Like Tree15Likes
 Old 12-24-2014, 11:48 AM   #81
MizzyMS3's Avatar
Posts: 511   (View Stats)
MizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the world
Wifey gave me this shifter for Christmas (we opened gifts early) and I started install. All is going smoothly, but I cannot for the life of me get the shifter out of the shifter base (where you have to depress the 3 tabs to take it out. One tab has a paper clip holding it open, but no matter how much we press the other two tabs, the shifter still does not come out. Any tips for this?
2012 CWP MS3 w/ Tech Package
Cobb AP V3 Purple Drank Tuned (E33 mix) | HTP 3.5' Intake | eBay Catless DP | UR CBE | CX-Racing FMIC | Autotechs | Turbosmart Dual Port BOV | JBR Short Throw Shifter | JBR Stage 2 SSP | JBR 88 duro RMM | RallyArmor Mudflaps | Eibach pro kit + Koni Yellows + SPC Camber Arms | NGK step colder
MizzyMS3 is offline   Reply With Quote
 Old 12-24-2014, 01:31 PM   #82
jeopardy98's Avatar
Posts: 1,920   (View Stats)
jeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the world
There are access holes to each tab. You can slide a flat head in each one and then it should pull right up.
Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed.
jeopardy98 is offline   Reply With Quote
The Following User Says Thank You to jeopardy98 For This Useful Post:
MizzyMS3 (12-24-2014)
 Old 12-24-2014, 02:54 PM   #83
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Make sure you are pushing the tabs IN IN IN...do not push them out. Push tabs in then put paperclip behind it, it will come right out. I pushed out at first and was like WTF.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
 Old 12-24-2014, 09:23 PM   #84
MizzyMS3's Avatar
Thank you guys! I feel so stupid haha. Once I got that part out of the way, it took about a half hour to get everything back together, and put back in the car, with the upgraded shifter bushings. Shifter feel is AMAZING. Thanks again guys!
The Following User Says Thank You to MizzyMS3 For This Useful Post:
jeopardy98 (12-25-2014)
 Old 12-24-2014, 11:11 PM   #85
mrmonk7663's Avatar
No problem haha. I did it as well, that's how I knew what your issue was, so don't feel bad
 Old 12-26-2014, 12:48 PM   #86
Djohns's Avatar
Posts: 3,944   (View Stats)
Okay after using this shifter for a couple weeks now my overall Impressions are FANTASTIC. Take a little time to tune it in really nice and make sure to use a lot of grease on the spring! Where it goes on the selector arm and where the base of the spring is. (Not sure that part was mentioned in install instructions) I used the Lubriplate grease and that stuff is fantastic. Once again Jamie released another fantastic product! Shifts are super smooth and crisp
 Old 12-26-2014, 09:14 PM   #87
XxSmarTz's Avatar
Posts: 1,121   (View Stats)
XxSmarTz is the leader of the worldXxSmarTz is the leader of the worldXxSmarTz is the leader of the worldXxSmarTz is the leader of the worldXxSmarTz is the leader of the worldXxSmarTz is the leader of the worldXxSmarTz is the leader of the worldXxSmarTz is the leader of the worldXxSmarTz is the leader of the worldXxSmarTz is the leader of the worldXxSmarTz is the leader of the world
Ordered
2013 MS3 Black Mica l JBR TRU-3" Wide Path l JBR Stage 3 Shift Kit l JBR SPHERICAL SHIFT KNOB l JBR FMIC Piping Kit l COBB Accessport V3 l FORGE V2 BPV l TR6 Core l CNT Catback l Top Speed Test Pipe l Autotech Internals l
XxSmarTz is offline   Reply With Quote
 Old 12-27-2014, 07:36 PM   #88
TheDukeZip's Avatar
Posts: 51   (View Stats)
TheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond repute
Santa dropped off this wonderful goodie and I got a chance to install it today. Installation wasn't difficult, just tricky - getting the retainer clip both off and on, as well as putting the spring back on required a lot of patience. For someone who's never done this before and took their time - took about 2 - 2.5 hours.
I put the throw just a hair below max reduction as seems to be recommended. With this, putting the neutral attachment all the way forward (so the shifter goes as far towards the back of the car as possible) seemed to be just right. Seems to be dialed in just right for me like this, but glad there are lots of adjustments that can be made on the shifter and on the shift cables to dial it in just right if necessary.
Thanks JBR!
JBR likes this.
