Like Tree15Likes
 Old 12-08-2014, 07:28 AM   #41
tikous360's Avatar
Posts: 182   (View Stats)
tikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the world
Hard when, while the car is off, running but not moving or down shifting in to 1st?
When the car is running but nt moving
tikous360 is offline   Reply With Quote
 Old 12-08-2014, 11:22 AM   #42
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
Thats the ssp. Take it off and it will be much smoother
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
The Following User Says Thank You to Zdraveca For This Useful Post:
Mauro_Penguin (12-08-2014)
 Old 12-08-2014, 12:33 PM   #43
You can back the throw off on the SSP and make it a bit longer there and do a gate adjustment. See the "How To Adjust Your Shifter" in the support section of our website.
-Jamie
MOCO MS3 (12-08-2014), tikous360 (12-08-2014)
 Old 12-08-2014, 05:39 PM   #44
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
I got my shifter today. Is this piece supposed to be bent like this or should it be flat?
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
jeopardy98 (12-08-2014)
 Old 12-08-2014, 05:50 PM   #45
jeopardy98's Avatar
Posts: 1,920   (View Stats)
jeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the world
Had the same question. I figured it was how it was supposed to be.
Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed.
jeopardy98 is offline   Reply With Quote
The Following User Says Thank You to jeopardy98 For This Useful Post:
mrmonk7663 (12-08-2014)
 Old 12-08-2014, 06:05 PM   #46
Zdraveca's Avatar
Groans: 145
Mine was like that too
GT2876r
E85 FREEKTUNE
 Old 12-08-2014, 06:20 PM   #47
Attachment 184361
The little hoop is suppose to be bent like that.
jeopardy98 (12-08-2014), Mauro_Penguin (12-09-2014), mrmonk7663 (12-08-2014)
 Old 12-08-2014, 06:22 PM   #48
mrmonk7663's Avatar
Good deal, just making sure. Thanks for the quick response
 Old 12-10-2014, 02:09 PM   #49
We have officially run out of these until mid January. 47 sold in 19 days! Many, Many thanks!!
We're still taking orders so keep that in mind if you want one of the next batch of 50.
Thanks,
Jamie
 Old 12-10-2014, 06:48 PM   #50
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
Installed mine saturday and took off the ssp. Shifts feel much better. The only issue that may actually be normal is i have a lot of side to side movement when in gear from the shifter. Took panels off today and looked at it while moving it around and everything is tight. Anyone else have this?
timmcc02 is offline   Reply With Quote
 Old 12-10-2014, 08:17 PM   #51
SaveMelMac's Avatar
Posts: 485   (View Stats)
I do have a small amount of play in the shifter if you twist the knob back and forth. I found it's coming from the shifter neck itself from the pin next to the spring that pushes the shifter back up when you push down for reverse.
 Old 12-11-2014, 11:49 AM   #52
UnknownReagent's Avatar
Posts: 26   (View Stats)
UnknownReagent is a name known to allUnknownReagent is a name known to allUnknownReagent is a name known to allUnknownReagent is a name known to allUnknownReagent is a name known to allUnknownReagent is a name known to all
Compared to stock and SSP, I have basically zero lateral play in my shifter now. Make sure the white cap that goes in the cable arm is securely attached to the ball-joint that sticks out the side of the shifter. I made that mistake at first and had a huge amount of play until I fixed it.
JBR likes this.
UnknownReagent is offline   Reply With Quote
The Following User Says Thank You to UnknownReagent For This Useful Post:
JBR (12-11-2014)
 Old 12-13-2014, 11:23 AM   #53
covelife1016's Avatar
Posts: 151   (View Stats)
covelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond repute
Just installed my 2nd gen short shifter today. It is very tight in gear and feels buttery smooth as mentioned before. However, I have to push down on the shifter for the pin to go under the gate guide for first and second gear. Is this normal or do I need to adjust something?
