 3 Adjustable Front Sway Bar JBR JAMES BARONE RACING 4 08-29-2014 04:02 AM
Page generated in 0.24287 seconds with 21 queries
