  • 1 Post By tddvrrn
 Old 03-18-2012, 10:26 AM   #1
kgb
kgb's Avatar
Posts: 808   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 88
Default What am I doing wrong...
So I am trying to install the EGR plug and I cannot get it to install flush. I have almost a quarter inch gap....any suggestions?
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
kgb is offline   Reply With Quote
 Old 03-18-2012, 10:28 AM   #2
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
pics? how you installed?
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
TexasSpeed3 is offline   Reply With Quote
 Old 03-18-2012, 10:30 AM   #3
ColonR's Avatar
Posts: 1,453   (View Stats)
ColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the world
pics
1992 miata, track beast here I come with 2 bride seats!! (current)
3076r speed6 owner (traded)
2000 camaro 415rwhp thru midwest chassis fab (sold)
ColonR is offline   Reply With Quote
 Old 03-18-2012, 10:48 AM   #4
kgb
kgb's Avatar
Groans: 88
Oh yes...pics
Using the JBR instructions for this, I put some RTV on the threads then tried to get it flush...
 Old 03-18-2012, 10:53 AM   #5
Groans: 273
@jbarone
 Old 03-18-2012, 11:04 AM   #6
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Mine didn't want to sit in flush either fwiw. Until I torqued it down without realizing my tq wrench was not set properly ftl. Now it sits flush.
I didn't put much if any muscle into it but I think it was more than 16ft lbs to get it to sit flush. Just glad I didn't break it.
The Following 2 Users Say Thank You to SLOWHATCH For This Useful Post:
kgb (03-18-2012), TexasSpeed3 (03-18-2012)
 Old 03-18-2012, 11:56 AM   #7
laxplayermjd's Avatar
Posts: 779   (View Stats)
laxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the world
the threads are probably bottomed out? the rtv is goin to seal it
2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune
laxplayermjd is offline   Reply With Quote
The Following User Says Thank You to laxplayermjd For This Useful Post:
kgb (03-18-2012)
 Old 03-18-2012, 12:09 PM   #8
kgb
kgb's Avatar
Groans: 88
That's what I was thinking after comparing the original egr's plug to JBR's plug. I'm going to wait a bit longer for other ideas before I tighten and RTV it.
I attached picture to show the differences... The first two shows the gap but the plugs are now the same size and the last one shows where the JBR plug has to be to tighten flush; but it's now longer.
 Old 03-18-2012, 05:09 PM   #9
kgb
kgb's Avatar
Groans: 88
Well...I RTV cream pied the plug and went for a short drive. Everything seems fine; STFT are normal for now. I'm getting my autotech internals installed tomorrow but not by me. With the difficulties I had with the EGR delete it's probably a good idea.
Next up AP and Guardian Angel...
The Following 3 Users Say Thank You to kgb For This Useful Post:
Lex (04-04-2012), SLOWHATCH (03-18-2012), TexasSpeed3 (03-18-2012)
 Old 03-18-2012, 10:12 PM   #10
It's fine, it's not suppose to be flush. Once it's tight, it's tight. The RTV is for extra piece of mind.
Thanks,
Jamie
Found a pic, not flush.
deadlandxtreme (03-19-2012), JTMS3 (03-20-2012), kgb (03-19-2012), rigor (03-18-2012), silentwolf8 (03-30-2012), TexasSpeed3 (03-19-2012)
 Old 03-19-2012, 10:08 PM   #11
kgb
kgb's Avatar
Groans: 88
That's all I needed to here....
Other than that little hiccup, the install would have taken only about an hour to complete.
Loving it!
Thanks JBR
The Following User Says Thank You to kgb For This Useful Post:
JBR (03-20-2012)
 Old 03-19-2012, 11:02 PM   #12
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
*hear?
glad it worked out. sometimes you just need to hear that it's gonna be ok.
kgb likes this.
The Following User Says Thank You to tddvrrn For This Useful Post:
kgb (03-20-2012)
 Old 03-30-2012, 03:34 PM   #13
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
On a slightly different note, is it possible to install the block-off plate and put the EGR tube back on instead of using the plug? I only ask because come inspection time, I've heard of some places doing a "visual" inspection just to make sure it's there.
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
 Old 03-30-2012, 06:57 PM   #14
silentwolf8's Avatar
Posts: 1,986   (View Stats)
silentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the world
Groans: 44
I wouldnt see y not. But then u have a direct flow of air to ur IM. So any type of debri would go directly into ur valves and thats no bueno
ZOOM ZOOM left the Room
2013 SPW STi // COBB SRI w/Box // COBB BPV // UR Catless DP// UR CBE // COBB Lowering Springs // COBB Sway Bars // +1 NGK // DW65c FP
AWDTuning Tuned
silentwolf8 is offline   Reply With Quote
 Old 04-04-2012, 08:52 AM   #15
Yes absolutely! Stealth EGR delete. Use a little red RTV on either side of the block off plate and slip it in between the tube flange and the head. Leave the stock gasket on the tube flange side as well. Done!!
skeurton (04-04-2012)
Something is wrong Coats MazdaSpeed 3/6 - ECU Computer Tuning 11 07-05-2011 03:15 PM
Something wrong thanox2 Mazdaspeed3/6 General Discussion 0 04-21-2009 09:25 PM
Page generated in 0.35946 seconds with 29 queries
