 Old 02-14-2012, 07:16 PM   #1
QwkEVO's Avatar
Posts: 484   (View Stats)
QwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the world
Default Another Intake Manifold Option
I got back my factory intake manifold today from Pablo aka SPEED6 KILLAH. I had sent it to him for porting based off of someone elses' recommendation. The work he did in my opinion is as good if not better than Grimmspeed. For one he sends it back to you 100% ready to bolt on. All the necessary holes have been filled, etc. He actually ports the intake runners and then where the rod for the VTCS butterflies went through is filled with JB weld and sanded smooth on each and every runner. I dont think GS goes that far. He also did some porting near the throttle body opening as well, which I didnt expect or even ask for.
I'm not going to say how much he charged me as he may want to adjust his price if he gets a lot of people wanting the same work done. I will say this, its a fraction of what GS charges and IMO better work. He had the manifold back in my hands 3 weeks after the day he received it. Plus I like keeping my money in the hands of other members if possible. Grimmspeed does make some nice stuff for us, but IMO what they are charging for the same work is a bit excessive.
Huge thanks and props to Pablo!!
Here are some pics:
SLOWHATCH likes this.
08 MS3 //PTP Injector seals & stud kit //CP-E RMM //Corksport Sway Bar // Koni Yellow Sports // Eibach Pro Kit Springs // Enkei 18" PF01's //
QwkEVO is offline   Reply With Quote
The Following 19 Users Say Thank You to QwkEVO For This Useful Post:
Alpha (02-20-2012), bmfms3 (03-05-2012), btstarcher (02-14-2012), dereeek (02-14-2012), Docnox (02-23-2012), Don06speed6 (02-14-2012), Downmented (02-22-2012), forgedzoomzoom (02-21-2012), GLORIFIEDBOZO (05-19-2012), helmetface (03-04-2012), Jh8909 (02-21-2012), kmac (02-22-2012), manelscout4life (03-04-2012), mason (02-19-2012), Nataphen (02-18-2012), SLOWHATCH (02-18-2012), SPEED6 KILLAH (02-14-2012), TWOptSL0W (02-14-2012), wolly6973 (02-15-2012)
 Old 02-14-2012, 07:22 PM   #2
btstarcher's Avatar
Posts: 4,852   (View Stats)
Looks great!
SnailTune in progress
 Old 02-14-2012, 07:26 PM   #3
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Pablo is a good friend of mine and does great work on these manifolds.
Don't shit on Grimmspeed. You obviously don't have all the info.
Beanfab / Tuned by Nishan
The Following User Says Thank You to doubleflusher For This Useful Post:
triplejumper18 (02-20-2012)
 Old 02-14-2012, 07:41 PM   #4
QwkEVO's Avatar
Not shitting on GS at all, I have a couple of their products and am very happy with them.
I almost had the IM porting done through them. What I didnt like is that for $349 you get a manifold back that you still have to plug holes in order to install it. Also the $349 doesn't include their ceramic coating, which they dont even state in the description.
So like I said, it's my opinion ONLY that their price is excessive for what you get. I based my decision off of what other people who have had their manifold ported by them have reported. I had all the info I needed to make an informed decision.
The Following User Says Thank You to QwkEVO For This Useful Post:
Jh8909 (02-21-2012)
 Old 02-15-2012, 04:22 AM   #5
Groans: 1,443
Please explain why my Grimmspeed mani didn't require holes to be plugged prior to install.
 Old 02-15-2012, 06:45 AM   #6
QwkEVO's Avatar
I can't, maybe after enough people complained, they refined their process? Which is a good thing. Because for $349, not including the ceramic coating it should be a direct bolt on w/o any further mods. I'm glad you didnt have to do anything to yours, that's how it should be IMO.
 Old 02-14-2012, 07:28 PM   #7
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
yea pablo is the shit. grimmspeed does do a whole different process so its comparing apples to oranges
...but again, go pablo!!
