Like Tree3Likes
  • 1 Post By Swinger13
  • 1 Post By maisonvi
  • 1 Post By Micha
 Old 01-03-2015, 01:46 AM   #1
Bishop9d4's Avatar
Posts: 23   (View Stats)
Bishop9d4 is a jewel in the roughBishop9d4 is a jewel in the roughBishop9d4 is a jewel in the roughBishop9d4 is a jewel in the rough
Default 500awhp build needs turbo
Ok people need a bit of help. Im going to break the 500awhp barrier I have everything but the turbo.
List of NEW Mods. (current mods in sig)
Wiseco Pistons
K1 Rods
CPE Mani
HTP 4 inch intake
HKS Twin Power
Tial 44mm waste gate
CPE Stage2 clutch
5th and 6th injectors
Speed Performance stage 2 cams
Crower 65lb Springs and retainers
Wilwood Big Brake Kit
Ok the problem is I can decide on a turbo. I was looking that the GTX 3576r and the PT 5858 and 5862
Turbo Compressor ind diameter Compressor exd diameter Turbine diameter HP
GTX3576R 58.00mm 76.60mm 68.00mm 400-600
PT5862 58.00mm 76.20mm 71.00mm 600-640
PT5858 58.00mm 76.20mm 64.90mm 600-620
I see the numbers I understand the numbers but Ive been reading that the gtx will spool but still have it up top and the 5862 wont. But i know the EVo guys are saying the 5858 and 5862 will blow the GTX out of the water as far as faster spool and top end. Does anybody know if that is true? Will the bigger turbine on the 5862 spin it faster or cause lag? Will the 5858's smaller turbine diameter cause it to tap out on the top end. And also the GTX 3576r comes with a .82 a/r and the PT turbos only offer a .63 a/r. im looking for the mid to top end power as my redline should be 7500 or better with a P and P. I could use some real help. Please leave the smart ass comments to yourself im not a noob to cars just to mazdas im used to building hondas and evos and not having to put up with DI. THX in advance
Red 06 Mazdaspeed6 GT, K1 Rods, Weisco Pistons, SP Cams, PTE 5862 turbo, CPE Mani, tial 44mm mvs gate, Crower 65Lb valve springs, HTP 4" intake, SP 6th port injection kit Deatchwerk 320 fuel pump, JBarone Stage 2 Short Shift Kit Razo Short Shift Stick PTP Fuel Pump Internals mild port and polish, Custom FMIC, Grimspeed EBCS, 4 Bar Map Sensor, HKS Twin Power Ignition, AWR Passanger Mount, Transmission Mount Dog Bone. Prosport EVO Boost Gauge, EGT Gauge, Oil Pressure Gauge, Prosport EVO 80mm Wideband 02 gauge, CP-E 3' Single cat Back Exhaust, custom downpipe,Turbosmart Compact Blow Off valve,PG Spin on Filter kit Devils Own Stage 2 water/meth kit H&R Coilover Shock Package AWR Adjustable endlinks SPC Rear Adjustable Camber plates, Corksport Front swaybar, Whiteline Rear Swaybar, CPE Stage 2 Clutch, SPC Adjustable ball Joints, Wilwood Big Brake Kit
Bishop9d4 is offline   Reply With Quote
The Following User Says Thank You to Bishop9d4 For This Useful Post:
Swinger13 (01-03-2015)
 Old 01-03-2015, 08:03 AM   #2
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Precision Turbo PT6266 CEA
Breath my friend, breath!
ms6mil (01-03-2015)
 Old 01-03-2015, 08:20 AM   #3
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
have you looked into HTA turbos? Fast spool and a fair bit of top end. I love mine. The GTX35 will hit your goals no problem I think with the fuel.
Also, asking for help, and saying "no smart ass comments" while being brown is really not the way to go about it.
The Following 4 Users Say Thank You to maisonvi For This Useful Post:
bo0okert (01-18-2015), Fail_6 (08-30-2015), Mauro_Penguin (01-12-2015), Micha (01-14-2015)
 Old 01-03-2015, 09:31 AM   #4
Get a ko6
chaser27 (01-12-2015), Fail_6 (08-30-2015)
 Old 01-03-2015, 09:46 AM   #5
Bishop9d4's Avatar
The 6266 is a gt 3582 equivalent right? Whats the spool characteristics?
Im trying to get the power in the middle and up top with minimal lag. The goal is to hit the target number without sacrificing the extra redline im going to pickup so i can hold peak boost longer. Not spool later and still only get 25-3000 rpm of full boost.
 Old 01-03-2015, 09:58 AM   #6
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Best turbo for you is 5858 or 6262/66. The garrett 35xx turbo spools very slow and i promise that you will "hate" it.