TheDukeZip is offline   Reply With Quote
The Following 2 Users Say Thank You to TheDukeZip For This Useful Post:
JBR (12-28-2014), XxSmarTz (12-27-2014)
 Old 12-28-2014, 06:17 PM   #89
Djohns's Avatar
Quick question, I love this shifter but after a night of hard driving (Having fun with my buddy and his ms3 and another with a 350Z) I noticed it to be a bit notchy during shifts I'm running ford motorcraft trans fluid and the fluid change was fairly recent so I'm not sure what is causing this. Feels smooth shifting when the car is off but when driving I feel the notchiness and downshifting to first only happens on occasions. I have to be gentle when shifting into 5th or I will get a possible grind
 Old 12-28-2014, 06:24 PM   #90
macdiesel's Avatar
Posts: 825   (View Stats)
Probably needs to be adjusted out.
 Old 12-28-2014, 06:34 PM   #91
Djohns's Avatar
Sorry for my slowness lol but what do you mean adjusted out?
 Old 12-28-2014, 06:48 PM   #92
macdiesel's Avatar
Mess with the adjuster? Take off ssp if you have one? I'm confused because you gave rave reviews before.
 Old 12-28-2014, 06:53 PM   #93
Djohns's Avatar
I have the stock shifter plate and weight on now. I do own a JBR ssp and counter weight. That's why I'm confused as well because it was great before then after that night it wasn't the same. I was wondering if I knocked something loose or what the deal is. I've been trying to adjust the cables but it doesn't seem to be working
 Old 12-28-2014, 07:09 PM   #94
It's possible the adjuster plate is loose or maybe the selector arm actuator. If it's not either of those, I'd venture to guess it's not the shifter.
 Old 12-28-2014, 07:16 PM   #95
Djohns's Avatar
Okay thank you for input! I will dig into it again asap and post up what happens!
 Old 12-31-2014, 11:24 AM   #96
Djohns's Avatar
Okay I think Ive narrowed it down to something with my linkage cables. So it is NOT the shifter. Couldn't find anything loose or out of place when I took it apart so I pulled just the cable that hooks to neutral and it still felt weird. Then we had one warmer day and it was back to smoothness. Back to cold and once again feels wrong.
JBR likes this.
JBR (12-31-2014)
 Old 12-31-2014, 11:46 AM   #97
I can see the cold having an effect on the lubricant used inside the cable sheathing.
Did it feel like there was any rough spots as you moved the cable in all the way and out? If so it could be some debris has managed to find it's way in nut that's sort of a long shot. It sounds like the cold is the issue. What are the temps when you say cold?
-Jamie
 Old 12-31-2014, 01:31 PM   #98
Djohns's Avatar
-Jamie
It was rough moving it in and out. Can pin point a specific spot with just the cable. But when attached to the shifter and actually driving not just having the car run, 5th feels awful. I have to line it up and apply light pressure until it decides it wants to go in and even then it feels really rough. like it is grinding on something but it doesn't make any noises. The others just feel a bit rough and notchy but not like 5th. By cold I mean 40's. (Illinois weather) then we had one day of 55 and it felt great
 Old 12-31-2014, 02:23 PM   #99
Hmmm I wonder if it's trans related? What fluid is in it?
 Old 12-31-2014, 03:42 PM   #100
Djohns's Avatar
Sorry first post was supposed to say can't pinpoint. Just changed the fluid switched to Ford Motorcraft about a month and a half ago car has 29k miles. Always let the car warm up before driving
 Old 12-31-2014, 04:30 PM   #101
WFO!'s Avatar
Posts: 103   (View Stats)
-Jamie
The cables are teflon lined. Dry. (E-brake cables too)
Id look somewere else. Could just be the fluid fill.
Impossible to say without being there to feel it in person.
The Following User Says NO Thank You to WFO! For This Un-useful Post:
ThizSpeed3 (01-02-2015)
 Old 12-31-2014, 04:45 PM   #102
Yeah, I thought there was some lubricant too; maybe not. I know I've gotten some kind of something on my fingers similar to graphite when I've pulled the boot back at the transmission.
Not sure what what could be the problem.
 Old 12-31-2014, 04:54 PM   #103
Djohns's Avatar
Dang this has everyone confused. It feels like little bumps as I shift into the gears. Thats another way to describe how it feels. I feel maybe 2-4 of the bumps when going into gear. It's very weird is there a possible way to check/clean the cables? Luckily I have tomorrow off so I can go digging in the engine bay to see if the cable is catching on something. Gunna check where it goes through the firewall and make sure they're not rubbing and other places. I'll post up what happens and if I find a fix so if anyone else has this issue they'll know what to do.