2010 MS3 non tech
// CS TMIC// CS battery box// JBR short shifter// JBR 88a rmm// JBR boost tubes// JBR solid shifter bushings// JBR coolant bypass and throttle body tig// Kozmic Motorsports primary and secondary egr delete// NGK one step colder plugs// AT fuel pump internals// HTP 3" intake// GFB bov// COBB accessport V2 // GroundControl springs// Koni yellows//
TUNED BY STRATIFIED
covelife1016 is offline   Reply With Quote
 Old 12-13-2014, 11:48 AM   #54
That is NOT normal. Is the gate guide all the way against the OEM gate? There is some adjustment there. Also, please check all points of the reassembly process ensure it's all correct. If the problem still exists, shoot me some good pictures to jamesbaroneracing@gmail.com so I can take a close look at them.
-Jamie
covelife1016 (12-13-2014), mrmonk7663 (12-13-2014)
 Old 12-13-2014, 11:53 AM   #55
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Check all the linkage over carefully to make sure all of the clips are fully pushed back in.
 Old 12-13-2014, 12:01 PM   #56
Got it. It was the adjustment on the selector cable. Somewhere putting it back in I must of knocked it or moved it off that nipple. Thanks for replying so fast.
JBR likes this.
2010 MS3 non tech
TUNED BY STRATIFIED
The Following 2 Users Say Thank You to covelife1016 For This Useful Post:
Gr8Speed (12-13-2014), JBR (12-13-2014)
 Old 12-13-2014, 12:06 PM   #57
-Jamie
Thanks for the help. I had a feeling that something wasn't right.
JBR likes this.
2010 MS3 non tech
TUNED BY STRATIFIED
The Following User Says Thank You to covelife1016 For This Useful Post:
JBR (12-13-2014)
 Old 12-13-2014, 12:20 PM   #58
Djohns's Avatar
Posts: 3,944   (View Stats)
Got mine and attempted to install before work. Having a real hard time getting that second cable to pop off. Anyone have any tips or suggestions for that?
 Old 12-13-2014, 12:27 PM   #59
13mm open end wrench is how I popped mine off.
2010 MS3 non tech
TUNED BY STRATIFIED
Djohns (12-13-2014), mr_mazda329 (04-16-2015)
 Old 12-13-2014, 06:34 PM   #60
timmcc02's Avatar
So I took mine apart to check it out and found the arm that comes out the left of the ball of the shift rod that screws into it came loose. So I tightened it up and it fixed the play. After driving it about 20 miles its loose again. You think I should use some loctite on it?
 Old 12-13-2014, 06:40 PM   #61
I presume you did tighten it with a wrench? If that doesn't keep it tight loctite will for sure. I'll add a note to the instructions to use some loctite as well.
Thanks for the feedback.
covelife1016 (12-13-2014), Mauro_Penguin (12-13-2014), mrmonk7663 (12-13-2014)
 Old 12-13-2014, 06:46 PM   #62
timmcc02's Avatar
Ya thats probably for the best just make sure to say blue loctite and not red lol. One more time taking it out of the car hopefully.
 Old 12-13-2014, 08:13 PM   #63
mrmonk7663's Avatar
I should be installing mine this coming week. I have the JBR adjustable short shift plate, set in the middle. I intend on keeping the ssp. I haven't seen any reviews yet with the combo installed, so i'll let yall know how it goes. My car is forced to use the SSP due to my blowthru setup. The stock setup with stock weight would contact my intake piping. The SSP on the middle setting works real well on its own, so hopefully the shifter makes it even nicer.
 Old 12-13-2014, 08:28 PM   #64
Djohns's Avatar
One last question, I notice that you have white lithium grease, I've been trying to get my hands on some and when I finally get some. It's black. Is it necessary to use white grease? I know that's a stupid question but I just wanna make sure before I go slathering that shit up
 Old 12-14-2014, 03:48 PM   #65
jeopardy98's Avatar
So I installed mine today and I love it but when I go over to first it doesn't spring back to neutral. It does from 5th and 6th. Also, in reverse it doesn't spring back. I think the spring is weird. I'm not pulling it back apart though. I can live with it.
 Old 12-14-2014, 04:36 PM   #66
I saw this issue in our shop car once out of many, many installs it didn't really resonate with me at the time but, here's how to fix the problem you're having.
Loosen the torx screw that holds the gate guide down. If you added the optional screw, loosen it too. Waggle the shifter back and forth and then tighten them back down again. This should resolve the issue with the shifter not returning to neutral. There should be no need to remove the shifter to correct this.
