  • 2 Post By JBR
 Old 08-12-2014, 01:19 PM   #1
Default New Product Release!! GEN 1 JBR MAZDASPEED 3 Adjustable Front Sway Bar
Details:
The JBR Tru-Torsion Front Sway Bar Kit is one of the most effective ways to improve handling without negatively affecting ride quality or increasing NVH. It's 28.6mm in diameter and offers two settings to choose from that provide a 35% or 55% increase in stiffness to resist body-roll. The adjustability allows for fine tuning and makes this sway bar kit the perfect choice whether you’re already running a JBR Rear Sway Bar or any another manufactures bar.
The JBR Front Sway Bar Kit is CNC bent and includes stiff polyurethane bushings for instant suspension response. All of the necessary hardware is included making for a direct factory replacement while ensuring a perfect OEM-like fit. The bushing brackets also include built-in grease fittings to make maintenance quick and simple.
The JBR Front Sway Bar Kit is compatible with stock and most aftermarket end links.
Features:
-28.6mm diameter bar, 2.6mm larger than stock
-6lbs lighter than stock
-35% - 55% increase in roll stiffness, user adjustable
-Stiffer polyurethane bushings and bushing brackets
-CNC bent for perfect fitment
-Easy to maintain with built-in grease fittings
The JBR Sway Bar Kit Includes:
-JBR adjustable front sway bar
-All necessary installation hardware and installation grease
-Installation instructions are available in our support section
-Shipping is free in the US & our Hassle Free Lifetime Warranty is included
Mauro_Penguin and MOCO MS3 like this.
The Following 15 Users Say Thank You to JBR For This Useful Post:
allo80 (08-13-2014), BruhhWill (08-18-2014), Code Monkey (08-12-2014), Cyclops (08-12-2014), jack_hammer (01-27-2015), Jtaylor (08-12-2014), justint5387 (08-20-2014), King Scumbag (08-13-2014), LatinKraze (08-12-2014), Mauro_Penguin (08-12-2014), roguemazda (08-12-2014), rolanblack (08-28-2014), ryno077 (08-18-2014), speed_freak91 (08-19-2014), taf0422 (08-12-2014)
 Old 08-18-2014, 07:26 PM   #2
getemslough's Avatar
Posts: 163   (View Stats)
getemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the world
want.
---2009 CWP---ATP GTX2867r---COBB AP V3---CS HPFP---CS BERYLLIUM/COPPER INJECTOR SEALS---SELF PORTED INTAKE MANIFOLD---CS 3.5 SRI---
---PROTOTYPE XSPOWER V3 IWG MANIFOLD (BETA TESTER)---CS CATTED DP---CNT CATBACK---RPM/CX FMIC PIPING---TREADSTONE TR8---
---GRIMMSPEED 3 PORT EBCS---3BAR MAP/RPM HARNESS---NGK 6510---JBR 51R TRAY---3P/HKS SSQV IV---CS RECIRC TUBE---KOZMIC OIL DRAIN---KOZMIC EGR DELETES---
---JBR TB/IM TIGS---CS PMM---CS RMM---CS OCC---CS SKID PLATE---
---CS STEERING WHEEL---CS SHIFTER BUSHINGS---SURE SHORTCUT---JBR SHORT SHIFT LEVER---SURE AGS 621g---SURE AGS EXTENDER---
---KONI STR.T---H&R SPRINGS---PROGRESS RSB---MOOG ENDLINKS---17X9+45 RPF1---5MMSPACERS---255/40/17 NITTO NT555---JBR FLAPS---
--GTX BUILD COMPLETE--
--FREEKTUNE 383/404 ON PUMP--
--METH COMING SOON--
getemslough is offline   Reply With Quote
 Old 08-19-2014, 08:05 AM   #3
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Will be buying within the next week. Let's add some more JBR parts! Lol
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
JBR (08-25-2014)
 Old 08-28-2014, 09:57 PM   #4
rolanblack's Avatar
Posts: 2,110   (View Stats)
Has anyone install his sway bar yet? We need reviews!!!!
 Old 08-29-2014, 04:02 AM   #5
Johnasaurus's Avatar
Posts: 359   (View Stats)
Johnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the world
Gen2?
2012 black mica. Totaled 10/31/14.
Johnasaurus is offline   Reply With Quote
New Product Release!! GEN 2 JBR MAZDASPEED 3 Adjustable Front Sway Bar JBR JAMES BARONE RACING 15 01-27-2015 05:08 PM
Product Release: CorkSport Adjustable Shortshifter For Mazdaspeed 3 CorkSport CorkSport 174 09-12-2014 07:51 AM
Product Release! CorkSport Mazdaspeed 6 Front Sway Bar CorkSport CorkSport 0 08-30-2012 12:10 PM
Product Release! CorkSport Mazda 2 Front Sway Bar CorkSport CorkSport 0 11-07-2011 11:00 AM
Page generated in 0.27022 seconds with 24 queries
