 Old 07-08-2014, 11:21 PM   #1
blake0521's Avatar
Posts: 302   (View Stats)
blake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud of
Default Rmm issues
So went to install my rmm today. When really smoothly minus the factory bolt through the bushing. For some reason my bolt has a nut that you have to thread in which I am pretty sure other speed 3's don't have from looking at how to threads and vids. Anyone have sudgestions for me? I am pretty sure that nut was just a getto rig mod from the last owner but I am not sure. Also can I move my car to a shop with out the rmm secured to the frame?
2010 Mazda Speed3-
Mods:
Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell
Next up: tune.
blake0521 is offline   Reply With Quote
 Old 07-08-2014, 11:41 PM   #2
kby
kby's Avatar
Posts: 653   (View Stats)
kby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the world
Groans: 31
Looks like someone cross-threaded/stripped the bolt that was built into the frame and just put a nut on top instead of re-threading it.
If possible just reattach it and baby it to get it fixed. Don't drive without a RMM.
kby is offline   Reply With Quote
The Following User Says Thank You to kby For This Useful Post:
Easter Bunny (07-09-2014)
 Old 07-08-2014, 11:42 PM   #3
blake0521's Avatar
So I would just have to get it re threaded? Next problem is that I do not have a mazda dealership near by..
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 07-09-2014, 12:09 AM   #4
King Scumbag's Avatar
Posts: 2,384   (View Stats)
I would take a flashlight and inspect the threads in that fixed blind nut in the frame. like @kby; said it could be stripped out. Or the previous over may have misplaced the OEM bolt and ghetto rigged that bolt in there stocking out or something. After inspecting the threads if they don't look like there all chewed up, jacked up and cross threaded I would try and find out what the specs of that OEM bolt are and try and get that bitch to work.
The nut on top idea is a good temp fix and could be OK. But i wouldn't know for sure. Im gonna go with its NOT good but thats just my .02.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
The Following 3 Users Say Thank You to King Scumbag For This Useful Post:
kby (07-09-2014), Mauro_Penguin (07-09-2014), pzr2874 (07-09-2014)
 Old 07-09-2014, 12:13 AM   #5
blake0521's Avatar
Hopefully jbr will chime in on this! I will check it out in the morning/ order a bolt from mazda.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 07-09-2014, 12:16 AM   #6
I think its just a matter of its not normal.. End of story haha. I wouldn't go through the trouble of ordering the bolt through mazda when you could probably research the specs on that bolt itself and pick one up for cheap at a hardware store.
Im about 100% sure that bolt is not the OEM bolt.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 07-09-2014, 12:28 AM   #7
blake0521's Avatar
If the threads are mangled what are my options? How someone can rethread em?
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 07-09-2014, 12:57 AM   #8
If its cross threaded throw your ghetto rig back in for the time being. Get the right bolt. Take it easy and Take it to an auto shop near by. They should be able rethread it so you can pop the right bolt in there.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 07-09-2014, 01:01 AM   #9
blake0521's Avatar
What's my best bet to find bolt specs? Call Mazda?
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 07-09-2014, 01:33 AM   #10
Question, where is the bolt that mount had in it that mounts the RMM to the trans bracket? It should have threaded right into the other side of the RMM pictured in the OP.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 07-09-2014, 05:40 AM   #11
blake0521's Avatar
The picture is of the stock mount and the bolt is the bolt that came out of the bushing/ subframe side not the rmm/trans mount side
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 07-09-2014, 05:46 AM   #12
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
I wouldn't source a Home Depot bolt for sure, IF anything take it to a Fastenal.
 Old 07-09-2014, 09:29 AM   #13
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Get at the very least a grade 6 bolt. Remember that thing is holding your motor to the frame... What you should do IF those threads are stripped is get a bolt and 2 nuts. Tighten the first nut down and then the second (second could be a lock nut). Good luck!
