  • 1 Post By JBR
  • 1 Post By JBR
 Old 03-12-2014, 05:15 PM   #1
Arrow New Product Release - JBR 2.0L SkyActiv Short Ram Intake Systems For Mazda 3 and CX-5
Details
The JBR Power Path Short Ram Intake kit is where the path to making more power begins for your SkyActiv Mazda. The JBR SRI is a complete replacement for the restrictive factory intake hose and air filter box netting gains of 6hp and 7lb/ft of torque . Simple to install and no ECU tuning is required.
Every MAF housing is machined from 6061 aluminum to tolerances of +/-.001" of spec. We’ve also gone a step further and added an air straightener to the housing which the factory air box does not have. This creates more laminar airflow therefore increasing sensor resolution for the most accurate signal from the MAF sensor to the ECU.
Our MAF housings are the lightest in the industry weighing in at only 9.6oz. The lighter housing significantly reduces heat soak and sheds heat quicker lowering intake temperatures creating more power. Each MAF housing is beautifully anodized for a smooth, long lasting finish resistant to corrosion, even when subjected to the harshest environmental conditions.
Our custom 6 ply polyester reinforced silicone intake hose eliminates the turbulence caused by the factory accordion rubber hose delivering smooth, oxygen rich air directly in to your engine. Our silicone is installed using wide stainless T-bolt clamps, not weak worm gear clamps to ensure a leak free seal.
Every Power Path Short Ram Intake includes a Dry-Flow air filter. JBR Dry Flow air filters flow 200% more air than the factory filter while providing superior engine protection. It uses both depth loading, capable of removing extremely fine particles (down to 0.1 micron), and structural screen wire to enhance airflow capabilities. This design results in a performance air filter capable of increasing horsepower and torque! The three-dimensional synthetic filtering medium is washable and requires no oiling for years of trouble free service.
Includes:
  • Precision Machined MAF Housing with air straightener
  • Reinforced Hi-Temperature Silicone Intake Hose
  • Stainless Steel T-Bolt Clamps
  • DRY Flow Air Filter
  • NO CEL Guarantee
Rokusek likes this.
Chief_Wiggum (03-12-2014), cthomp (03-12-2014), King Scumbag (03-12-2014), Rokusek (03-14-2014)
 Old 03-12-2014, 05:28 PM   #2
865ms3's Avatar
Posts: 2,602   (View Stats)
looks like my wife's CX5 can be a JBR whore just like my speed now.
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
 Old 03-12-2014, 07:15 PM   #3
darthxar's Avatar
Posts: 560   (View Stats)
darthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the world
My wife's cx-5 also needs one of these.
Double tappin' the Moto
2013 VRM MS3
darthxar is offline   Reply With Quote
The Following User Says Thank You to darthxar For This Useful Post:
865ms3 (03-12-2014)
 Old 03-12-2014, 07:09 PM   #4
King Scumbag's Avatar
Posts: 2,384   (View Stats)
Keep em coming @jbarone;!
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
 Old 03-12-2014, 08:35 PM   #5
Liquid silver and it's really cool looking. Nothing like it anywhere!
King Scumbag likes this.
 Old 03-12-2014, 09:16 PM   #6
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Felt like I entered rave or something.
 Old 03-13-2014, 10:34 AM   #7
swsmailman's Avatar
Posts: 1,118   (View Stats)
Nice, love the music, I know the song but can't remember the name of it.
The SO is either going to get a CX5 or a BRZ someday.... She is all about the BRZ for some reason, but if she gets a CX5 then looks like it will also get a JBR treatment on it.
2013 Liquid Silver MazdaSpeed
 Old 03-14-2014, 06:54 AM   #8
Ministry of Sound - Spaceman (The Sound of Trap Edit) (Carnage Festival Trap Remix)
 Old 03-14-2014, 08:51 PM   #9
Johnny_Law's Avatar
Posts: 194   (View Stats)
Johnny_Law has a reputation beyond reputeJohnny_Law has a reputation beyond reputeJohnny_Law has a reputation beyond reputeJohnny_Law has a reputation beyond reputeJohnny_Law has a reputation beyond reputeJohnny_Law has a reputation beyond reputeJohnny_Law has a reputation beyond reputeJohnny_Law has a reputation beyond reputeJohnny_Law has a reputation beyond reputeJohnny_Law has a reputation beyond reputeJohnny_Law has a reputation beyond repute
Since the 2.0L NA motor doesn't use an air straighter in the stock MAF housing, did you find any advantages in your testing from using it?
Thanks,
CorkSport: Fog light Kit/LED Rear Bumper Lights/Shifter Bushing Kit/License Plate Relocate/Front Lower Arm Bar/Camber Plates/Four Point Rear Chassis Bracing/Camber Arms/
Cobb: AP Version 3/
AEM: Port Injection WME/
Dominant Engineering: Adjustable Rear Toe Arms - Heim Joints/
Tri-Point Engineering: Adjustable Rear Sway Bar - Race/
Whiteline: Front and Rear Control Arm Bushings - Caster Correction/Bump Steer Correction/Front Sway Bar/
KW: Variant III/
POWERGRID: Front End Links/
JBR: Stage 2 Catch Can Kit/
CP-E: Catted DP/Triton/TMIC/Stage 2 Rear, Engine & Transmission Mount/
Sure: Full3 Aeros/AGS Shift Nob/
HTP: Battery Tray/
NGK: One Step Colder/
AutoTech: Internals/
AutoEXE: Oversized Cold Pipe/Boost Tubes/
AEM: Oversized Air Filer -- 21-2145DK/
Renewable Lubricants Inc: Bio Synthetic HD Super High Performance 5W40 Low Ash/
TSW: Nurburgring 18X8.5 + 45/
BFGoodrich: G-Force Sport COMP 2 255/35R18 (runs wide)/
Johnny_Law is offline   Reply With Quote
 Old 03-17-2014, 10:16 AM   #10
Thanks,
We found the increased airflow to be a bit more turbulent. Adding in the air straightener helped to stabilize the idle and the fuel trims. Smoother air makes more power.
New Product Release…JBR 3.5" Wide Path IAS Full Silicone Intake Systems for MAZDASPEED 3/6 JBR JAMES BARONE RACING 51 03-27-2014 08:12 PM
New Product Release - MAZDA 3 SKYACTIV Panel Filter JBR JAMES BARONE RACING 15 01-01-2014 11:33 AM
Product Release! 2014+ Mazda 6 and CX5 2.5L SkyActiv Power Series Short Ram Intakes CorkSport CorkSport 1 05-03-2013 05:52 PM
Product Release! CorkSport SkyActiv Short Ram Intake CorkSport CorkSport 0 04-26-2012 10:50 AM
Product Release! CorkSport SkyActiv Mazda 3 Power Series Single Exit Exhaust CorkSport CorkSport 0 04-10-2012 01:20 PM
Page generated in 0.32911 seconds with 26 queries
