 Old 03-18-2010, 08:02 PM   #1
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Default SSP Review Speed 6
So I'm on my iPhone and didn't want to write this whole thing out, so I did a lazy thing and copy and pastedthis from the PM I sent Jamie early (when I was on my computer). Anyways...
Hey, just wanted to give a minor review and say you were pretty much dead on with what you said about the TWM shifter. It is a little more difficult to push into gear, but to be honest, at first, I didn't think I had the damn car in gear it was so short!!!
I did have one issue where shifting into third (was all the way in) and I let the clutch out it sounded like it was grinding, pushed clutch back in and let it out, no problems. Dunno what that was about, not worried, don't think it had anything to do with your product.
All in all I am VERY impressed, extremely happy as of yet, and since I don't think I'll be getting rid of it, I might, in a few weeks order one for Stealth, the guy I said I would give it to if I didn't like it.
Thanks again!!!!
Btw, I have a stage 2 TWM sts for those who were wondering.
The shift knob is great, and noticeably heavier than the twm one I had (don't remember which one, it's trapezoidal if u look at the cross section).
I'll write a further review after i've had it on a week or so and have some more miles under its belt.
The Following 3 Users Say Thank You to tbot For This Useful Post:
JBR (03-19-2010), MPSdriver (03-19-2010), raterry (03-18-2010)
 Old 03-19-2010, 05:21 AM   #2
I'm thrilled you're happy with it. Sounds like that third gear issue was some sort of fluke. I'm very interested in your thoughts after you've had for a while.
Thanks Tbot!!
Jamie
tbot (03-19-2010)
 Old 03-19-2010, 05:50 AM   #3
Alpha's Avatar
Posts: 3,711   (View Stats)
Stage 2 AND the SSP? Man, that has to be like an inch of travel from 1st to 2nd. Haha!
JBR (03-19-2010)
 Old 03-19-2010, 06:47 AM   #4
MPSdriver's Avatar
Posts: 136   (View Stats)
MPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the world
Thanks for the review, hopefully you'll have good xp's to report on in the future. I'm considering this SSP as well in combination with a TWM SS stage 2.
I thought that the E4 knob was about the same weight as a desert eagle TWM knob (600 grams)
You got this knob right?
MPSdriver is offline   Reply With Quote
The Following User Says Thank You to MPSdriver For This Useful Post:
JBR (03-19-2010)
 Old 03-19-2010, 08:38 AM   #5
tbot's Avatar
Groans: 40
I did have that one ^^ yes (sorry I couldn't remember the name). But after holding both in each hand and one at a time in one hand, I could tell the E4 knob was heavier.
As far as the install goes, his directions/instructions are about as straight forward and simple as possible. This has been BY FAR the easiest/simplest mod I've done to my car with some of the most noticeable improvements. And I was thuroughly impressed that EVERYTHING you need to do this comes with his kit (well besides the tools...Jamie you wanna change that too?!? hehe j/k)
So far the biggest thing I've had to do is retrain my "muscle memory" for when to STOP shifting. I'm still used to traveling further, and there are times where I can feel (at least I think) the shift lever bending (or giving).
Like I said in the first post, I still don't think I'm all the way in gear some of the time and expect the motor to rev up and nothing happen which in turn surprises me with my car taking off!!!
My HAPPIEST thing about this is that I'm no longer missing 3rd gear shifts. I would for some reason before not quite get it in gear (wouldn't travel any further) and have to pull it back into neutral and put it back in gear for it to go. Jamie's SSP has COMPLETELY remedied that issue all together. It feels solid now!
Again, reminder to those that have a TWM sts, going from neutral to the LEFT (as in towards first/second and reverse) didn't change at all, still easy, stock feeling if you will. But going to the right (as in towards 5th/6th) is stiffer. Shifting from 5th to 6th is stiff as well and takes a noticeable amount more effort to make that shift happen. Granted on the other hand, going from 6th DOWN to 5th is relatively easy, not sure what gives with that, but it is what it is I guess.
45 minute drive to work today (fucking snow!!!) I was loving life, almost glad the highways were a mess, gave me a chance to shift more often So yeah, I really like it.
The Following 2 Users Say Thank You to tbot For This Useful Post:
JBR (03-19-2010), MPSdriver (03-22-2010)
 Old 03-19-2010, 08:59 AM   #6
tbot has just provided some very valuable information. I have no first hand experience with the TWM Stage 2 and the shift plate together, but I do with the TWM Stage 1 and the shift plate combination.
One thing I noticed while designing the shift plate for the MS6 was that the stock shifting feel is much softer and smoother than the MS3. More luxurious if you will. So I think you MS6 owners are in for a little more of a shock when switching over from stock to a short shift plate. What was very obvious to me when I tested it with and with out the TWM Stage 1 was that it felt better and much easier then the MS3 with the shift plate. I think that you'll find that it's something that you'll get accustomed to very easily and quickly.
Thanks,
Jamie
raterry (03-24-2010)
 Old 03-19-2010, 09:02 AM   #7
tbot's Avatar
Groans: 40
Hey!!! Right on!!! Glad I could participate in the "valuable information providing" club on here
 Old 03-23-2010, 03:30 PM   #8
meelo88's Avatar
Posts: 557   (View Stats)
meelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the world
very interesting....i have the TWM stage 1.....i'll have to sleep on this for a little bit to see if I want to do this or not...
*sleep*
"If I can't fix it, it was meant to be broken"
[SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey
TUNED BY NISHAN
POWER
SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG
COSMETIC AND AUDIO
Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4
meelo88 is offline   Reply With Quote
The Following User Says Thank You to meelo88 For This Useful Post:
JBR (03-23-2010)
 Old 03-23-2010, 03:55 PM   #9
tbot's Avatar
Groans: 40
^^ I honestly think you would be alright. I just found out that apparently there's some adjustments that can be made, but not sure what it is exactly, but it might help my 5th and 6th gear issue (which I dont' think is much at all).
In a follow up. I will say that I love it! The only problem is like I said retraining my muscle memory to where to move the shifter for gears (I go out of first to go into neutral and put it in second...seriously, the short of throws) and if I'm in neutral on the highway and going into a gear, it takes a little longer cause its not quite the same feel now.
Over all tho, couldn't be happier. Its what I was expecting when I got the STS from TWM. Oh, and btw, no missed gears as of yet. Before I would somehow manage to miss 3rd all the time, have yet to since the SSP install.
Thanks again Jamie!
JBR (03-23-2010), meelo88 (03-23-2010)
 Old 03-23-2010, 05:30 PM   #10
meelo88's Avatar
fair enough, i'll put this on my list of things to do/get....first things first some suspension parts...
TUNED BY NISHAN
POWER
COSMETIC AND AUDIO
JBR (03-23-2010)
Review: Need For Speed Shift fills gap between Forza 3 and GT5 Haltech Automotive News 1 01-29-2010 12:24 PM
Review: 2009 Dodge Challenger SRT8 six-speed reveals its true character Haltech Automotive News 0 11-16-2009 10:30 AM
Review: 2010 Bentley GTC Speed is like Heaven. Only better. Haltech Automotive News 0 07-28-2009 10:20 AM
Review: 2010 Lincoln MKS EcoBoost offers big American luxury with straight line speed Haltech Automotive News 0 07-17-2009 10:10 AM
Page generated in 0.31341 seconds with 25 queries
