 Old 03-19-2013, 11:35 AM   #1
superdave2335's Avatar
Posts: 924   (View Stats)
superdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the world
Groaned at 9 Times in 6 Posts
Looks pretty dope. Might even clear the alternator... Curious if there would be enough room for a down pipe as well.
Someone should try. And if it doesn't fit... just return it.
Ya I agree it's deff a nice looking piece. It's nice that you can also run a vband as well. I may look into this more. Yes I would also have to check up on the ol return policy! Lol
Shooting this ISH from my iPhone using forCUMrunner
08' MS3 ESK-EMO Tuned!!!
GT3076r EWG
Manley rods, cp-e stage 2 pistons, arp studs, fullRace exhaust mani,PNP stock IM, TurboXS catless DP/TP/CBE, TurboXS FMIC, hybrid boost control setup using MBC/EBCS, HTP 4" intake system w/MAF block off plate, 3.5" blow thru system fabbed by me,3 bar map, SNOW Stage 2 W/Direct port meth, HKS SSQV4 full vta, JBR 80duro RMM/TMM/PMM, JBR Stage2 OCC, EGR delete, TWM Full Replacement, perm butt plug knob, JBR SB, KMD V2, NGK's, perm pcv plate.
shout outs to -Rob, DJ, Nishan, William, John. couldn't have done it with out your guys advice and assistance. thanks.
superdave2335 is offline   Reply With Quote
Page generated in 0.22978 seconds with 21 queries