 Old 07-09-2014, 10:34 AM   #14
I asked that question @blake0521; because I'm pretty sure the bolt that is used to attach the OEM RMM to the trans bracket are the same exact specs. With maybe a minor difference in length.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 07-09-2014, 10:39 AM   #15
Gr8Speed's Avatar
Don't quote me on this, but I think they may be a different thread pitch. Or I may be thinking of a different bolt. I remember something weird where I started the wrong bolt into the wrong hole and it started cross threading.
 Old 07-09-2014, 03:53 PM   #16
Yousuf's Avatar
Posts: 1,398   (View Stats)
Groans: 128
This just isn't one of those times where ghetto-rigging is your only option left, do what these guys are telling you first..
Let us know what happens
Mod-bug's back...
 Old 07-09-2014, 07:00 PM   #17
blake0521's Avatar
So I am going to write a how to on this because that was so shitty hahaha. So I got a grade 8 bolt and ran it through the super blown out threads and into a nut with red lock tight. Then torqued to 70 ft lbs and called it a day. The threads actully held the new bolt but since the were fucked up I put an extra nut on there for security. Will be re torquing it next week after my meet and will report if I lost any tension.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 07-10-2014, 06:26 AM   #18
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
you could have drilled out the mangled sub frame threads and put in a helicoil.
Also the previous owner put in RMM inserts, the blue pieces are not stock. Unless you put those in.
I know it's too late for you but to have the info out there @Travisms3; had to replace that bolt this past weekend and will know the specs. And after that experience he can tell you first hand that, yes, you can drive without a rmm bolt.
Blue Pu.
 Old 07-10-2014, 07:45 AM   #19
Travisms3's Avatar
Posts: 417   (View Stats)
Travisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the world
M12, 1.25 thread, 2.5 or 3 inch long.
I don't recommend driving with out the rmm. It feels like your engine is coming through the fire wall, but I did it unknowingly for a couple weeks.
Travisms3 is offline   Reply With Quote
The Following User Says Thank You to Travisms3 For This Useful Post:
anavrinIV (07-10-2014)
 Old 07-10-2014, 07:52 AM   #20
anavrinIV's Avatar
Groans: 63
to be fair I think it was there at least in some way for most of that time. You said when you came over that it felt a lot worse that day, I'm guessing you had just lost that bolt at that point. But still you made it to my place on 1.5 mounts so that's impressive.
Blue Pu.
 Old 07-10-2014, 08:13 AM   #21
Travisms3's Avatar
No I found the bolt in my tool box so it was off since the turbo swap. I just think the pmm started to deteriorate more
 Old 07-10-2014, 08:27 AM   #22
anavrinIV's Avatar
Groans: 63
Damn. Welp...that explains a lot.
Blue Pu.
 Old 07-10-2014, 09:19 AM   #23
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
i bet he lost the OEM bolt and used that bolt which is likely thinner and went right through the frame and he used a nut like he said jsut to stock out, get the proper thread bolt and try to thread it into the frame like its supposed to be
EDIT: i forgot to mention that that thinner bolt moving around in the good threads could have damaged the threads in some way and honestly this thread should be in the general support section
Mauro_Penguin (07-10-2014)
 Old 07-10-2014, 03:26 PM   #24
Gr8Speed's Avatar
One of those bolts from something down there (can't remember what) fits, but is the wrong thread. It won't snug or anything, but goes through and "threads" in.
Ford issues six recalls covering 101,000 vehicles for multiple issues Haltech Automotive News 0 07-08-2014 01:50 PM
Possible DBW Issues helmetface Mazdaspeed3/6 General Discussion 39 01-08-2013 03:09 PM
DO Stg 1 kit issues Chimmike MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 32 01-16-2012 11:20 AM
I have a few issues rtabagaboy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 05-09-2009 11:43 AM
MS6 Issues FantasmoNegro MazdaSpeed 3/6 - ECU Computer Tuning 5 04-17-2009 04:51 PM
Page generated in 0.45991 seconds with 29 queries
