 Old 06-03-2012, 01:28 PM   #1
DFWSpeed's Avatar
Posts: 81   (View Stats)
DFWSpeed has a reputation beyond reputeDFWSpeed has a reputation beyond reputeDFWSpeed has a reputation beyond reputeDFWSpeed has a reputation beyond reputeDFWSpeed has a reputation beyond reputeDFWSpeed has a reputation beyond reputeDFWSpeed has a reputation beyond reputeDFWSpeed has a reputation beyond reputeDFWSpeed has a reputation beyond reputeDFWSpeed has a reputation beyond reputeDFWSpeed has a reputation beyond repute
Default Shift knob
So 2 days ago I was adjusting the way my JBR shift knob faced. Now the problem is, I pulled off the knob, but the nut that fits into the knob is stuck inside. I'll attach a picture to clarify.
I'm just trying to figure out how in the hell to get this thing out without damaging the threads. Lol. ImageUploadedByTapatalk1338751680.508533.jpg
2010 Mazdaspeed 3
E30 | Cp-e TMIC | Cp-e HPFP | CS SRI/TIP | JBR RMM | Ebay DP | UR Catless TP | UR Cat-back | Turbosmart Dual Port | Privat Akzent 18x8 +46 | JBR SSP & Shift knob |
FREEKTUNE in progress
1993 Suzuki VS800 Intruder Bobber
DFWSpeed is offline   Reply With Quote
 Old 06-03-2012, 01:31 PM   #2
McGee's Avatar
Posts: 402   (View Stats)
McGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the world
Groans: 27
Just tighten the knob on the shifter to embed new threads into the nut.
Don't tighten it too much or that bitch will be stuck.
Then screw the knob back off and nut should be in place.
Worked for me
McGee is offline   Reply With Quote
 Old 06-03-2012, 02:28 PM   #3
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
Or take a screw that is deep enough and screw it into the nut. Holding the knob in place turn the screw and the nut will come right out.
______________________
Built By NATOR
Tons of Ricer Mods
 Old 06-03-2012, 05:15 PM   #4
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
good luck. same thing happened to me and the only way I could get it out was to loctite a bolt into the aluminum adapter. Unfortunately I also loctited the jamb nut in, so my knob is now worthless.
Blue Pu.
 Old 06-03-2012, 05:58 PM   #5
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Ummmm...take a proper sized Allen key and unscrew it?!
EDIT: I was talking bought jamb nut, my bad
 Old 06-27-2012, 06:05 PM   #6
deek's Avatar
Posts: 687   (View Stats)
deek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the world
This happened to mine as well, adapter is stuck inside of knob , still can install on car but no longer can adjust (straighten diagram). Tried reinstalling on car and loosen off, gonna try to buy long bolt, then vice grip bolt and spin assembly.
@jbarone got any tips or tricks to get it out?
2010 Dodge Ram 1500
6 inch pro comp lift, 35x12.50x20 pro comp tires, pro comp 7089 wheels 20x9.5
deek is offline   Reply With Quote
 Old 06-27-2012, 06:15 PM   #7
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
Bake it. The heat should break up the glue. Works with super glue, at least.
Sent from my LG-MS690 using Tapatalk 2
it's fun to do bad things
 Old 07-02-2012, 01:18 AM   #8
deek's Avatar
I'm just trying to figure out how in the hell to get this thing out without damaging the threads. Lol. Attachment 62787
I got mine out today, fair warning attempt at own risk. I was able to do this without damaging the threads. If you do damage threads just order new adapter for 15 bucks.
Take flat head screw driver that is thick enough to fit into adapter but get stuck if you push it in, then hammer it into place, turn counter clockwise and out pops adapter. If you wrap flat head with tape or cloth you may be able to pull it out with out too much damage to inner threads. Try adapter over shifter, if tou can turn smooth then your good. Again worse case scenario you buy new adapter. But you have full function of shift knob again.
2010 Dodge Ram 1500
The Following User Says Thank You to deek For This Useful Post:
JBR (07-05-2012)
Page generated in 0.29272 seconds with 27 queries