 Old 02-14-2012, 08:30 PM   #8
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
How does this compare to MAPerformance's PnP job?
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 02-14-2012, 08:35 PM   #9
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
flowbench?
The Following User Says Thank You to Mizzle For This Useful Post:
mazdafreak (02-14-2012)
 Old 02-14-2012, 08:39 PM   #10
khopwood77's Avatar
Posts: 245   (View Stats)
khopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the world
flowbench?
+1
Interested to know what the error % is between the runners.
2010 Black Mica MS3 (Daily Driver) - self-tuned with the help of Lex www.mazdaspeedforum.org/forum/forum/f426/k06-log-86437/
K04 Hybrid, Nitto NT01s, JMF Manifold, 4 Port Meth, 100% E85, 3 Bar MAP, HTP 3.5, Cobb DP, ETS TMIC, KMD Internals, PTP RV, OCC, Forge BPV, CP-E Mounts, JBR Thermal Intake & Throttle Body Gaskets, JBR Shifter Plate & Bushings
2006 Mustang GT - www.vortechsuperchargers.com/global_item.php?gik=348
Built Motor, 675 RWHP 560 lb/ft T-Trim 21PSI Non-Intercooled
1993 Mustang LX - www.youtube.com/watch?v=WiCCvodp6CU
Budget 349 Stroker
khopwood77 is offline   Reply With Quote
 Old 02-14-2012, 09:12 PM   #11
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
1# 254cfm 2#256cfm 3#259 cfm 4#255
There pretty much close to each other..
Also remember are intake manifold air flow sucks stock you don't wanna hear the numbers how much there each off by.
SPEED6 KILLAH is offline   Reply With Quote
The Following 15 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
802MS3 (02-21-2012), Chimmike (02-15-2012), ChimmyChong (02-14-2012), Docnox (02-23-2012), Don06speed6 (02-14-2012), forgedzoomzoom (02-21-2012), Jh8909 (02-21-2012), khopwood77 (02-14-2012), kmac (02-22-2012), mazdafreak (02-14-2012), Mizzle (02-16-2012), Monotonous ONE (02-23-2012), SLOWHATCH (02-18-2012), uncorked11 (02-14-2012), wolly6973 (02-15-2012)
 Old 02-14-2012, 09:29 PM   #12
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Also remember are intake manifold air flow stuck stock you don't wanna hear the numbers how much there each off by.
How do these numbers compare to GS?
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 02-14-2012, 09:42 PM   #13
One of my friend who have a GS Manifold and he said his total of cfm is about 1250
Mines in total cfm 1,024
The Following 9 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
ak_spray (02-20-2012), bmfms3 (03-05-2012), Chimmike (02-15-2012), Docnox (02-23-2012), helmetface (03-04-2012), kmac (02-22-2012), mazdafreak (02-14-2012), SLOWHATCH (02-18-2012), wolly6973 (02-15-2012)
 Old 02-15-2012, 07:05 AM   #14
Groans: 1,443
I have the first one they did.
The pictures on their site is of mine.
 Old 02-15-2012, 08:03 AM   #15
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Be sure to turn your boost back up as you are going to loose at least 2 psi but you will not loose power with that 2 psi drop.... looks good good job pablo
track weight 3220
street weight 3370
The Following 3 Users Say Thank You to qtrmile beast For This Useful Post:
doubleflusher (02-15-2012), h.h.sk1nny (02-26-2012), SPEED6 KILLAH (02-15-2012)
 Old 02-18-2012, 05:39 PM   #16
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
The hole plugging is nice but it is not needed. There are many many guys running ported manifolds with awesome gains that have the holes open and just the rod removed. In any event, the mani looks GREAT
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 02-18-2012, 06:43 PM   #17
mazdafreak's Avatar
Groans: 124
@forcedinduktion
713whp/569wtq!
The Following User Says Thank You to mazdafreak For This Useful Post:
forcedinduktion (02-19-2012)
 Old 02-20-2012, 01:08 PM   #18
Karmat's Avatar
Posts: 1,179   (View Stats)
The grimmspeed is around $400 without a core?
