 Old 03-03-2016, 11:51 AM   #1
Exclamation New Product Release!! Mazdaspeed 3 & Ford Focus ST Solid Rear Drag Mount!!
Special LIMITED time Offer!! Racing season is right around the corner, get yours now!
Mazdaspeed 3 and Ford Focus ST Solid Rear Drag Mount
Details:
With the Mazda platform making in excess of 800HP, getting that power to stick is becoming harder and harder to accomplish. With the mounts currently on the market focused primarily on street-driven cars, there's an increasing demand for more solid mounting. To accomplish the task of keeping the motor planted and the tires hooked up, we've got to get serious.
With weight being a real concern when it comes to going fast, our first choice was 6061 billet aluminum. Testing proved this material option to be flawed. After repeated passes by a 500+ horsepower vehicle, the mounting hole began to oval. As testing continued, this condition only got worse. Eventually the mount was pushed to the point of excessive wear around the mounting points and would no longer remain tight.
Sticking to our roots, 4130 alloy steel was employed, and proved to be up to the task. To say the JBR solid rear drag mount is serious is an understatement. It's constructed out of solid 2" round bar, tube and plate, followed with precision TIG welding and powder coating.
We are confident there's no Mazda on this planet now or in the future that this mount can't handle.
Application:
  • 2004 - 2013 Mazda 3
  • 2007 - 2013 Mazdaspeed 3
  • 2013+ Ford Focus ST
Features:
  • Designed and manufactured in the USA
  • 4130 alloy construction
  • Reduced drive train slop
  • Precise shifts
  • Improved 1/4 mile times
  • Bolt-on installation
Includes:
  • 1 Solid rear drag mount
  • Mounting Hardware
  • Online Installation instructions are available in our support section
aaronsleeps (03-03-2016), Gr8Speed (03-03-2016), Mauro_Penguin (03-04-2016), PapaSmurf (03-03-2016), Yatta (01-18-2017), [R]usty (03-03-2016)
 Old 03-03-2016, 11:54 AM   #2
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
My god! I wonder what vibes feel like with this bad boy. Them "because racecar" vibes...
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 03-03-2016, 12:06 PM   #3
You'd be surprised! This is being run in several DD's and these guys are super happy with it.
Jrs7686 (03-03-2016)
 Old 01-18-2017, 09:45 AM   #4
Solid! It don't vibe like you think.
 Old 01-18-2017, 09:49 AM   #5
Yatta's Avatar
Posts: 1,862   (View Stats)
[*]2007 - 2013 Mazdspeed 3
add an a to Mazdaspeed?
and god... reduce slop or eliminate ? it doesn’t look like much movement is allowed
 Old 01-19-2017, 07:38 AM   #6
With the other mounts not being solid, it can only further reduce slop.
New Product Release!! Mazda 3, Mazdaspeed 3 and Focus ST Adjustable Rear Toe Arms JBR JAMES BARONE RACING 1 04-29-2015 11:24 AM
New Product Release!! Ford Focus ST Rear Adjustable Camber Arms JBR JAMES BARONE RACING 3 04-23-2015 07:51 PM
Dual Product Release!! CorkSport Shift Knob and MazdaSpeed 6 Rear Differential Mount CorkSport CorkSport 15 07-07-2013 10:41 AM
Page generated in 0.27685 seconds with 22 queries
