  • 1 Post By vroom4
 Old 11-19-2012, 04:12 PM   #1
vroom4's Avatar
Posts: 145   (View Stats)
vroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond repute
Groaned at 8 Times in 3 Posts
Default Reviews: RMM, Short Shifter, Solid Bushings, Shift Knob
So I recently purchased all this stuff and installed it on my '12 MS3, thought Id throw a review up after ~3 months or so...
RMM: Extremely easy to install, eliminates firewall destruction on hard decel/accel, tons of vibes for first 1000 miles, not too bad afterwards, With AC on I still get some rattling of my speedo cluster surround while idling and at 2500 RPM...to be expected, just thought Id put the info out there one more time
Short shifter: Again, extremely easy to install, very modifiable throw distance. Not a fan of the installation causing the air box to kind of just...float there...and also not mate up with the rest of the ducting very well. Also, this caused me to pop out of gear under extreme braking during autocross even after adjusting it 1000 different ways in the cabin and in the engine bay. Uninstalled for good.
Solid Mounts: AWESOME. Seriously best mod Ive done to the car. No more limp wobbly shifter.
Shift knob: Hate how you have to "tap" the adapter with the stock shifter, just seams like a poor design. Not sure why the OEM thread couldnt be matched? Also, after 3 months my powdercoat is already wearing through in 4-5 spots. Not very noticably unless you are in the car every day....which I am. Still, combined with the solid shifter mounts, makes a huge difference.
Thats all. Overall Im pretty happy for what I payed and the customer service. I will be ordering a RSB soon My complaints are mostly just to put it out there for other people who may autocross to know not to get the short shifter or you will be uninstalling...or driving with one hand on the shifter.
Sig_Nasty likes this.
vroom4 is offline   Reply With Quote
 Old 11-19-2012, 05:14 PM   #2
Hush's Avatar
Posts: 520   (View Stats)
Hush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the world
Groans: 156
Assume JBR?
Ha, I did the same 3 months ago! If you get an intake, you can get rid of the 'box' and the little gromet 'rests', then go back and use the SSP.
Chrome molly RMM? I got the 70 duro, and was very pleased, afterwards saw most get the chrome molly. I am only DD, though. No more missed shifts, at least that are not my fault. May get chrome molly someday.
RSB I installed a couple of months ago, deffinitly tightened up under steer.
Hush is offline   Reply With Quote
 Old 11-19-2012, 05:21 PM   #3
ABSpeed3's Avatar
Posts: 698   (View Stats)
ABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the world
Groans: 133
Groaned at 7 Times in 4 Posts
I have had my short shift plate for years, one of the first mods on my car and I've never had any issues daily driving or racing.
I am disappointed with the finish of my shift knob though, the coating is chipping off mine as well, it only lasted about 6 months if that. Didn't think install was bad, and love the way it feels when I'm driving.
08.5 CWP MS3 GT
PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC
ABSpeed3 is offline   Reply With Quote
 Old 11-19-2012, 05:42 PM   #4
Hush's Avatar
Groans: 156
For Auto-x, how do you like the MS3 shifting in general?
I have never auto-x, but curious what impressions of the throw, and ease of getting in gear. Even with the bushings, the feal is very notchy, like you you are def moving linkage. I also wonder if heavy knob hurts or helps in this.
 Old 11-19-2012, 10:35 PM   #5
ABSpeed3's Avatar
Groans: 133
I am by no means great at auto-x, but that was mostly due to my all season tires and crap suspension. As far as the heavy knob/bushings/ssp goes I love it. It def needs to be figured out and takes some getting used to, but I can move through the gears like butter.
08.5 CWP MS3 GT
The Following User Says Thank You to ABSpeed3 For This Useful Post:
Hush (11-19-2012)
 Old 11-20-2012, 07:21 PM   #6
vroom4's Avatar
Ok so right there you just proved why your short shifter wasnt a problem...you arent good at autox haha. Until you are a decent racer with good tires, you will never stop hard enough to bounce it out of gear...Also, who knows the difference between generations.
Also, I cant change intakes or I would. It moves me out of my current class.
 Old 01-02-2013, 09:27 AM   #7
RACER_X's Avatar
Posts: 266   (View Stats)
RACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the world
Groaned at 31 Times in 14 Posts
Just my $.02
SSP is well worth the $ and effort
Bushings not so much, the rubber grommets are compressed very hard and the sleeve limits how tight it can go anyways, main reason I didn't was to use the bushings for the air box
ΜΟΛΩΝ ΛΑΒΕ
2014 Honda Grom 125cc's of FURY! now more furious w/ 181cc's
2015 F150 Platinum
2012 MS3 Liquid Silver
Autotech HPFP
Cobb AP & CBE
Corksport FTB
Enkei Raijin 18x8 et45
JBR 3.0WP, RSB, RMM & SSP II
Stratified Tune
TrackMasters hood prop and ecu reloc.
TurboSmart BOV
RACER_X is offline   Reply With Quote
 Old 01-31-2013, 02:49 PM   #8
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Just put in the solid shifter bushings today, night and day difference in shifter feel. My bushings metal components were bent up when I took them out! No wonder the 1st-2nd shift was messed up.
Overall, way worth the 25 dollars spent. This was accompanied by an already installed 70 duro RMM, FOCO Trans Fluid, and a modaddiction shift knob; shifts fantastic now!
JBR (01-31-2013)
Another review jbarone short shift plate, bushings, and knob. bohica17 2010 MS3 - Engine, Transmission & Driveline 18 02-16-2011 07:45 AM
Page generated in 0.31413 seconds with 24 queries