2002 Corvette Z06 (Black)
 Old 02-20-2012, 01:48 PM   #19
QwkEVO's Avatar
$349 and that doesn't include the ceramic coating, return shipping and you have to send in your own manifold.
 Old 02-20-2012, 05:36 PM   #20
Karmat's Avatar
I wanna even out the flow differences and am contemplating on the most cost effective option. GS seems to create quite a bit of flow.
 Old 02-20-2012, 05:43 PM   #21
QwkEVO's Avatar
I got my manifold ported AND ceramic coated for cheaper than what GS charges just to port the manifold. My flow imbalance has been evened out to less than 5% across the board.
 Old 02-20-2012, 05:59 PM   #22
laxplayermjd's Avatar
Posts: 779   (View Stats)
laxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the world
if anyone wants a stock mani i got a spare for sale then again maybe i should send mine to him...
looks like some nice quality work
2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune
laxplayermjd is offline   Reply With Quote
 Old 02-21-2012, 08:19 PM   #23
mazdaspeed4life's Avatar
Posts: 93   (View Stats)
mazdaspeed4life is infamous around these partsmazdaspeed4life is infamous around these partsmazdaspeed4life is infamous around these parts
Groaned at 108 Times in 27 Posts
Damn so witheverything done what hp gains have u shown
I am here: http://maps.google.com/maps?ll=38.104347,-77.800709
mazdaspeed4life is offline   Reply With Quote
 Old 02-21-2012, 08:26 PM   #24
snowms3's Avatar
Posts: 287   (View Stats)
snowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond repute
bump for gains
2009 cwp MS3. COBB SRI, COBB inlet pipe, CPE catless DP, GHL catback(drone-free), SURE RMM, JBR PMM 80d, DASHHAWK, COBB AP STRATIFIED TUNED BY LEX 3/10 E85, ATP FMIC, HKS SSQ Full recirc, AUTOTECH INTERNALS, WHITELINE 27mm Adjustable RSB, Einkei RPF1 gold/ Firestone Wide Oval Indy 500 235/45/17, GORILLA BLACK LUGNUTS.
snowms3 is offline   Reply With Quote
 Old 02-21-2012, 09:11 PM   #25
QwkEVO's Avatar
To be honest it's going to be hard for me to pinpoint gains with this because I'm bolting it on the same time I do my turbo swap (3071gtx). My goals were to reduce the flow imbalance and increase flow through the manifold.
mrmonk7663 (02-21-2012)
 Old 02-21-2012, 09:22 PM   #26
mrmonk7663's Avatar
I will have gain information on my car here hopefully this weekend. The only upgrade I am making is the intake manifold. My New Intake Manifold OP, not trying to threadjack bro, just trying to provide the information on manifold gains!!! I'll delete if you want this out of your thread.
 Old 02-21-2012, 09:42 PM   #27
QwkEVO's Avatar
No it's cool, I'm curious to see the gains as well myself. That's the only bad thing about bottling on a bunch of stuff at once. Hard to tell what made the most gains.
 Old 02-21-2012, 09:44 PM   #28
mrmonk7663's Avatar
Yah, I hear you. I will report back as soon as I have definitive information. The only other mod I will be doing is adding an additional intake gasket, so I will be stacking 2 together to help lower the BATs.
The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post:
Docnox (02-23-2012), snowms3 (02-22-2012)
 Old 02-22-2012, 08:54 PM   #29
mrmonk7663's Avatar
Quick update...looks like the intake will be delayed one week. My injector seals will not arrive until Monday, so I have to push back the install one week...no desire to pull intake 2 weekends in a row!!! March 4th I will have data. I will use this weekend to take some logs so I will have a base from which to evaluate gains from the install.
 Old 02-23-2012, 03:59 PM   #30
Just incase you guys have not read about this being done before. I believe that with pablos intake it should yield pretty close to these results. The job that he did was really clean and smooth. There might be more threads about this that you can read while you are awaiting his results on his test.