 Old 01-01-2015, 11:14 PM   #104
Djohns's Avatar
Okay i started trying to pinpoint my issue this evening and well. I did just that. I was looking at the cables under the hood and found that the rubbing is from that area then I found that it was coming from right above the trans boot on the shift lever shaft or pivot shaft?(not sure what the part is called) in the photo the piece to the left is a bit loose and is rubbing the other side quite a bit as I change gears and is producing little metal shavings. Hence that feeling in 5th. And the roughness in all the others. But I can't figure out how to tighten up that loose piece. Sorry for the photo being cropped! The boot is supposed to be at the bottom of the picture
 Old 01-02-2015, 10:25 AM   #105
That shot is of the secondary selector linkage at the point where it engages the selector shaft. It's design is to move in and out and also to pivot up and down. It's not meant to be tightened. Our shop cars have a considerable amount of grease in that area. It would appear the the metal you are seeing is from the lack of grease over a long period of time. I suggest greasing the area well to see if after some time the issue goes away.
-Jamie
Djohns (01-02-2015)
 Old 01-02-2015, 07:41 PM   #106
Djohns's Avatar
Yea I figured it was supposed to move but I was thinking that it may have been excessive with how much it was rubbing. Yea I cleaned it all out of the metal shavings and put some lithium grease in it. Should I use a thicker grease or should lithium be sufficient?
 Old 01-03-2015, 08:38 AM   #107
Lithium should be OK. Let us know if the problem goes away.
Djohns (01-03-2015)
 Old 01-03-2015, 08:29 PM   #108
Djohns's Avatar
I'll post up what happens after a week and how often I regreased
 Old 01-08-2015, 12:11 PM   #109
Djohns's Avatar
Just an update on the issue I was having: the grease seems to be working. Still having occasional trouble down shifting into second and first. But overall it is slowly getting better. Cold weather really does play a big role into this. So far within a week I've greased about 3 times
JBR (01-19-2015)
 Old 01-19-2015, 05:10 PM   #110
Shifters are back in stock. All back orders have shipped or are being prepared to ship now.
Thanks for your patience.
We have plenty now.
XxSmarTz likes this.
MOCO MS3 (01-19-2015), XxSmarTz (01-19-2015)
 Old 01-19-2015, 07:56 PM   #111
hobbit-monster's Avatar
Posts: 6   (View Stats)
hobbit-monster will become famous soon enough
Originally Posted by SaveMelMac View Post
I do have a small amount of play in the shifter if you twist the knob back and forth. I found it's coming from the shifter neck itself from the pin next to the spring that pushes the shifter back up when you push down for reverse.
I too am having the same issue. It's not major by any means but it is a slight annoyance. Besides that props to JBR for an amazing part. Its incredible how smooth it is compared to a SSP or stock. Not to mention an awesome price.
hobbit-monster is offline   Reply With Quote
The Following User Says Thank You to hobbit-monster For This Useful Post:
Mauro_Penguin (01-19-2015)
 Old 01-19-2015, 07:59 PM   #112
jeopardy98's Avatar
I have slight slop on the shifter now as well. Not sure what changed. I popped the console out and looked today abs it looks like somethung in the actual cup or in the return spring. Everything was tight on the attachment points.
 Old 01-20-2015, 10:57 AM   #113
There is about .007" of play in the vertical slot for the reverse lock out pin which exhibits a slight amount of rotational play. This allowance is necessary to avoid any binding and for smooth operation.
exentix (01-20-2015)
 Old 01-20-2015, 12:52 PM   #114
jeopardy98's Avatar
I'm talking about more than a 1/2". I'll make a video.
 Old 01-20-2015, 01:01 PM   #115
If that's the case, I would suspect something has come loose.
 Old 01-20-2015, 06:06 PM   #116
jeopardy98's Avatar
What could have come loose in the cup?
Last edited by jeopardy98; 01-20-2015 at 06:06 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-20-2015, 06:10 PM   #117
Djohns's Avatar
Maybe the spring? I Noticed on mine when I was greasing the slide and had the spring up it had a lot of play like that
jeopardy98 (01-20-2015)
 Old 01-20-2015, 06:20 PM   #118
I was talking about rotational play not side to side.
Not sure. You'll need to get in there and look.
 Old 01-20-2015, 06:22 PM   #119
jeopardy98's Avatar
I did. I took it apart yesterday. The looseness is in the cup itself. All the cables and adjustments are tight. The spring or a broken cup are the only options left...
 Old 01-20-2015, 08:05 PM   #120
Djohns's Avatar
Can you take a video of it when the shifter boot and all that are out so we can look at the shifter base and shortshifter itself and maybe pinpoint the issue?
New Product Release!! JBR Short Shifter 2007 - 2009 Mazdaspeed 3 In Stock JBR JAMES BARONE RACING 204 12-29-2014 10:18 AM
New Product Release - MAZDASPEED 3 GEN 1 RHD Short Shifter! Now Available JBR JAMES BARONE RACING 1 11-18-2014 10:33 AM
Product Release: CorkSport Adjustable Shortshifter For Mazdaspeed 3 CorkSport CorkSport 174 09-12-2014 07:51 AM
Page generated in 0.58329 seconds with 30 queries
