 Old 08-29-2016, 01:54 PM   #1
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Default 44mm mvs to 38mm mvs adapter
Does anyone know where to find one of these from? called ATP to see if i can one made and they said the couldn't do it.... Last option is to get the parts and have them welded but i just want to see if someone already sells it already done. If you are curious as to what i am talking about go to ATP website and look up ATP-FLS-121
track weight 3220
street weight 3370
 Old 08-29-2016, 02:06 PM   #2
i looked up that part number and got this
i don't know if your looking for that or
one of theses
People do make a 44mm to 38mm wastegate flanges if thats what you're asking.
 Old 08-29-2016, 03:04 PM   #3
ATP-FLS-131 sorry this part... it doesn't HAVE to be 90o that is just they way they sell it.. just need an adapter so i can install my 38 mvs..
Basically i have the CPE manifold (44mm outlet) and i have a 38mm tial wastegate and i am trying not to buy an 44mm wastegate. So i figured i would just get an adapter (reducer) to fit.
That other part number is if i want to just buy the pipe and weld the flanges on for myself.
one of theses
This part is if i had a two bolt set up and i want to convert to an MVS setup...
Yes this is what i am looking for but i want 44MVS to 38MVS
After further reading i understand that the 44mm is called MV-R for the vband version and the Vband version of the 38mm is called MVS. So i need a 44mm MVR vband to a 38mm MVS vband adapter....
track weight 3220
street weight 3370
Last edited by qtrmile beast; 08-29-2016 at 03:15 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-29-2016, 03:21 PM   #4
all they have is 44mm to 38mm 2 bolt flange. looks like you have to weld 38mm to a 44mm dump pipe. you can get a 44mm dumpipe with 44mm flange for like $30 on ebay
 Old 08-30-2016, 09:12 AM   #5
MVR 44mm Wastegate 90 Deg Elbow, 100% 304 Stainless : atpturbo.com
Got a call back from ATP last night and come to find out they do have what i am looking for. I just have to check the box on that link that i want an MVR(44mm) on one side and an MVS(38mm) on the other..
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
WetzMS3 (08-30-2016)
 Old 09-15-2016, 04:25 PM   #6
on to the next part
Its about to go down!!! next will be the clutch install!!!
track weight 3220
street weight 3370
44mm to 38mm mv-s austin102085 MazdaSpeed 3/6 - Turbo Induction 16 10-26-2009 01:12 PM
Page generated in 0.28266 seconds with 21 queries
