 Old 06-12-2013, 09:49 AM   #1
MSP6's Avatar
Posts: 1,246   (View Stats)
Default PMM Install Tip
Some people were mentioning that the PMM was a tight fit and a PITA to install. Here's a quick way to get it on there. Thought it might help someone out.
First, get the mount somewhat in place, then get the designated frame bolt into the A-hole (giggity)
Then get the two bolts started in the B-Holes (again, giggity) They won't actually seat in ther but will bind up almost immediately. This is ok.
Hit "C" with either the side of your fist (or a rubber mallet) a few times to lock it in a little.
Lower your jack a few turns, hit "C" a few more times. Notice the bolts slide in a wee bit further. Repeat this a handful of times and your PMM will slowly seat itself right down into place, no engine rocking required. Then you can finish off your bolts. Hope this helps!
The Following 2 Users Say Thank You to MSP6 For This Useful Post:
RichieRichness (07-05-2013), SpeedRebirth (06-12-2013)
 Old 06-12-2013, 09:57 AM   #2
Nice! Thanks for the tip.
A-hole...LOL
allo80 (06-13-2013)
First Install Cobb SRI/TIP/Airbox looking for TIP install video? Phog Mazdaspeed3/6 General Discussion 3 12-14-2012 04:26 PM
What to install/not install for autocross. maisonvi Auto-X / Road Racing / Time Attack 17 06-22-2012 09:02 AM
To install EGR Block Off or not to install EGR Block Off..that is the question? deadlandxtreme 2010 MS3 - Engine, Transmission & Driveline 9 01-16-2012 12:38 PM
Page generated in 0.23798 seconds with 22 queries
