 Old 10-19-2015, 11:42 AM   #1
Arrow New Product Release!! 2014 & Up CX-5 Adjustable Rear Camber Arms
Details:
Rear camber arms are often overlooked when it comes to lowering until the rear tires need to be replaced after only 10k miles. Unfortunately, the stock suspension does not allow for the necessary adjustments to correct this problem.
Adjustable Rear Camber Arms correct the additional negative camber generated when a vehicle is lowered. *Not only will they aid in camber correction but, they also allow for you to add up to +3/-2 degrees of camber for on the street or the track.
Constructed entirely from high strength 4130 molly steel tubing and reinforced with thick steel gussets to prevent any unwanted flex or stress. Fitted with chrome plated 4130 spherical rod ends with a nylon race, control and road feel is increased with no need to worry about any added noise.
Sold as a set because we know you don't want just one.
Application:
2014 and up Mazda CX-5
Features:
  • Designed, Engineered and Manufactured in the USA
  • 4130 construction
  • Powder coated for long lasting durability
JBR Rear Camber Arm Kit Includes:
  • 1 Set of Rear Adjustable Camber Arms
*Designed to work with vehicles lowered within the realistic operating limitations of the vehicle. Not designed for stancing.
Mauro_Penguin (10-20-2015)
New Product Release!! Mazda 3, Mazdaspeed 3 and Focus ST Adjustable Rear Toe Arms JBR JAMES BARONE RACING 1 04-29-2015 11:24 AM
New Product Release!! Ford Focus ST Rear Adjustable Camber Arms JBR JAMES BARONE RACING 3 04-23-2015 07:51 PM
Product Release! CorkSport Adjustable Rear Camber Arms CorkSport CorkSport 15 07-31-2012 12:30 PM
Page generated in 0.22624 seconds with 20 queries
