  • 1 Post By
  • 1 Post By
 Old 01-27-2015, 05:08 PM   #1
allo80's Avatar
Posts: 46   (View Stats)
allo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud of
Originally Posted by foodtime View Post
Installed this sway bar this weekend. Wasn't too bad unless you didn't have some set backs as me.
Set back #1 : wrong direction the bar itself was put into the car. I was so excited to get the bar out of the car that I didn't notice how the bar was facing. Make sure bar ends where endlinks attached to face downward. (I put the bar in backwards, had to remove once more, than insert it back into the car. Jack stand space was a hard to work with)
Set back #2 : I ensure I centered the whole bar but the end of it were rubbing against the tire rod on passenger side. You can see the rubbing line where I'm pointing. I pushed the bar as back as i can with the adjustable bracket. I decided to shave some of the tip of the sway bar. End result left a good 1/2 in away from the tire rod with no rubbing.
Performance is good but nothing compared to the rear sway bar JBR provided. I place end links into the stiffest position. I'm going to put the rears on stiffest as well. Let see how this works out with autocross next weekend.
How has the bar holding up? Any feedback?
allo80 is offline   Reply With Quote
Product Release: CorkSport Adjustable Shortshifter For Mazdaspeed 3 CorkSport CorkSport 174 09-12-2014 07:51 AM
Product Release! CorkSport Mazdaspeed 3 Front Camber Kit CorkSport CorkSport 3 07-03-2013 01:08 PM
Product Release! CorkSport Mazdaspeed 6 Front Sway Bar CorkSport CorkSport 0 08-30-2012 12:10 PM
Product Release! CorkSport Mazda 2 Front Sway Bar CorkSport CorkSport 0 11-07-2011 11:00 AM
Page generated in 0.24926 seconds with 22 queries
