  • 1 Post By Cheapspeed
 Old 10-09-2015, 02:59 PM   #1
Arrow New Product Release!! Focus ST Hot & Cold - METH, TIAL & HKS Charge Pipes
COLD SIDE CHARGE PIPES
Details:
The JBR Cold Side Charge Pipe Kits for the Ford focus ST are constructed out of 2.5" mandrel bent aluminum. They ALL incorporate a 1/8" NPT bung for methanol injection and CNC machined flange for either a TIAL or HKS blow off valve. Whether you’re looking to lower charge temps, decrease knock and add timing through the use of meth injection, upgrading your turbo to one without in internal bypass valve or you just want that distinctive sound of a external blow off valve, we've designed kits that included everything to simply and easily get the job done.
The increased diameter and smoother radius tubing of the JBR kits allow for the cold air exiting the intercooler to make its way to the engine faster and more efficiently than the OEM piping.
Making the connections are our custom, 5-ply reinforced silicone couplers. These couplers will not expand under boost and are fuel and oil resistant. Keeping the couplers and piping firmly in place, we've included 19mm wide stainless T-bolt clamps.
The end results are a suite of kits that look, fit and most importantly...Perform!!
Fitment:
  • Direct OEM replacement
  • Fits all aftermarket turbos and intercoolers that are direct OEM emplacements
Features:
  • Increased air flow
  • Meth injection ready
  • Lower charge temps
Includes:
  • 1 Cold side charge pipe with a TIAL or HKS flange & meth injector bung
  • All necessary components to block and eliminate the OEM bypass valve
  • 2 silicone couplers
  • 3' of silicone vacuum tubing
  • 4 stainless T-bolt clamps
  • 1 TIAL or HKS BOV (optional)
HOT SIDE CHARGE PIPES
Details:
The JBR Hot Side Charge Pipe Kit for the Ford focus ST is constructed out of 2.5" mandrel bent aluminum. We used up all the available space and created a hot side charge pipe that increases the diameter by 26% over the OEM. This translates into a significant increase in air flow to get that hot air exiting the turbo to the intercooler faster and cooled quicker.
Like our cold side kits, the connections made using our custom, 5-ply reinforced silicone couplers. These couplers will not expand under boost and are fuel and oil resistant. Keeping the couplers and piping firmly in place, we've included 19mm wide stainless T-bolt clamps.
Fitment:
Features:
  • Increased Air Flow
Includes:
  • 1 Hot side charge pipe
Gr8Speed (10-09-2015), Mauro_Penguin (10-09-2015)
 Old 10-10-2015, 06:25 AM   #2
EnixStorm's Avatar
Posts: 108   (View Stats)
EnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond repute
Groaned at 3 Times in 1 Post
Question... How does this help us?
Cobb SRI :|: Cobb TIP :|: CPE Stg 2 RMM :|: JBR 70 PMM :|: AutoTech Internals :|: AP V3
EnixStorm is offline   Reply With Quote
 Old 10-10-2015, 07:51 AM   #3
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
There are ST owners on this site too. We have an Ecoboost subforum.
JBR likes this.
JBR (10-10-2015)
 Old 10-10-2015, 07:55 AM   #4
EnixStorm's Avatar
Yea but we Mazda owners want more parts too!!
 Old 10-16-2015, 10:28 AM   #5
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
I mean, based on your signature JBR offers a ton of modifications that you currently don't have. Start with the old before asking for the new .
 Old 10-16-2015, 11:05 AM   #6
EnixStorm's Avatar
Well my signature is a bit old... But I'm pretty much fully bolted besides this little k04
Still deciding on what to upgrade to... I've always like the gt28 series because turbo lag is upsetting on 30+
Did JBR ever put out that FMM? It wasn't cost effective? Haven't kept up on that...
*forgot to mention signatures don't even show up in forum runner :/
New Product Release!! MS3/6 and Focus ST Throttle Body Meth Injection Spacer JBR JAMES BARONE RACING 62 06-04-2015 11:11 AM
New Product Release!! Ford Focus ST Mud Flap Kits JBR JAMES BARONE RACING 0 05-11-2015 12:41 PM
New Product Release!! Ford Focus ST Rear Adjustable Camber Arms JBR JAMES BARONE RACING 3 04-23-2015 07:51 PM
Product Release! CorkSport Mazda 2 Cold Air Duct CorkSport CorkSport 4 09-17-2012 11:53 AM
Product Release! CorkSport Cold Air Intake for the 2010+ Mazdaspeed 3 CorkSport CorkSport 26 09-08-2012 09:14 PM
Page generated in 0.28365 seconds with 23 queries