Biggest garrett on our cars should be 3076
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 01-03-2015, 10:04 AM   #7
JMEngineer's Avatar
Posts: 2,122   (View Stats)
Twin K04's
I really want to see someone do this.
-GTX2867R Coming Soon
The Following User Says Thank You to JMEngineer For This Useful Post:
Easter Bunny (01-03-2015)
 Old 01-03-2015, 11:10 AM   #8
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
donate first
but I am planning to go down a very similar route so I'm subbing this thread. Please don't dissapoint.
Silverdecepticon likes this.
Performance:
Stratified Tune in progress
 Old 01-03-2015, 11:39 AM   #9
maisonvi's Avatar
Groans: 75
Twin K04's
Didnt someone do this a while back? But they made the manifold runners wrong or something I thought. It was running I think though.
Rotareez likes this.
 Old 01-03-2015, 01:46 PM   #10
@keefover; did it but was having surge issues. I believe it was great at wot though.
daafisch (01-12-2015), Micha (01-14-2015)
 Old 01-03-2015, 05:32 PM   #11
Bishop9d4's Avatar
Yeah Jordan did try it. had some issues i need to hit him up and see if he fixed it or abandoned the project. As for the turbo I was leaning toward the 5862. Its air-cooled so ill have to run a pass thru for the water cooler. I heard the GTX turbos spool slow, My 3071r isn't bad i just wanna make sure i can hand these mustang owners around here there asses on a consistent basis.
mxlplx71 (01-03-2015)
 Old 01-04-2015, 02:31 PM   #12
avesfan101's Avatar
Posts: 442   (View Stats)
avesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the world
I run the 5862 and it is by far the best decision I made. Spools pretty damn quick and has the room up top.
Fuck MSF
avesfan101 is offline   Reply With Quote
The Following 2 Users Say Thank You to avesfan101 For This Useful Post:
Micha (01-14-2015), Swinger13 (01-04-2015)
 Old 01-04-2015, 04:58 PM   #13
bfak66's Avatar
Posts: 106   (View Stats)
bfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond repute
Twin K04's
Do it...do it
bfak66 is offline   Reply With Quote
 Old 01-08-2015, 11:24 AM   #14
msfastashell's Avatar
Posts: 36   (View Stats)
msfastashell is just really nicemsfastashell is just really nicemsfastashell is just really nicemsfastashell is just really nice
The guy who made the twin k04 setup was selling it, don't know if he still its. IIRC it needed a balance tube because it was having surge issues
msfastashell is offline   Reply With Quote
 Old 01-12-2015, 10:57 AM   #15
pmartz16's Avatar
Posts: 1,140   (View Stats)
You said you have the CP-e mani. The flange on that will dictate which turbo brand you go for. Unless you have not ordered it yet.
2014 Mz3 MG
 Old 01-12-2015, 11:16 AM   #16
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Wiseco Pistons
K1 Rods
CPE Mani
HTP 4 inch intake
HKS Twin Power
CPE Stage2 clutch
Of the three turbos you listed, I would go with the 5862. You will easily make 500+ with a good tune.
I beg to differ.
My speed3 had a FP HTA3582 and made 30psi by 3900rpm.
A 35r will spool just fine, with a tuner that knows what to do.
Beanfab / Tuned by Nishan
The Following 6 Users Say Thank You to doubleflusher For This Useful Post:
Hammology (07-17-2015), maisonvi (01-13-2015), Mauro_Penguin (01-12-2015), Micha (01-14-2015), Swinger13 (01-12-2015), WetzMS3 (01-14-2015)
 Old 01-14-2015, 12:12 AM   #17
BLKSTIG's Avatar
Posts: 507   (View Stats)
I'm curious about these cams. Has anyone run these yet?
 Old 01-14-2015, 05:52 AM   #18
Micha's Avatar
Posts: 3,436   (View Stats)
He abandoned it. I actually think its still for sale too.
I am slow again.
I modded it a little.
 Old 01-15-2015, 05:58 AM   #19
Bishop9d4's Avatar
The guy who has the 700whp 6 is running them, I called speed performance to see what the specs were and there pretty much 264/256 with a bowl port and springs and retainers there saying you could see a 8k redline
 Old 01-15-2015, 05:59 AM   #20
BLKSTIG's Avatar
Sweet. Does the AP allow that high to be achieved? Last I heard only VT allowed that type of redline.
 Old 01-19-2015, 04:10 PM   #21
mau7uk's Avatar
Posts: 15   (View Stats)
mau7uk will become famous soon enough
what length are your oil/coolant lines?
mau7uk is offline   Reply With Quote
 Old 07-17-2015, 12:49 PM   #22
Bishop9d4's Avatar
Ok so Im going 5862. The car goes in the shop next month just waiting on the driveshaft shop stage 3.5 rear axels. My oil lines are kosmic designed for the PTE turbo. More to follow once bild and dyno is complete.
