![]() Join Date: Jan 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score when i was doing my balance shaft delete i noticed a good amount of wear on the cylinder walls, this plus i was closing in on 100k miles prompted me to go for a rebuild. so i purchased everything needed for a solid rebuild. CP 9.5:1 pistons .020 over eagle rods fidanza flywheel act sprung 6 puck clutch disc oem pressure plate (might swap this to something heavier) new oil pump new water pump new vvt actuator new thermostat oem master gasket set, plus the rear main seal arp crank bolt arp flywheel bolt arp head and main studs new timing components (chain, guides and tensioner) injectors and everything required to run extra injectors on each intake runner. still cant figure out if want to use megasquirt or that driver that comes with 6th port. and a spare long block off a local had the pistons and bearings coated with the dry film stuff and ceramic on the piston tops after ripping apart the spare block and having it matched to the pistons and line honed i got to work on assembling the short block, head porting to come as well. now to my problem, i cant figure out what turbo i want to run. im shooting for 500 or so hp. this isnt my daily, takes about 50% of the driving split with my dsm; so im not to greatly concerned with the drivability issues that might arise from a car like this. anyway, my plan at first was to run compound, use a evo 8 stock turbo to a hx 52 or 55. i did some crude measurements (best i could without having the turbos on hand) and found they should fit well if i mount the large turbo kind of where the battery sits. this set up though becomes super expensive, and pain to tune, and in general a pain in the ass. however it gives you a fast spool off the little turbo, and lots of top end off the big turbo. plus two turbos spooling sounds so bad ass. is there a single turbo option that would give me everything I am looking for? ive looked at teh garret turbos and while theyll get me to my power goals, they also come with the downside of bad spool characteristics. if anyone has any input on this i would appreciate it. ill post pictures in the next few days. |
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score I vote BW EFR 7168, fast spool, integrated wastegate and integrated bpv and will meet your power goals.
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package |
| Not Ranked : 0 score For comfortable 500s you need additional 6th port fueling. For the turbo look at a gtx35, EFR mentioned above or a precision. It should flow at least 55 lbs but closer and a bit above 60 lbs is better due to losses at that power level.
| The Following User Says Thank You to Lex For This Useful Post: | Easter Bunny (11-24-2013) |
![]() Join Date: Jan 2011 Location: sicily, Italy
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 439
| Not Ranked : 0 score You should buy papasmurfs gt35 if it's not already sold. He is selling it for a great price Sent from my iPhone using Tapatalk
__________________ 07 SILVER Speed3 , BNR S3- Tial 38mm EWG w/ stock mani- COBB AP- Ebay catless Downpipe- HTP 3in intake- Devils Own WMI (D10)- CX Racing FMIC- Autotech internals- Grimmspeed 3P EBCS- Denso ITV22- HKS super SQV- Bosch 3 bar - Damon PMM- JBR RMM- shift weight- EGR delete- TIGs- JBR RSB- Eibach springs- TR Motorsports 17x9- Hankook RS-3 255/40/17 |
Groans: 33
| Not Ranked : 0 score You might want to change the arp head studs for OEM or H11, preferably H11. Doing it right the first time will give you peace of mind
also i looked into those BW EFR turbos, pretty crazy set up, never saw a turbo that has a built in BPV. however that single turbo would cost more than my compound set up, and probably not have the same benefits. also im just looking for an excuse to buy a tubing bender to go along with my tig welder for the manifold. | |
| Not Ranked : 0 score Compound turbos is too complicated for only 500 hp.
| The Following User Says Thank You to Easter Bunny For This Useful Post: | Roddiy (11-24-2013) |
![]() Join Date: Aug 2011 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,355
Groans: 279
| Not Ranked : 0 score This. For 500hp you can just use a PTE 6262, you might even get away with a PTE 5857 if your setup flows correctly. Spool shouldn't be too laggy on the latter either.
__________________ 2010 LSM Speed3 Bolted + Corn + Meth + ACT 6-Puck #BakeryTuned |
| The Following User Says Thank You to Roddiy For This Useful Post: | Easter Bunny (11-24-2013) |
| PTP Built block | Jonny Quest | Mazdaspeed3/6 General Discussion | 33 | 06-12-2012 10:10 PM |
| Possibly Doing a build | Sickspeed3 | MazdaSpeed 3/6 - Build Diaries | 9 | 09-08-2011 09:28 PM |
| FML and possibly my built motor | turd burglar | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 14 | 04-19-2011 10:02 PM |
| Built Block? | BreakTheStatic | Mazdaspeed3/6 General Discussion | 91 | 06-03-2009 12:53 AM |
