Like Tree3Likes
  • 1 Post By classybum
  • 1 Post By Kyle Undefined
  • 1 Post By Tremmy2
 Old 06-04-2013, 09:52 AM   #1
classybum's Avatar
Posts: 31   (View Stats)
classybum has much to be proud ofclassybum has much to be proud ofclassybum has much to be proud ofclassybum has much to be proud ofclassybum has much to be proud ofclassybum has much to be proud ofclassybum has much to be proud ofclassybum has much to be proud ofclassybum has much to be proud of
Question Power Path Stage 2 installed (awesome) - remove factory air collector? (genpu)
I recently bought and installed the JBR powerpath stage 2 on my 2012 speed3, first mod, and I love it to death. Jamie/Jennifer provided great customer service. The install guide is awesome, far better than some competitors, and it went without a hitch.
Question: The install guide leaves the furthest upstream bits of the factory intake installed, not sure what to call them, air collector and hose? See attached picture, green circle, shows the hose i removed, but I left in the furthest upstream plastic piece (not pictured). Is it best to leave those installed? I see that it would direct airflow to the filter, but I was thinking that the hose itself was pointed slightly down. Leaving only the initial air collector/deflector will still generally direct ram air at the air filter.
I can get some better pictures later if it helps, i stole the attached from JBRs install guide:
http://jamesbaroneracing.com/support...structions.pdf
Thanks!
JBR likes this.
classybum is offline   Reply With Quote
The Following User Says Thank You to classybum For This Useful Post:
JBR (06-04-2013)
 Old 06-04-2013, 10:00 AM   #2
Police - Grammarhead
Vansquish's Avatar
Correct me if I'm wrong, but that hose in the green circle shouldn't be part of the OEM intake system at all...
 Old 06-04-2013, 10:05 AM   #3
classybum's Avatar
It's definitely part of the stock intake system. It connects directly to the factory airbox. You can also see it in step 3 and 6 of the instructions linked above.
 Old 06-04-2013, 03:44 PM   #4
Vansquish's Avatar
It's an MS3 thing. My factory air-box had only one ingress and one egress, and the ingress was located in the driver's side wheel well. There was no "ram-air" intake hose leading to the grill.
 Old 06-04-2013, 10:13 AM   #5
FSUMazdaSpeed's Avatar
Posts: 350   (View Stats)
I took it out when I installed my intake, just seemed to be in the way and looked out of p lace without the factory airbox
 Old 06-04-2013, 10:22 AM   #6
Andrewbox's Avatar
Posts: 667   (View Stats)
Andrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the world
You can remove it. Just leave the larger section of the tube as it has clips to hold some cooling lines to the radiator support
Black Mica 2013 Mazdaspeed 3 w/ tech
GTX3076r EWG | CP-E ΔCore | CP-E Triton | CP-E LTRmani | CP-E DP
AUTOTECH HPFP | HTP 3.5" | GFB RESPONS
GRIMMSPEED EBC | CORKSPORT SSP | K-SPORT COILS
JBR CAMBER ARMS | JBR SWAY BAR | JBR MOUNTED
JBR TIGs | JBR ERG | JBR 51r TRAY
Andrewbox is offline   Reply With Quote
 Old 06-04-2013, 10:39 AM   #7
DuoofDeath1's Avatar
Posts: 393   (View Stats)
DuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the world
I left mine installed for a long time and then removed it last week. It is used to get fresh air to the stock intake box but it is not needed on the JBR intake. Mine was actually scrapping up against my Corksport intake so that is why I took it out but I don't think it will do that to the JBR intake.
2014 Snowflake White Pearl Mazda 3 2.0l 6spd Hatchback
2012 Black Mica Mazdaspeed3 - Sold
2004 Strato Blue Mazda 3 2.3L 5spd Hatchback - Sold
DuoofDeath1 is offline   Reply With Quote
 Old 06-04-2013, 10:51 AM   #8
Tremmy2's Avatar
Posts: 54   (View Stats)
Tremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant future
I was pondering that same thing the other day. Decided to just leave it attached on the off chance I need to stock out for some reason. One less thing to put back.
2013 Black Mica MazdaSpeed 3
COBB AccessPORT // JBR Power Path Stage II SRI // AutoTech HPFP // CP-E xFlex RMM Stage II // JBR Short Shift Plate RSB// JBR Solid Shifter Bushings // H&R Springs // CorkSport RSB
Tremmy2 is offline   Reply With Quote
 Old 06-04-2013, 04:10 PM   #9
Sideswipe Magnet
Kyle Undefined's Avatar
Posts: 3,378   (View Stats)
Groans: 332
Off topic, but WTF is up with your avatar? Lol.
bhamitgeek likes this.
Emerald Green 2002 Miata
Mods:
Waiting list:
Full vinyl wrap
Events:
LynzeCs bottom bitch.
