  • 1 Post By JBR
 Old 11-17-2015, 12:55 PM   #1
Arrow New Product Release!! - 2016 Miata (ND) Oil Catch Can Kits
We're very pleased to offer our very first product designed specifically for the 2016 Miata!!
2.0L SkyActiv Oil Catch Can Kits Special Introductory price for the first 5 adopters!
Details:
During everyday engine operation, blow-by gases, as well as oil vapor from the engines rotating assembly, pass through the PCV valve and are routed into the intake for the engine to burn off. Before ever making it into the cylinders, some of that oil mist and other contaminates adhere to the backside of the hot intake valves. Over time a thick crust forms significantly reducing performance and potentially leading to a costly cleaning or repair. This is especially a problem for the 2.0L motor because, there's no fuel (Direct Injection) passing over the valves to wash and keep them clean. This is why an OCC is a must have for any Mazda SkyActiv motor.
As the PCV gases enter the catch can a pressure drop occurs. The oil then begins to fall out of suspension as it flows through a series of 3 perforated filter plates. As the gases flow through the plates, the oil sticks and the gas is all that reaches the outlet at the top of the catch can. Oil that accumulates on the filter plates runs off and is collected in the bottom.
The catch can is conveniently mounted in the engine bay on the passenger side of the engine. The large 5/8" drain hose and easy to operate drain valve make emptying the catch can a breeze at each oil change.
Throughout the life of the catch can, no maintenance is required. The perforated filter plates will never break down, need to be cleaned or be replaced.
Application
  • 2016 Mazda MX5 2.0L SkyActiv Engine
Features:
  • Entirely constructed out of 6061 aluminum
  • Precision TIG welding of all components
  • Zero maintenance required (aside from draining)
  • Large 5/8" easily operated drain valve
Includes:
  • 1 Oil catch can
  • 101" of 3/8" polyester reinforced oil, fuel and chemical resistant hose
  • 1 Drain valve
  • 20" of 5/8" polyester reinforced oil, fuel and chemical resistant hose
  • 4 zip ties
  • 2 1/4"-20 X 1/2" stainless steel bolts
  • 2 1/4"-20 Nylon insert lock nuts
  • 1 3/8"-16 x 1/2" hex Bolt - 1 3/8" lock washer - 2 Mounting brackets
Mauro_Penguin likes this.
Mauro_Penguin (11-18-2015), Raider (11-17-2015)
New Product Re-Release!! FST and MS3/6 Oil Catch Can Kits JBR JAMES BARONE RACING 17 01-16-2017 07:28 AM
New Product Release!! SKYACTIV 2.0 and 2.5L Oil Catch Can Kits!! JBR JAMES BARONE RACING 0 06-11-2015 02:41 PM
New Product Release!! Ford Focus ST Mud Flap Kits JBR JAMES BARONE RACING 0 05-11-2015 12:41 PM
Product Release ? SkyActiv Aluminum Oil Catch Can CorkSport CorkSport 0 05-14-2014 05:10 PM
Product Release! CorkSport Oil Catch Can Development and Release Notes CorkSport CorkSport 118 03-25-2014 05:20 PM
Page generated in 0.24081 seconds with 20 queries
