Like Tree15Likes
 Old 01-20-2015, 08:07 PM   #121
jeopardy98's Avatar
Posts: 1,920   (View Stats)
jeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the world
Certainly. I'll post up tomorrow.
Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed.
jeopardy98 is offline   Reply With Quote
 Old 01-20-2015, 08:39 PM   #122
Djohns's Avatar
Posts: 3,944   (View Stats)
Sounds good. If you can, get a close up of the spring when you move the shifter side to side in neutral and when you do it in gear. Same with the shifter cup if you can. It'll help pinpoint the issue. I'm thinking that the spring may be on wrong, but I could be wrong.
jeopardy98 (01-20-2015)
 Old 03-07-2015, 11:00 AM   #123
We're All Thieves's Avatar
Posts: 28   (View Stats)
We're All Thieves is a jewel in the roughWe're All Thieves is a jewel in the roughWe're All Thieves is a jewel in the rough
Any update on this?
We're All Thieves is offline   Reply With Quote
 Old 03-07-2015, 04:24 PM   #124
jeopardy98's Avatar
No, I've just decided to deal with it.
 Old 04-12-2015, 09:12 PM   #125
Snapple415's Avatar
Posts: 38   (View Stats)
Snapple415 has a spectacular aura aboutSnapple415 has a spectacular aura about
Guys am I missing something? Because this will hit pretty bad.. I have a 2010 and it's on the shortest setting (if i put it on the longest then I don't have this problem) but even so it doesn't seem anyone else has had this problem?
Snapple415 is offline   Reply With Quote
 Old 05-20-2015, 02:01 PM   #126
Snapple415's Avatar
bump
 Old 05-20-2015, 02:25 PM   #127
Djohns's Avatar
Dude.... Not to be a dick but it clearly states in the install instructions that 2010 and up models need to trim that piece up to be on the shortest setting.
2010 black mica speed3
Soon:built motor
Gr8Speed (05-20-2015)
 Old 05-20-2015, 02:28 PM   #128
Snapple415's Avatar
The picture shows it to be the ring that holds the shift boot.. (on the instructions) well my bad if it's actually that then. Thank you
 Old 05-20-2015, 02:30 PM   #129
Djohns's Avatar
Also try backing it down a tad. It's not meant to be pushed all the way to the top. Back it down a little. You won't notice a difference in shift throw
Soon:built motor
 Old 05-25-2015, 07:39 AM   #130
Snapple415's Avatar
Ok done. Everything was trimmed down nicely i wonder if its simpler just to swap the piece with a newer model.
2nd question and this is just for ease of mind. I did start to get the same "slop" as the others. It was very tight for about the first week and now its looser (not enough to annoy me but enough to show ah obvious difference.
I'm thinking maybe it's the grease I used? I used general purpose YELLOW lithium grease. The man at the hardware store told me it would be fine. Is it actually ok? Or is it starting to break down the plastics because now I'm getting worried!
 Old 05-25-2015, 10:11 AM   #131
Sorry we didn't see this earlier.
The reason for the contact in that area is because the adjuster is not assembled correctly. Please see steps 13 thru 15.
 Old 05-25-2015, 12:11 PM   #132
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
SuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond repute
Hmmm was gunna go with the CS one but I may have to go to the dark side..
2013 Genpu GT, 245/40 Direzzas, CS SRI+TIP,CS TP+CB, CS TMIC, CS FP Internals, CS 80a RMM, CS BPV, Accessport V3, Tuned by Nishan
SuckSqueezBangBlow is offline   Reply With Quote
New Product Release!! JBR Short Shifter 2007 - 2009 Mazdaspeed 3 In Stock JBR JAMES BARONE RACING 204 12-29-2014 10:18 AM
New Product Release - MAZDASPEED 3 GEN 1 RHD Short Shifter! Now Available JBR JAMES BARONE RACING 1 11-18-2014 10:33 AM
Product Release: CorkSport Adjustable Shortshifter For Mazdaspeed 3 CorkSport CorkSport 174 09-12-2014 07:51 AM
Page generated in 0.32540 seconds with 26 queries
