 Old 07-02-2012, 01:18 AM   #1
deek's Avatar
Posts: 687   (View Stats)
deek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the world
Originally Posted by DFWSpeed View Post
So 2 days ago I was adjusting the way my JBR shift knob faced. Now the problem is, I pulled off the knob, but the nut that fits into the knob is stuck inside. I'll attach a picture to clarify.
I'm just trying to figure out how in the hell to get this thing out without damaging the threads. Lol. Attachment 62787
I got mine out today, fair warning attempt at own risk. I was able to do this without damaging the threads. If you do damage threads just order new adapter for 15 bucks.
Take flat head screw driver that is thick enough to fit into adapter but get stuck if you push it in, then hammer it into place, turn counter clockwise and out pops adapter. If you wrap flat head with tape or cloth you may be able to pull it out with out too much damage to inner threads. Try adapter over shifter, if tou can turn smooth then your good. Again worse case scenario you buy new adapter. But you have full function of shift knob again.
2010 Dodge Ram 1500
6 inch pro comp lift, 35x12.50x20 pro comp tires, pro comp 7089 wheels 20x9.5
deek is offline   Reply With Quote
The Following User Says Thank You to deek For This Useful Post:
JBR (07-05-2012)
Page generated in 0.22753 seconds with 22 queries
