  • 1 Post By wes3id
  • 1 Post By JBR
 Old 03-07-2016, 09:56 AM   #1
wes3id's Avatar
Posts: 611   (View Stats)
wes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the world
Default THANK YOU JBR
I recently ordered a JBR 3.5" wide path intake and some of the clamps included were too small to use, but luckily i had a few extras on hand. I figured i should just let them know about the issue for future buyers. I wrote them an email letting them know and included pics of the clamps and setup...I did not ask for replacement clamps or anything. I was very quickly responded to about the issue and will be receiving the correct clamps soon. Their customer service is great and it just goes to show that they do care about their products, customers, and reputation as a good business. Thanks again JBR
JBR likes this.
07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS
K04 93 FREEKTUNED 271 AWHP/296TQ
K04 E85 FREEKTUNED 309 AWHP/360TQ
BNR S3 93 FREEKTUNED 336 AWHP/360TQ
BNR S3 E85 FREEKTUNED 375 AWHP/376TQ
wes3id is offline   Reply With Quote
The Following 8 Users Say Thank You to wes3id For This Useful Post:
ALPINEST4RS (03-09-2016), Code Monkey (03-09-2016), Gr8Speed (03-07-2016), Hush (03-09-2016), JBR (03-22-2016), Mauro_Penguin (03-07-2016), MS3Shadow (03-07-2016), Vansquish (03-09-2016)
 Old 03-09-2016, 08:51 AM   #2
Our apologies for the mix up. The correct clamps will ship today.
wes3id likes this.
Code Monkey (03-09-2016), Hush (03-09-2016), Vansquish (03-09-2016), wes3id (03-09-2016)
 Old 03-09-2016, 11:01 AM   #3
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
Groaned at 8 Times in 3 Posts
I had the same issue. Where do I send an email? I just purchased mine last week.
 Old 03-09-2016, 12:20 PM   #4
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
Website > Contact section > email address.
The Following 4 Users Say Thank You to WAMBUSHHHH! For This Useful Post:
JBR (03-10-2016), MD1032 (03-16-2016), MS3Shadow (03-09-2016), SofaKingAwesome (03-09-2016)
Page generated in 0.25111 seconds with 22 queries
