Like Tree24Likes
 Old 08-23-2013, 01:40 AM   #81
Navy_Mech2's Avatar
Posts: 484   (View Stats)
Just ordered 80 duro passenger and tranny mounts and stage 2 catch can with vta kit. Late night shopping FTW!
Sent from my DROID RAZR using Tapatalk 4
KILLAH BUILT
The Following User Says Thank You to Navy_Mech2 For This Useful Post:
jm211 (08-23-2013)
 Old 08-23-2013, 05:46 AM   #82
jm211's Avatar
Posts: 943   (View Stats)
Originally Posted by Funkster777 View Post
I suspect it is from the PMM
Could it be that some of the bolts backed out a bit?
Update on my rmm: 350miles, vibs are pretty much gone. No threadlocker but tested the bolts for tightness a few times, all good. The vibs are too little. Need moar mounts.
 Old 08-23-2013, 06:41 AM   #83
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
~550 miles on the JBR 80 Trilogy, and am really happy with em. It's really surprising how nice it is to drive the 6 when the engine & trans stay where they're supposed to.
The first 70 miles were harsh- vibes and trans whine- totally expected and knew it would be gone soon so didn't stress. Right on 70 miles the first harsh edge eased off and it was amazing- it was like hitting a light switch, the vibes just settled down.
Now, at 550ish miles the trans has quieted down quite a bit- about half the gear whine compared to new, and the only time I get vibes anymore is just off idle when I rev the engine. I'm running the stock idle, bump it up a touch and even that would go away.
For reference, this is on a new engine that still has the balance shaft. I can see the first several hundred miles being pretty harsh if you've done the BSD. At this point tho, I'm already not worried about doing the BSD when this engine gets it's forged bottom end next year...
Yeah, love the Trilogy. It's a good thing....
340hp / 371tq
IamJamen (08-23-2013), SpeedRebirth (08-23-2013)
 Old 08-23-2013, 07:09 AM   #84
Funkster777's Avatar
Posts: 1,254   (View Stats)
Funkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the world
I don't believe so but I will check them this weekend/early next week.
Funkster777
2010 Black Cherry Metallic Mazda 6 DD (well as needed)
2006 Black Mica Mazdaspeed6 Sport
Originally fixed by IL NATOR. Rear Diff, TC, & PS cooler replaced due to MI NATOR. Rebuilding a MS6 one part at a time.
Performance: GTX3076r~Molnar rods~Wiseco pistons~Grimm EBCS~3-bar MAP~Autotech Internals~HTP 3.5" intake~GFB BPV~TR8 intercooler w/2.5" piping~Cobb AP v3~Freak Tune in progress (need to quit breaking things)~eBay catless DP~CS CBE~JBR RMM~ACT HD 6 puck sprung w/prolite~JBR SSP & weight~TWM Stage 2 SS w/BB & boot~Maisonvi Shift Knob~AE Tower Strut Bar~Rear Interior Brace~CP-e Rear Diff mount~Replacement Rear Diff & TC, MD PS cooler, CS Front & Rear Sway Bar~H&R Springs~Bilstein HD shocks~SS brake lines~FI Grounding Kit~EBC Yellows~Potenza RE970AS
Exterior: 6000k HIDs low beams~8000k HIDs fog lights~Luminics Ultra White Bulb high beams~HD lip~Speedline Emblemless Grill~Blacked out rear emblems~Smoked Rear & Side Markers with LEDs~15% back & windshield top tint~35% front~Sharkfin Antenna~Tower II LEDs for parking lights~CAR-LED tails
Interior: UV & purple LEDs~Blackvue DR400G-HD~Escort Redline up high w/mute~NeoPro Link iPod Connection~ProSport Premium Boost Gauge w/Vent Dual gauge pod
Waiting to Install/ Buy: SS clutch, oil pressure gauge, CP-e EWG setup/ Wheels (likely)?, Summer tires?, EVO Brembos?, Meth setup-5/6th port?
Funkster777 is offline   Reply With Quote
 Old 08-23-2013, 01:13 PM   #85
@Funkster777; I suspect something is not correct with your install or you are very sensitive to NVH. Your description is far from the norm. Look things over and let me know if I can help.
Thanks,
Jamie
Dizzy Turbo (08-23-2013)
 Old 08-23-2013, 01:26 PM   #86
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
I got all of @jbarone; mounts, the pmm only has one of the bolts and the nut securing it and I don't have any excessive vibes.
 Old 09-16-2013, 11:10 AM   #87
jucca's Avatar
Posts: 159   (View Stats)
jucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond repute
Got this morning RMM, just came from shop, my mechanic returned stock one, and said it can't be mounted without cutting piece of metal that holds rear part of mount . What I'm missing here? As I read it is pretty straight forward
jucca is offline   Reply With Quote
 Old 09-16-2013, 12:01 PM   #88
There are two tabs at the mounting location on the sub-frame that need to be spread apart and then narrow end of the mount will fit in. Some guys remove them but, with our mount you don't have to. It's a tight fit but it can be done.