Now, the stalk not coming all the way back up, we think is caused by the thick lithium grease we used during assembly. This issue especially prevalent if the car is very cold and the grease is even tackier. I suspect it will get better with time as the grease breaks down.
Let me know if this solves the problem and I'll add a note to the installation instructions.
-Jamie
jeopardy98 likes this.
danmillerok (12-14-2014), jeopardy98 (12-14-2014), Mauro_Penguin (12-14-2014)
 Old 12-14-2014, 04:44 PM   #67
jeopardy98's Avatar
Excellent! I'll give it a shot. I did use the optional screw and if it is that easy I will certainly be fixing it up. Thanks! It returns back up just fine. No issue there.
 Old 12-14-2014, 04:52 PM   #68
WFO!'s Avatar
Posts: 103   (View Stats)
-Jamie
Jamie
Im sure you know about Lubriplate.
This is what came with my Factory Mazdaspeed short shift kit from Mazda.
Also included in the B&M shift kits as well as others. Its the only grease to use for shifters in most opinions.
Cheap on eBay.
Lubriplate Aero Lithium Based Grease Lubricant 5 Pieces 3 8 oz Tubes New | eBay
The Following 5 Users Say Thank You to WFO! For This Useful Post:
danmillerok (12-14-2014), Easter Bunny (12-17-2014), JBR (12-14-2014), Mauro_Penguin (12-14-2014), mrmonk7663 (12-14-2014)
 Old 12-14-2014, 05:38 PM   #69
Originally Posted by WFO! View Post
Jamie
Cheap on eBay.
I've heard of it but I've never tried it. I will get some. Thanks for mentioning it.
Here's a fun fact....
Mazdaspeed and B&M supplying the same grease a coincidence? No, B&M made the Mazdaspeed shifters for Mazda to Mazda's specifications.
-Jamie
 Old 12-14-2014, 05:47 PM   #70
WFO!'s Avatar
^ Right. Also the Mazdaspeed kits came with a nice pressed steel tool for removing the ball so you dont have to mess with paperclips etc. Thats a B&M thing. They include the tool in other SS kits.
That grease is godlike, BTW.
The Following 2 Users Say Thank You to WFO! For This Useful Post:
covelife1016 (12-15-2014), JBR (12-14-2014)
 Old 12-14-2014, 06:25 PM   #71
Ordered!!
 Old 12-15-2014, 06:57 AM   #72
MOCO MS3's Avatar
Posts: 644   (View Stats)
Drove a friends MS3 with the shifter last night and I can truly say that this one of the best aftermarket pieces I have ever seen or felt. The shifting was smooth, precise and effortless. More importantly, there was no slop in it at all and the confidence with the shorter throws and the precise way it goes into every gear, was amazing.
I have driven cars with B & M, Mazdaspeed, TWM and others, this one is second to none. It felt almost like driving a car with a sequenial gearbox, the down shifts were smooth and precise as well. I cannot wait to get this shifter on track @ Mid-Ohio and put it through it paces and see the results of a couple of days of work!
The Following 4 Users Say Thank You to MOCO MS3 For This Useful Post:
jeopardy98 (12-15-2014), Mauro_Penguin (12-15-2014), mrmonk7663 (12-15-2014), TJM216 (12-17-2014)
 Old 12-17-2014, 05:43 PM   #73
mrmonk7663's Avatar
Installed the shifter today in my gen2. Instructions are spot on. I added blue loctite to the shifterball you tighten.
I set throw all the way down (least reduction) and neutral all the way back (pulled to rear). I have a jbr adjustable ssp. I set that to minimal reduction.
Shifting is smooth and short. 3rd gear is so smooth and short compared to the rest it almost is hard to tell I even engaged the gear. All gears engage fine upshifting and downshifting. Reverse is normal as well.
Install is tedious but not hard. 2 1/2 hours start to finish including ssp adjustment and quick snack break.
If my new intake setup provides me with enough room I might take the ssp off to try that. I initially had the ssp in the middle position, and while everything worked fine, 3rd was too short that way for my liking.
All in all a great product. For the amount of time and precision it takes to design this thing the price is an incredible value.
Thanks JBR
JBR likes this.