 Old 07-17-2015, 12:56 PM   #23
radbrad's Avatar
Posts: 538   (View Stats)
Kozmic makes oil lines for the 6 now?
07Speed3
radbrad is offline   Reply With Quote
 Old 07-17-2015, 01:02 PM   #24
Bishop9d4's Avatar
They do got them from edgeautosport
 Old 07-17-2015, 05:49 PM   #25
radbrad's Avatar
Even the return line? I thought kozmic didn't include the return with the turbo kit...
edit: just looked on edge, you are correct sir. Good stuff
07Speed3
 Old 07-18-2015, 12:26 AM   #26
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
@Bishop9d4; Don't do the 5862!!! I swear the 5858 rips more!!! IMHO, the high hp 5862 cars don't look that fast to me, or at least not as fast as I would imagine. 5858's seem noticeable faster. My 5858 rips ass at 32psi and tons more room for more power. I should be a tad over 500hp @ 32psi, planning on running 35 with more meth and a jmf manifold
 Old 07-18-2015, 12:40 AM   #27
Micha's Avatar
I am at 458 awhp and 385 awtq on a mustang Dyno on a 5862 on 28-29 lbs and 17 degrees of timing 50/50 e85/91.
The 5862 seems to have more higher end. I am also on a JMF manifold and 6th port.
Koke382 likes this.
I am slow again.
avesfan101 (07-18-2015)
 Old 07-18-2015, 02:50 PM   #28
avesfan101's Avatar
Made 521 awhp and 412 tq on a mustang. 5862 @ 30psi. 93 oct. 6th port and meth pre tb.
The 5862 is a sick turbo.
Sent from my SM-N910V using Tapatalk
Fuck MSF
 Old 07-18-2015, 02:53 PM   #29
h.h.sk1nny's Avatar
Not that vd is the shit but I am running 500whp with 17* timing and 30psi on the 5858. Not hating on you guys, just seen some on Youtube and was not impressive looking. I think I'm gonna run her at the track tonight. 32psi and 1.5* timing. No JMF manifold either yet, just waiting on it to show up.
 Old 07-18-2015, 09:44 PM   #30
Micha's Avatar
Vdyno has me around 520AWHP on the same exact setup that I ran a 458 on the dyno. Dyno operator also didn't run me out to redline in my runs.
I am slow again.
Fail_6 (08-30-2015)
 Old 07-19-2015, 01:31 AM   #31
The GTX3076 is in a similar range to the PTE 5858 and 5862 in terms of compressor flow.
The GTX3076 has the same compressor as the GTX3576 and out of those two definitely choose the 3076 for spool and response.
Even on a Mazda hotside with IWG which is quite small the GTX3076 will break 500whp on a FWD. If you get a nicer flowing hotside and EWG you will get your goals with this turbo.
The PTE turbos are very capable as well and as mentioned are in a similar power ballpark. Out of the two I would choose the 5862 as it has a bit more top end and with the Speed6 you load the motor more and spool earlier than a Speed3
Micha (07-20-2015), SpeedRebirth (07-19-2015)
 Old 08-15-2015, 10:47 PM   #32
Bishop9d4's Avatar
Im looking for the top end with the springs and retainers my red line will be past 7k. Also im seeing the 5862 hitting full boost by 43-4500 and with the built bottom and cams i can hold it to red line. and with a 50/50 93/e85 combo 500 willbe 2 ez. But if Tacoma has 94 oct like im hearing the retune on 50/50 is going to be even better.
Now new question. Does anybody have a copy of a stock map so I can unmarry my AP and install the V3 my comp crashed and I lost mine.
 Old 07-25-2016, 01:16 PM   #33
Bishop9d4's Avatar
Default UPPPPDPATE
For those who care that was in this post. THANK YOU!!! I did the 5862 and the shyt is real. Starts spooling at 2300 full boost at 3800 holding 27.5 psi to redline. Was about to dyno but during the inspection we found that the stock injectors studs were used so we have to replace them. So im replacing the entire fuel system to go E85 4 new injectors autotech internals and a dw300. More to fiollow
The Following 2 Users Say Thank You to Bishop9d4 For This Useful Post:
mxlplx71 (07-25-2016), SpeedRebirth (07-25-2016)
GTK-450 turbo build matgod MazdaSpeed 3/6 - Big Turbo Builds 18 09-09-2013 08:00 PM
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 02:16 PM
Why not another S3 turbo build! taf0422 MazdaSpeed 3/6 - Big Turbo Builds 187 02-21-2013 02:13 AM
Big turbo kit, build one or not? ptperformance Mazdaspeed3/6 General Discussion 33 10-12-2008 02:55 PM
Page generated in 0.51898 seconds with 37 queries
