![]() | | #41 | ![]() |
Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
![]() | | #42 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Maybe you should include those instructions with the product? I wasn't aware that could be an issue when I bought it... Thanks for the tip though. |
| The Following User Says Thank You to ilight For This Useful Post: | breakfstincluded (10-18-2014) |
![]() | | #43 | ![]() |
(Thread Starter) | Not Ranked : 0 score The instructions are in the support section of our website and have been for 4 years. |
![]() | | #44 | ![]() |
| Not Ranked : 0 score Sorry, I'm not an expert at everything automotive (always trying to learn). All I had questioned was whether or not it might have been a good idea to mention that the use of this plate might require the shifter to be adjusted. As a fellow small business owner, I know the importance of keeping my clients/customers happy. I just thought you could have been a little more friendly with your advice (rather than standoffish). I'm sorry for questioning your companies professionalism. Take care. |
| The Following User Says Thank You to ilight For This Useful Post: | jdmage_mx5 (10-07-2014) |
![]() | | #45 | ![]() |
I respond with help to your problem in under two minutes and you respond with... and I'm being standoffish? You can't help anybody no a days. | |
| The Following 3 Users Say Thank You to JBR For This Useful Post: |
![]() | | #46 | ![]() |
![]() Join Date: Dec 2012 Location: Ann Arbor, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 890
| Not Ranked : 0 score Bought this along with solid shifter bushings. Night and day. I didn't realize how far gone my lockout was until I slapped this bad boy in. No wonder my 1st and 2nd shifts were so out of whack. I was all the way in reverse territory. Thanks for the product! Now I'm eyeing up that short shifter. Hmm...
__________________ 2007 MS3 Injen SRI | CS TIP | CS TP | 3" TP-Back Straight Pipe | AT Internals All Mounts | Koni Oranges | Eibach Springs | Moog Endlinks Thermal Insulating Gaskets | TB Coolant Bypass AP V3 | FreekTune | Russian Dashcam Mod |
![]() | | #47 | ![]() |
![]() Join Date: Mar 2010 Location: WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 223
| Not Ranked : 0 score Will be ordering this and base bushings this weekend! |
![]() | | #48 | ![]() |
| Not Ranked : 0 score Hope the gen pu comes out soon! like very soon. Had alot of notchy feeling in my shifts so I checked out the shifter and found plastic shavings all caught in the grease |
![]() | | #49 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
| Not Ranked : 0 score Damnit I need this for the MS6 . Should i go ahead and squash those dreams now? Or is there a chance in hell this will be made for the 6?
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() |
| The Following User Says Thank You to ItsNox For This Useful Post: | veritas-truth (04-13-2015) |
![]() | | #50 | ![]() |
![]() Join Date: Dec 2013 Location: The North
Rep Power: 0 ![]() ![]() ![]() Thanks: 80
| Not Ranked : 0 score Just received mine today. Well made and perfect fit. Takes about 10 min to install and a slight adjustment of the shifter cable. Thanks JBR! Putting it into reverse is solid as well as the shift from first to second. My original plastic wasn't worn too much either. |
![]() | | #51 | ![]() |
![]() Join Date: Apr 2015 Location: Riverton, UT
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score hi everyone! i am brand new to the mazda world. i just bought a 2012 MS3 and i absolutely love it!! the only problem i have with it is the reverse lockout does not work so as you all know, it will shift right into reverse without pushing on the shifter :/. i saw the part from JBR to fix this problem but then realized it said its only for 07-09. my question is, will that part work for my '12 or is there another part i need that im not seeing? any and all help would be HUGELY appreciated. thank you!! |
![]() | | #52 | ![]() |
![]() Join Date: Aug 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,823
__________________ | |
![]() | | #53 | ![]() |
![]() Join Date: May 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
@jbarone; is the 2nd Gen MS3 gate guide available for purchase on its own, or is it only compatible along with the short shifter? | |
![]() | | #54 | ![]() |
![]() | | #55 | ![]() |
(Thread Starter) | Not Ranked : 0 score We have it available but it only comes with our GEN 2 short shifter. The gate guide itself is not compatible with the OEM shifter. |
| The Following User Says Thank You to JBR For This Useful Post: | frothy (05-01-2015) |
![]() | | #56 | ![]() |
![]() Join Date: Jan 2010 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 946
Groans: 53
Groaned at 31 Times in 22 Posts
| Not Ranked : 0 score I was just looking at my OEM shifter yesterday and noticed all the wear from the reverse lock out pin... I was wondering if someone made this and BAM JBR does.
__________________ You know.... Moose stuff |
![]() | | #57 | ![]() |
![]() Join Date: Sep 2013 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 76
| Not Ranked : 0 score Installed mine last night. Smooth as butter. |
| The Following User Says Thank You to djrich26 For This Useful Post: | JBR (10-24-2015) |
![]() | | #58 | ![]() |
![]() Join Date: Jan 2012 Location: Seattle, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 858
| Not Ranked : 0 score Had mine in for around 3 months now, great cheap & easy mod. JBR, you make my shifting feel so gooooooooood
__________________ NATOR-WA 'GOVAN' '07 Sunlight Silver Mica MS3 GT JBR SRI + TIP + 88a RMM + SSP + SSB + Giant red knob + Reverse lock-out guide Michelin Pilot Sport A/S 3 215/45 R18 | Damond OCC | ebay Catless TP Defi Red Racer 52mm boost gauge | Torque Pro Android App Dash Install ebay All white LED bulbs + Custom LED strip hatch lights | 15% Tint + 5% Visor Pending installs: JBR EGR Delete + TB TIG | Stealthbox w/ Kicker & amp | Ford magical tranny jizz ~ [SIGPIC][/SIGPIC] |
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score Get Guided! |
![]() | | #60 | ![]() |
![]() Join Date: Jan 2015 Location: Wheat Ridge, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score We do not and there's no plans to make one. |
| Display Modes | |
| New Product Release !! Big Brake Caliper Kit for the Mazdaspeed 6 | CorkSport | CorkSport | 57 | 05-31-2014 07:21 AM |
| Product Release! ? CorkSport Adds Mazdaspeed 6 Rear Sway Bar to Product Line-Up | CorkSport | CorkSport | 47 | 04-22-2014 11:53 PM |
| Product Release! CorkSport Mazdaspeed 3 and Mazdaspeed 6 Brake Pads | CorkSport | CorkSport | 54 | 03-07-2014 07:50 PM |
| CorkSport Mazdaspeed 3 Shifter Bushings and Mazdaspeed 3/6 Short Shift Plate Product Release! | Gwynne | CorkSport | 53 | 09-14-2013 07:51 PM |
| Double Product Release! CorkSport Mazdaspeed 3/Mazda 3 and Mazdaspeed 6 Rear Motor Mount | CorkSport | CorkSport | 30 | 04-19-2013 06:44 PM |