 Old 09-16-2013, 12:08 PM   #89
Thanks,
Jamie
I don't believe I am very sensitive to NVH. It was beyond normal from what I've read. @silvapain; and @ Matt Damond; helped put it in. I double checked in later and it was installed correctly. @silvapain; said it was too much during the break-in period. Many others drove with me and it was too much. I removed it (and sold it to anther forum member). I'm running a modificed stock and vibes are significantly less. I only notice them at idle. Sorry it didn't work out.
You have the wriggle the mount to fit but it will work.
Funkster777
The Following 2 Users Say Thank You to Funkster777 For This Useful Post:
dead-zone (03-17-2014), silvapain (09-16-2013)
 Old 09-16-2013, 12:10 PM   #90
jucca's Avatar
Thanks guys, will go again tomorrow.
Cobb AP V3
Stratified tune
Autotech HPFP internals
M2 DP
JBR PowerPath stg II
Sure RMM
Sure Rear Diff Mount
TurboXS 50/50
Grimspeed EBCS
NGK Iridium step colder
Ebay OCC
EGR delete
3BAR MAP w/ Harness
3" CBE w/ high flow mufflers
Eibach -35mm
18x9 JapanRacing JR3 w/ 235/40/18 Kumho KU39
 Old 09-16-2013, 12:15 PM   #91
Police - Grammarhead
Vansquish's Avatar
I've got the 80A RMM, and the NVH is such that at anything above about 2000rpm, things are OK. Below that, the mirrors shake, and there are rattles throughout much of my interior. There's also a LOT of NVH during decel, in-gear at around 2750-3500rpm (driving relatively aggressively), but that part is MOAR RACECAR than anything else, so I'm OK with it.
I simply "tapped" on those metal tabs with a hammer a few times, and now everything fits like a glove.
 Old 09-16-2013, 12:16 PM   #92
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I don't believe I am very sensitive to NVH. It was beyond normal from what I've read. silvapain and @ Matt Damond; helped put it in. I double checked in later and it was installed correctly. silvapain said it was too much during the break-in period. Many others drove with me and it was too much. I removed it (and sold it to anther forum member). I'm running a modificed stock and vibes are significantly less. I only notice them at idle. Sorry it didn't work out.
Very similar to my AWR mounts, from what I remember. Loud. I was hoping for an improvement compared to the AWR's, but these are definitely not much better in that regard.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 09-16-2013, 12:19 PM   #93
I had no vibes at idle and they became worst with rpm. ~3000 was the worse. Everything was shaking in the car: mirrors, change, tools, people. I'm OK with what I'm running now as it is stronger than stock but not too crazy. This is not to knock JBR as his stuff is great. My car appears to react differently to things. It is what it is.
Funkster777
silvapain (09-16-2013), Vansquish (09-16-2013)
 Old 09-16-2013, 02:53 PM   #94
jm211's Avatar
My mount has certain parts in the low band where it vibrates but not bad at all. Kinda disapointed, looks like i need to order the other two.
 Old 09-16-2013, 03:15 PM   #95
shadesofgray19's Avatar
Posts: 794   (View Stats)
Wow, I think JBR are by far better than the AWR mounts. I ran the AWR TMM and PMM with an old school SU RMM for 20k miles and the vibes were horrible. Deceleration felt like the front end was going to vibrate out from under the car. Engine noise was also louder with AWR. Part of that may have been because the AWR TMM bushing was destroyed and the PMM mount did not set the engine level.
My JBR mounts are not even broken in yet, 500 miles on TMM and RMM and only 50 miles on PMM mount and I love them so far. My mirrors vibrate more from my catted DP and CP-E 3" dual exhaust than from the mounts. The engine just feels solidly mounted and shifts are butter smooth.
 Old 09-16-2013, 03:15 PM   #96
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
amoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the world
Groans: 53
Groaned at 31 Times in 22 Posts
It's so damn strange how big of a variance you will get in reports of NVH. I understand everyone has different tolerance but some of these stories are too far apart to think that is the only issue.
How can one guy think it's chattering the fillings out of his teeth and completely un-driveable while another says vibes are barely noticeable after the break in period?
You know.... Moose stuff
amoosenamedhank is offline   Reply With Quote
The Following User Says Thank You to amoosenamedhank For This Useful Post:
6erforlife (09-16-2013)
 Old 09-16-2013, 03:35 PM   #97
6erforlife's Avatar
Posts: 48   (View Stats)
6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of
I agree completely which is why I haven't jumped on these yet. The promise of smooth shifts and a planted motor is mouth watering but at the expense of not being able to bear the vibes has me constantly going back and forth between the pros and cons. "Racecar or Race DailyDriver?"
