 Old 04-07-2010, 06:22 PM   #1
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
Default 18 psi DynoJet Dyno Sheets
This was tuned at 20psi on a mustang dyno. On this dynojet it was only boosting 18psi.
John Shafer at akuma motorsports does the tuning because he is the best. Contact info for him is in my signature.
The one line were it looks erased was because the wheels were spinning on the dyno so he erases the weird squiggly line. second run stuck because the tires were hot.
I wanna thank Mazda For supplying me with the diamond cut 09 mazda rods.
Thanks mazda
STOCK MOTOR
STOCK CLUTCH
The Following 14 Users Say Thank You to For This Useful Post:
AndyMS3 (04-08-2010), BUNGEEZZ (04-08-2010), DaleNixon (04-07-2010), djuosnteisn (04-08-2010), Fobio (04-07-2010), FreeFlyFreak (04-08-2010), gsrtype1 (04-08-2010), IshiKage (04-07-2010), madvillain (04-07-2010), PaPaSpeed (04-07-2010), RGV_MS3 (04-09-2010), Sacrilicious (04-08-2010), snailD (04-07-2010), stefan (04-07-2010)
 Old 04-07-2010, 06:26 PM   #2
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Impressive! I've gotta get up to Akuma for a tune.
Frequentflyer is offline   Reply With Quote
 Old 04-07-2010, 06:28 PM   #3
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Nice Brian. Still on AP right? Any plans to make the switch to SB?
 Old 04-07-2010, 06:31 PM   #4
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
very nice, ive got to get back to pa for a ride,lol
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
 Old 04-07-2010, 06:34 PM   #5
18psiWhiteMS3
Lurkers
Posts: n/a
this is old dyno from last year. I just moved it to the NEW BIG turbo Section Haltech Created
The Following 2 Users Say Thank You to For This Useful Post:
djuosnteisn (04-08-2010), kilik2 (04-09-2010)
 Old 04-07-2010, 06:37 PM   #6
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
Ok, I'm impressed. That is a very good uncorrected run. That 3076 is definitely moving some air through the motor! I think that dip around 6k rpm is due to the cam timing dropping to zero and back up to +4 deg as in the stock map. I have mine set to +10 deg at that zero point with no dip in power. Did your tuner look at/modify the VVT table?
FORZDA 1 is offline   Reply With Quote
 Old 04-07-2010, 06:47 PM   #7
jmonterr's Avatar
Posts: 45   (View Stats)
jmonterr will become famous soon enough
sick
jmonterr is offline   Reply With Quote
 Old 04-07-2010, 06:50 PM   #8
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
Does your car make that silly external wastegate sound? Jealoussss!
DaleNixon is offline   Reply With Quote
 Old 04-07-2010, 07:20 PM   #9
18psiWhiteMS3
Lurkers
Posts: n/a
when it was on the mustang dyno there was no dip at all but that is interesting
 Old 04-07-2010, 07:24 PM   #10
[MSF STIG]
FORZDA 1's Avatar
Well then I suppose it could be a bit more wheel slip at the higher power levels....
 Old 04-07-2010, 10:12 PM   #11
You mentioned you have better control of the throttle ... when are you dynoing that?
 Old 04-08-2010, 08:10 AM   #12
18psiWhiteMS3
Lurkers
Posts: n/a
i dunno man. the place i get dynoed at has moved to a new location and there dyno is not in the ground yet. i might try and find someone else but the guy i usually go to charges me 40 bucks cause he loves my car LOL
i really wanna dyno tomorrow cause it will be in the 50's
Last edited by 18psiWhiteMS3; 04-08-2010 at 08:10 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-08-2010, 09:44 AM   #13
ToledoSpeed3's Avatar
Posts: 244   (View Stats)
ToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the world
I just noticed this in the VVT table recently and thought it was strange that they shut down the overlap and then have it go back up to +4 at higher RPM. Nice little speed bump they put in there! I was tempted to change it to +4 where the zeros were.
ToledoSpeed3
09 MazdaSpeed3 GT, True Red
ToledoSpeed3 is offline   Reply With Quote
 Old 04-08-2010, 09:59 AM   #14
ALL-IN.
AndyMS3's Avatar
Posts: 671   (View Stats)
AndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the world
Groans: 30
Wicked numbers. Now where's the video!?
AndyMS3 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/18-psi-dynojet-dyno-sheets-53338/
MSP3 == LOLz - Page 12 - 8th Generation Honda Civic Forum This thread Refback 05-16-2010 10:46 AM
MSP3 == LOLz - Page 11 - 8th Generation Honda Civic Forum This thread Pingback 05-16-2010 10:33 AM
My DynoJet DYNO 10/6/09 18psiWhiteMS3 MazdaSpeed 3/6 - Dyno Sheets/Discussions 127 10-28-2009 02:01 AM
DYNOJET Rpm Pick Up AlpineFD MazdaSpeed 3/6 - Dyno Sheets/Discussions 8 02-23-2009 07:12 AM
Slipping clutch, stock dp 291.7whp dynojet.:) gsrtype1 MazdaSpeed 3/6 - Dyno Sheets/Discussions 56 01-09-2009 01:24 PM
Dynolicious vs. V-Box and Dynojet Haltech Automotive News 0 08-01-2008 06:40 PM
New SmartBargains Coupon Codes - Extra 25% Off Select Luxury Sheets at SmartBargains Haltech Hot Deals Section 0 04-14-2008 01:50 PM
Page generated in 0.33564 seconds with 28 queries