MAP PERFORMANCE INTAKE(post 57 is where your answer is)
MAPerformance Ported Intake Manifold
INTAKE MANIFOLD that i ported
ported intake hp
It would be interesting to see what you come up with though...
track weight 3220
street weight 3370
Docnox (02-23-2012), helmetface (03-04-2012), mrmonk7663 (02-23-2012)
 Old 03-01-2012, 09:26 AM   #31
GrimmSpeed's Avatar
Posts: 49   (View Stats)
GrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond repute
Nice work Pablo! Everything look very thorough!
Just to clarify, we do not fill the center holes, just the end ones to seal the manifold off. Once the manifold is pressurized the holes will have no affect on the performance of the manifold.
Mike
GrimmSpeed is offline   Reply With Quote
The Following 3 Users Say Thank You to GrimmSpeed For This Useful Post:
Chimmike (03-01-2012), qtrmile beast (03-01-2012), tddvrrn (03-03-2012)
 Old 03-01-2012, 09:55 AM   #32
I have another intake that i will be porting and i want to know if anyone tested the flow of the intake with it being ONE complete runner insted of 1 into 2.
track weight 3220
street weight 3370
 Old 03-01-2012, 04:56 PM   #33
HPFPUPGRADE's Avatar
Posts: 403   (View Stats)
HPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the world
Groaned at 22 Times in 17 Posts
Yes, huge gains but you need to open up the runner deep into the manifold and cut the manifold apart to get the areas after the bend of the intake. Also, you may have to weld the edge of the manifold where the short runner is if you want even the floor of the manifold. There is 3 to 4 hours of welding and when you are done you need to have the surface machined flat again.
We are getting ready to release a cyl head that has very similar work done to it.
HPFPUPGRADE is offline   Reply With Quote
 Old 03-01-2012, 05:31 PM   #34
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
The stock manifold outflows my ported head so I dont see the point other than balancing the flow and bragging rights. No one has a head that out flows mine yet so I think its kind of a waste of money.
I think the stock IM out flows my head by about 40cfm at .500" lift, so its not even by a little and no one is running anything even slightly close to a .500" lift cam. I bet at .300" lift it outflows my head by 100cfm or more. Ide have to check my thread again.
2006 Mazdaspeed 6
 Old 03-01-2012, 10:54 PM   #35
well all the ported intakes that i have done have created a gain of at least 15 or so hp...
http://www.mazdaspeedforum.org/forum/foru...take-hp-61778/
track weight 3220
street weight 3370
 Old 03-01-2012, 11:13 PM   #36
mrmonk7663's Avatar
Link isn't working.
 Old 03-01-2012, 11:40 PM   #37
Link isn't working.
ported intake hp
track weight 3220
street weight 3370
 Old 03-01-2012, 11:00 PM   #38
I can't image how much mine will be then with my head.
 Old 03-02-2012, 08:35 AM   #39
Speeeeeed
06Speed6's Avatar
I think the hp gain is just from balancing the flow, it really might be that bad.
2006 Mazdaspeed 6
Mizzle (03-03-2012)
 Old 03-04-2012, 12:07 PM   #40
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Still awaiting hard evidence from others on the gains of this before I dive in.
And when you say "really might be that bad" you're referring to the balance of the flow?
Thanks!
Exhaust Manifold option- please look and respond! Chimmike MazdaSpeed 3/6 - Turbo Induction 31 08-01-2011 08:17 AM
new intake manifold option.. somewhat. Stockturbo_Ms3 MazdaSpeed 3/6 - Turbo Induction 6 08-03-2010 12:58 PM
Intake manifold this, intake manifold that!!! ptperformance Mazdaspeed3/6 General Discussion 53 06-21-2010 02:51 PM
Intake manifold QuickSpool 2010 MS3 - Engine, Transmission & Driveline 0 11-18-2009 06:19 PM
Page generated in 0.58844 seconds with 39 queries