Liquid Platinum 07 Speed 6 #10177
JBR 80duro RMM, Sure Juggernaut, Sure Dreadnaught
GTX3071, Cobb AP, HTP3.5" Intake, Streetunit TMIC, M2 DP, TurboSmart BOV, Grimmspeed EBCS, AT Internals, GP Werks BSD & Baffle, Denso ITV22, TWM Stage 2, Dashhawk, JBR OCC, JBR TB TIG, SURE IM TIG, VTCS Delete, Ford Transit Oil Filter Conversion, Clean Valves!
LED tail lights, 20% tint, EVO X rims and VG Sharkfin
Big Turbo baby!
6erforlife is offline   Reply With Quote
 Old 09-16-2013, 03:39 PM   #98
I understand the concerns. Personal taste does have some impact. If I did them myself, then I would wonder about install error but I had three guys help that really knew what they were doing. For the record I do have the BSD but my crankshaft was balanced with the rebuild.
Funkster777
 Old 09-16-2013, 03:53 PM   #99
jm211's Avatar
Just a rmm isnt going to kill you. All 3 may.
 Old 09-17-2013, 09:42 AM   #100
The ms6 owners are much more sensitive to vibration because of how smooth the car is to begin with. I think that is why the comments on NVH is so far apart.
Funkster777 (09-17-2013)
 Old 09-17-2013, 09:54 AM   #101
I'd consider a substantive retort to your implication of delicacy, alas I must delay owing to previously scheduled manicure....
340hp / 371tq
 Old 09-17-2013, 09:56 AM   #102
Lots of sandy vaginas in this thread.
Boostin'likeAboss (09-17-2013), himurax13 (09-17-2013)
 Old 09-17-2013, 11:02 AM   #103
Eth Fiend
phate's Avatar
I owned and raced my MS3 for three years before getting my MS6. It had all aftermarket engine mounts, and I can say, without a doubt, the 6 is louder with aftermarket engine mounts than my or any 3 I've ever been in. My 3 was bad. My 6 is worse, by a pretty significant amount.
-06 MS6
Funkster777 (09-17-2013), jm211 (09-19-2013), silvapain (09-17-2013), TiGraySpeed6 (09-17-2013)
 Old 09-17-2013, 11:22 AM   #104
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Default Product Release MAZDASPEED 6 Motor Mounts in Stock!!
I had a TRZ dogbone RMM and TMM on my MS3, and it wasn't as bad as @Funkster777's car with your RMM and PMM. Not even close.
dead-zone (03-17-2014), Funkster777 (09-17-2013)
 Old 09-17-2013, 12:17 PM   #105
Groans: 53
What would be fantastic is if two members with completely contradicting stories lived close enough to compare results.
I would be interested to see if you though the cars who report much less dramatic results shared the same out come.
The Following 3 Users Say Thank You to amoosenamedhank For This Useful Post:
6erforlife (09-17-2013), jm211 (09-19-2013), silvapain (09-17-2013)
 Old 09-17-2013, 12:22 PM   #106
Another local MI NATOR member is putting in 70 duro PMM so we can compare when we meet next.
Funkster777
amoosenamedhank (09-17-2013), TiGraySpeed6 (09-17-2013)
 Old 09-17-2013, 02:44 PM   #107
jucca's Avatar
Finnaly installed today RMM on my MS6. Hope it will vibrate less after braking in. Also noticed exhaust is bit louder now. Is that OK?
Cobb AP V3
Stratified tune
M2 DP
Sure RMM
TurboXS 50/50
Grimspeed EBCS
Ebay OCC
EGR delete
3BAR MAP w/ Harness
Eibach -35mm
 Old 09-17-2013, 05:30 PM   #108
julienjj's Avatar
Posts: 292   (View Stats)
julienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the world
I'm installing My JBR 70 sidemounts this weekend. I have the cp-e rear mount already installed, the car dosent vibrate unless the AC turns on at iddle. Give a nice back massage when it shake.
Current money pits:
2006 MS6 Black mica
CP-E RMM|COBB AP|Test pipe|RX-8 oem wheels|Corksport SRI+TIP|Autotech CDFP|Michelin Pilot Super Sports 235/40ZR18|
|HKS SSQV|COBB Sift weight|Corksport mudflaps (Because rallycar)| JBR 70A Sidemounts|
2008 BMW 135i 6MT
M package|JB4 tune|255/35r18 Michelin PSS|BMW Performance exhaust|
julienjj is offline   Reply With Quote
 Old 09-17-2013, 05:32 PM   #109
cletusb's Avatar
Posts: 488   (View Stats)
Thats happens with just the cp-e rear for me. Assuming that means the 70s don't add much if any vibes
 Old 09-17-2013, 05:49 PM   #110
julienjj's Avatar
The 70s aren't on the car yet !