The Following 4 Users Say Thank You to mrmonk7663 For This Useful Post:
covelife1016 (12-17-2014), JBR (12-17-2014), Mauro_Penguin (12-17-2014), MOCO MS3 (12-18-2014)
 Old 12-17-2014, 08:20 PM   #74
mrmonk7663's Avatar
Update-The way 3rd and 5th felt with the SSP I did not feel comfortable driving. It is not because it didn't work, it was because you couldn't feel when 3rd and 5th engaged. It was that short. It was at least half as short as 2nd and 4th. So I took off the SSP but retained the JBR shift weight. I left the shifter at the lowest reduction. Now all gears feel equal in shift length and all engage perfect. Next step is to increase the shift reduction by about 10 more percent via the shifter, and I should be all done.
The point of this is, yes you can use the SSP with this shifter. Based on my experience today, however, I would not personally recommend doing it. It is not needed, and only takes 10 minutes to remove. The new shifter has enough reduction ability to meet anyones needs without an SSP.
Update 2- Moved the throw reduction so that a tad past middle. This required more trimming of the plastic than the install instructions said. I think someone else mentioned this in here. No big deal. On future shifters in production it might be easier to radius that corner. Anyway, throw is great and all gears have easy positive engagement. I am happy with where its at. I'm done
I hope my review helps some of yall out there.
The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post:
Mauro_Penguin (12-18-2014), MOCO MS3 (12-18-2014)
 Old 12-18-2014, 12:35 AM   #75
NeoKraSH's Avatar
Posts: 49   (View Stats)
NeoKraSH is a splendid one to beholdNeoKraSH is a splendid one to beholdNeoKraSH is a splendid one to beholdNeoKraSH is a splendid one to beholdNeoKraSH is a splendid one to beholdNeoKraSH is a splendid one to beholdNeoKraSH is a splendid one to behold
Nice work Jamie! I would love one if I was not currently a broke college student haha
2011 MS3AXELA
NeoKraSH is offline   Reply With Quote
The Following User Says Thank You to NeoKraSH For This Useful Post:
macdiesel (12-28-2014)
 Old 12-20-2014, 06:34 PM   #76
Djohns's Avatar
Installed mine, absolutely love it, used the Lubriplate grease as mentioned above. Only thing I'm having a problem with is I have trimmed A lot off of the plastic piece and I am still hitting it. I'm not sure I can take anymore off. Is it possibly something I did during install? Shifter is set at shortest throw and neutral all the way towards the back. (Towards the inside of the car)
JBR likes this.
JBR (12-20-2014)
 Old 12-20-2014, 06:40 PM   #77
I doubt you're doing g anything wrong. If you have it set to the shortest throw its actually exceeding what it was designed to do. So, back off a bit and it will clear. You won't notice the throw being a tad longer.
Hope this helps.
-Jamie
Djohns (12-21-2014)
 Old 12-20-2014, 10:29 PM   #78
mrmonk7663's Avatar
Its possible you did not trim enough. I had it set at the shortest and had no issues. I went to the middle and had to trim more. You can take the cupholder out but place the shifter bezel back on, and reach your hand under there and feel exactly where it hits...that's what I did.
 Old 12-22-2014, 01:06 AM   #79
nb6179505's Avatar
Posts: 348   (View Stats)
nb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond repute
stupid question, but i couldn't find anything, I just took the SSP off and kept stock under the hood with the short shifter. The red adjustable piece, I have furthest back towards the back seats, but in terms of height, does the shorter it goes make the throw shorter or longer?
ie the higher up its set, will that lengthen the throw?
nb6179505 is offline   Reply With Quote
 Old 12-22-2014, 08:45 AM   #80
mrmonk7663's Avatar
Up is shorter, all the way down is longest throw.
New Product Release!! JBR Short Shifter 2007 - 2009 Mazdaspeed 3 In Stock JBR JAMES BARONE RACING 204 12-29-2014 10:18 AM
New Product Release - MAZDASPEED 3 GEN 1 RHD Short Shifter! Now Available JBR JAMES BARONE RACING 1 11-18-2014 10:33 AM
Product Release: CorkSport Adjustable Shortshifter For Mazdaspeed 3 CorkSport CorkSport 174 09-12-2014 07:51 AM
Page generated in 0.59892 seconds with 35 queries