 Old 06-04-2013, 04:18 PM   #10
Andrewbox's Avatar
new age skeet shooting
 Old 06-04-2013, 04:34 PM   #11
Sideswipe Magnet
Groans: 332
It's disturbing LOL.
Mods:
Waiting list:
Full vinyl wrap
Events:
 Old 06-04-2013, 04:36 PM   #12
Tremmy2's Avatar
Lol... never lived in an apartment with a loud ass neighbor toddler?
 Old 06-06-2013, 10:02 AM   #13
King Scumbag's Avatar
Posts: 2,384   (View Stats)
WTF is the name of that movie? Isn't it "Coming to America" or something. Dude just goes around murking fools lol.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
 Old 06-04-2013, 04:38 PM   #14
Sideswipe Magnet
Groans: 332
Haha nope!
Mods:
Waiting list:
Full vinyl wrap
Events:
 Old 06-04-2013, 04:40 PM   #15
Tremmy2's Avatar
Haha nope!
You my friend are a lucky lucky man...
The Following User Says Thank You to Tremmy2 For This Useful Post:
Kyle Undefined (06-04-2013)
 Old 06-06-2013, 08:47 AM   #16
In SRI mode I left the factory ducting in place to direct fresh cool air at the filter. In CAI mode it probably won't help much.
classybum (06-07-2013)
 Old 06-06-2013, 09:25 AM   #17
Turbojoe's Avatar
Posts: 53   (View Stats)
Turbojoe has a brilliant futureTurbojoe has a brilliant futureTurbojoe has a brilliant futureTurbojoe has a brilliant futureTurbojoe has a brilliant futureTurbojoe has a brilliant futureTurbojoe has a brilliant futureTurbojoe has a brilliant futureTurbojoe has a brilliant futureTurbojoe has a brilliant futureTurbojoe has a brilliant future
I took the entire piece out and it does help bring down the Intake and BAt's as air now passes directly over the intake manifold. Also I have a FMIC and took out the scoop from the hood and you will be amazed how much more heat comes out now. One last thing if you decide to leave that piece of the OEM intake you could get the new Cobb SRI box that utilizes that section and acts as a ram air. Just my 2 cents enjoy the new intake!!
Mods: 35% Tint // OEM Window Visors / 8,000K HID Headlights & Fogs / Ultimate Racing High Flow Cat DP, Catless TP & CBE / CPE Full Replacement Fuel Pump / Cobb SRI, TIP & AP (Custom Tuned by Cobb & VTR / CPE FMIC / Jbarone Stage 2 Shift Kit w/Knob / Ford Motorcraft Transaxle Fluid / NGK Spark Plugs / Sure Torq 3 90 Duro RMM / JBR 88 Duro Side/Pass. Mounts / JBR Rear Sway Bar (Red) / Koni Yellow's W/Corksport Lowering Springs / Hankook V12 tyres / Dashdaq / JBR AP mount.
Turbojoe is offline   Reply With Quote
The Following User Says Thank You to Turbojoe For This Useful Post:
 Old 06-06-2013, 01:02 PM   #18
warlord's Avatar
Posts: 756   (View Stats)
warlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the world
Groaned at 60 Times in 18 Posts
I found the same thing. When I ran a cp-e nano SRI my IAT's were lower with that piece of oem intake ducting removed. Lower BAT's were inconclusive but IAT's were definitely better. The best way to lower IAT's with an SRI is to remove the weather stripping at the rear of the hood. IAT's dropped a solid 4* with that free mod.
Oem intake ducting meaning the one with the round end. That's the one i removed. The square one that clips to the radiator housing I left in. IAT's (under hood temps) got hotter when I removed it so I re installed it.
2018 Audi S6 Prestige. APR Tuned 575 AWHP (current)
2017 Audi A4 APR tuned 315 AWHP (sold)
2014 IS350 (sold)
2013 MS3 Stage2 E85 (sold)
2011 MS3 Stage2 (sold)
warlord is offline   Reply With Quote
The Following User Says Thank You to warlord For This Useful Post:
 Old 06-06-2013, 12:28 PM   #19
Tremmy2's Avatar
God Bless America or some such.
Sent from my HTCONE using Tapatalk 4 Beta
James Barone Power Path SRI / TIP bhamitgeek JAMES BARONE RACING 12 05-19-2013 03:26 PM
Questions before ordering a "Path Stage II Power Intake" levon.mark JAMES BARONE RACING 37 03-26-2013 05:01 PM
JBR Power Path Stage 1 SRI swerv0428 JAMES BARONE RACING 0 03-08-2013 10:54 AM
Stage 2 -Mod Path Dilemma J_Logik Gen2 MS3 General Discussion 40 02-14-2012 05:31 PM
GenPu's factory fuel cut factory tune psi (relative pressure) WRX_Fan_0717 2010 MS3 - ECU Computer Tuning 1 03-09-2011 11:14 PM
Page generated in 0.40586 seconds with 31 queries