Current money pits:
2006 MS6 Black mica
2008 BMW 135i 6MT
 Old 09-17-2013, 06:17 PM   #111
cletusb's Avatar
My reading fail. Interested in your results once installed :-)
 Old 09-19-2013, 12:40 PM   #112
IamJamen's Avatar
Posts: 789   (View Stats)
Does anyone know the size/thread/pitch of the bolts used to secure the JBR PMM to the frame rail? I installed the PMM last night and was tightening the rear frame bolt to the spec (70 ft lb) listed in JBR's instructions when I felt it go soft. So either the bolt is letting go or the threads in the frame rail are stripped.
I figure I'll have a spare bolt and a heli-coil/time-sert kit ready to go when I remove the bolt so I don't have any down time. And, no, I did not cross-thread the bolt. Is it just me or does 70 ft lb seem a bit excessive?
@jbarone
 Old 09-19-2013, 01:37 PM   #113
According to the manual bolt(s) to frame rail should be 43.4-58.5 ft-lbf
File Type: jpg Screenshot - 9_19_2013 , 3_33_56 PM.jpg (373.1 KB, 23 views)
340hp / 371tq
Funkster777 (09-20-2013), IamJamen (09-19-2013), phate (09-19-2013)
 Old 09-19-2013, 01:49 PM   #114
IamJamen's Avatar
LOL. Checking the workshop manual would have been smart. I guess I just assumed Mr. Barone's instructions took those values into account. Time to buy a helicoil kit.
Thanks.
Dizzy Turbo likes this.
The Following 2 Users Say Thank You to IamJamen For This Useful Post:
Dizzy Turbo (09-19-2013), Funkster777 (09-20-2013)
 Old 09-19-2013, 01:59 PM   #115
Yeah I broke that bolt and have yet to fix it haha. It did seem excessive. I pmed Jamie tp let him know and he said the spec was fine so I chalked it up to my shitty torque wrench haha
The Following 2 Users Say Thank You to Dizzy Turbo For This Useful Post:
 Old 09-19-2013, 05:23 PM   #116
Stock spec for the stock mount is fine. We chose 12 ft/lbs over for this application and have installed many at this spec without issue.
-Jamie
 Old 09-20-2013, 03:42 PM   #117
Boostin'likeAboss's Avatar
Posts: 1,792   (View Stats)
I have an 88 AWR rmm and the 80 JBR pmm.
just took my first cruise since pmm install and I think the NVH increase wasn't bad all. definite increase but not uncomfortable and I love how it feels along with the added shift performance. Knowing the nvh is gonna die off later kind of has me depressed lol. I still have my balance shaft.
Can't wait to order the TMM and APv3 next month
DON'T CHANGE A THING JAIME!
08 cwp ms3
 Old 09-20-2013, 04:02 PM   #118
+1
I've got ~1,300 on my 80 duro Trilogy now, and love it. It's my daily driver and at 76K miles it feels better now than when I purchased it with 19K miles.
Yes there's a difference between being mounted or being isolated, but I like your version better, and I'm exceptionally pleased with 'em.
340hp / 371tq
 Old 09-20-2013, 08:40 PM   #119
@jbarone
Yeah, I would be careful torquing the frame bolts to 70 lbs as the exact same thing happened to me, but it was my front bolt. Seems odd that those two bolts exceed the stock maximum torque spec by more than 20%, while the others are specified on the low end of the stock torque specs, 45 for the nut on the body and 60 for those on the studs on the motor. If I had looked at the manual I would have torqued them down to 50 lbs and not 70. I usually pick the middle of the broad torque specs in that book.
The Following User Says Thank You to shadesofgray19 For This Useful Post:
IamJamen (09-21-2013)
 Old 09-20-2013, 11:47 PM   #120
julienjj's Avatar
Got my 70 pmm installed today... torqued to 70/lb no problem. I think I will loosen them hower.
Is it just me or the engine is loud as fuck now ? vibration are very low, but the sound level is very high inside the cabin
Current money pits:
2006 MS6 Black mica
2008 BMW 135i 6MT
Dual Product Release!! CorkSport Mazdaspeed 3 Passenger Side Motor Mount and Transmission Insert CorkSport CorkSport 143 04-13-2016 12:00 AM
JBR MAZDASPEED 6 Rear Motor Mounts In Stock!! JBR JAMES BARONE RACING 22 08-28-2013 05:32 AM
JBR MAZDASPEED 3 Transmission Motor Mounts in Stock!! JBR JAMES BARONE RACING 2 03-21-2013 02:14 PM
CP-E Motor Mounts for the Mazdaspeed 3 in stock ! kevin@gripgarage.com Mazdaspeed3/6 General Discussion 0 04-24-2009 02:25 PM
Page generated in 0.60283 seconds with 38 queries
