  • 1 Post By the2falcon
 Old 04-25-2014, 10:24 AM   #1
the2falcon's Avatar
Posts: 263   (View Stats)
the2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the world
Default 3071 turbo swap
Tomorrow is the day that I will be dropping the 3071 in. Cobb fmic, xs power mani that I welded a tial 44mm wg on, 3.5 jbr intake. Can't wait to get it finished and tuned.
the2falcon is offline   Reply With Quote
The Following 6 Users Say Thank You to the2falcon For This Useful Post:
almcbs (04-25-2014), Bulgsta (06-01-2014), derek13p (04-25-2014), Koke382 (05-15-2014), speed3 britz (04-25-2014), WetzMS3 (04-25-2014)
 Old 05-15-2014, 10:32 PM   #2
levon.mark's Avatar
Posts: 268   (View Stats)
Groaned at 9 Times in 4 Posts
update?
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 05-16-2014, 05:35 AM   #3
calizoomzoom's Avatar
Posts: 684   (View Stats)
calizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the world
+1 for update
calizoomzoom is offline   Reply With Quote
 Old 05-16-2014, 05:40 AM   #4
memin's Avatar
Posts: 994   (View Stats)
+2 for update
 Old 05-16-2014, 06:03 AM   #5
white'swhiteMPS's Avatar
Posts: 639   (View Stats)
white'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the world
+3 for update
2012 MS3 CWP- Cobb AP, CS CBE, CS SRI/TIH, UR testpipe, Corksport Downpipe, JBR 88 duro RMM, NGK step colder plugs, Autotech HPFP, ETS TMIC, Koni Yellows, Swift Spec-R Springs, Forge V1, Corksport Hoodscoop (cooler BATs, yo)
Enkei RPF1 (gold) 17x9 +45 w/ Conti procontacts 245/45
Freektuned- E85 4/8gal mix
white'swhiteMPS is offline   Reply With Quote
 Old 05-16-2014, 06:12 AM   #6
Coats's Avatar
Posts: 580   (View Stats)
Coats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the world
+4 update
2013 Dodge Ram Laramie
GONE 2009 335i xdrive coupe COBB AP V3 CPe DCI
SOLD 2009 FREEKED Mazdaspeed3 GT
Coats is offline   Reply With Quote
 Old 05-16-2014, 07:06 AM   #7
JDMCRX's Avatar
Posts: 128   (View Stats)
JDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond repute
Groaned at 18 Times in 6 Posts
In for updates i want to see how that WG placement is going to clear the firewall.
JDMCRX is offline   Reply With Quote
 Old 06-01-2014, 07:32 AM   #8
the2falcon's Avatar
I'll get some when I get home. Sry I've been busy
 Old 06-01-2014, 12:55 PM   #9
the2falcon's Avatar
Here goes the final product
calizoomzoom likes this.
The Following 3 Users Say Thank You to the2falcon For This Useful Post:
Bulgsta (06-01-2014), calizoomzoom (06-01-2014), levon.mark (06-02-2014)
 Old 06-01-2014, 05:58 PM   #10
Bulgsta's Avatar
Posts: 120   (View Stats)
Bulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond repute
I would watch that vacuum line going to the EWG. seems to close to the exhaust
2007 Mazdaspeed 6
GTX3076 - CPE- EX-mani w/ 44mm EWG - CPE Safe Seals - COBB APv3 - COBB Shifter Weight - DO Stage 2 Meth - PnP Intake Mani - Catless TBE - Corksport FMIC - Corksport Rear Diff Mount - Corksport OCC - AWR RRM, TMM, PMM - TT Front Engine Mount - TT Front Diff Mount - HTP 3.5 " - GFB 50/50 - AT internals - GrimSpeed ECBS - 3 Bar Map - Perm PCV plate - JBR BSD w/ baffle - JBR TIGS - Sure Shortcut - Tower Strut Bar - EGR Delete - EGR Valve Deleted - Shifter Bushings - H&R Springs - Koni Yellow Shocks - Stoptech D&S rotors - EBC Pads - Stainless Steel Brake Lines - Denso ITV 22 - Whiteline RSB - Guardian Angel
Bulgsta is offline   Reply With Quote
The Following User Says Thank You to Bulgsta For This Useful Post:
Miltron (06-06-2014)
 Old 06-01-2014, 08:49 PM   #11
the2falcon's Avatar
I have it zip tied up. I've been watching it.
Me three goes ATP 3071 Tomas MazdaSpeed 3/6 - Big Turbo Builds 4 08-23-2011 06:35 AM
Turbo swap (cx-7 turbo for ms3 turbo on MS6) johnnyspeed6 MazdaSpeed 3/6 - Turbo Induction 9 09-19-2009 08:56 AM
Page generated in 0.30907 seconds with 27 queries
