 Old 11-25-2019, 11:22 AM   #1
Default Product Release!! JBR 2007-2013 Mazdaspeed 3 Adjustable Rear Camber Arms!!
Details:
Rear camber arms are often overlooked when it comes to lowering until the rear tires need to be replaced after only 10k miles.
Unfortunately, the stock suspension does not allow for the necessary adjustments to correct this problem.
The JBR Adjustable Rear Camber Arms correct the increased negative camber that results when a vehicle is lowered.
Not only will they aid in camber correction but, they also allow for you to add up to +/-4 degrees of camber for on the street or the track.
The arm is machined entirely from 1.5" thick 6061 billet aluminum then anodized to resist corrosion.
The spherical rod ends are specifically engineered for automotive suspension applications. They eliminate binding and provide the lowest amount of friction possible.
The slotted nylon race and a heat treated and polished hard chrome plated ball make for long lasting smooth operation.
The housing is also heat treated, hard chrome plated 4130 chrome molly steel.
The bushings are 100% polyurethane. Polyurethane bushings are far more durable and outperform rubber bushings hands down.
They're also resistant to chemicals, oils and weathering making them the perfect choice for suspension components.
Applications:
Features:
  • 6061 billet aluminum arm
  • 4130 chrome molly spherical rod ends
  • Polyurethane bushings
JBR Rear Camber Arm Kit Includes:
  • 1 Pair of rear adjustable camber arms
The CorkSport Adjustable Front Camber Arms for the 2006-2007 Mazdaspeed 6 CorkSport CorkSport 7 03-07-2016 02:23 PM
New Product Release!! 2014 & Up CX-5 Adjustable Rear Camber Arms JBR JAMES BARONE RACING 0 10-19-2015 11:42 AM
New Product Release!! Mazda 3, Mazdaspeed 3 and Focus ST Adjustable Rear Toe Arms JBR JAMES BARONE RACING 1 04-29-2015 11:24 AM
New Product Release!! Ford Focus ST Rear Adjustable Camber Arms JBR JAMES BARONE RACING 3 04-23-2015 07:51 PM
Product Release! CorkSport Adjustable Rear Camber Arms CorkSport CorkSport 15 07-31-2012 12:30 PM
Page generated in 0.22782 seconds with 20 queries
