  • 1 Post By EdgeAutosport.com
 Old 04-17-2012, 09:09 PM   #1
drummerboy1864's Avatar
Posts: 65   (View Stats)
drummerboy1864 is a splendid one to beholddrummerboy1864 is a splendid one to beholddrummerboy1864 is a splendid one to beholddrummerboy1864 is a splendid one to beholddrummerboy1864 is a splendid one to beholddrummerboy1864 is a splendid one to behold
Default Anyone Running Stock Internals? 350+
So I was wondering how many of you are actually running a big turbo build still on stock internals. I have about 3 1/2 grand put aside for my build. I want to run a GT3076, FMIC, TIP, Fuel pump internals, with a Cobb Acessport. I hoping to get those for 3.5k
I already have the CAI and DP. But im worried Im going to damage my internals... I cant decide if i want to wait untill I have 4.5k saved up to get pistons and rods.
So who is actually running stock internals pushing 350+whp? From what I have been hearing thats about the breaking point most people hit with stock...
And would it be a bad idea to run this turbo build with the stock internals, and just keep the turbo around 18-20psi.. untill I can put in forged internals?
Cobb High Flow DP - Greddy TI-C CBE -
Sure SRI - Sure 3" MAF - Sure TIP - JBR 88a RMM - JB Shifter Plate - JB Weighted Shift Knob - CS Lic Plate Relocation - CS Shifter Bushings - Cobb AP - Rota Tarmac 3 Hyperblack 18x8 - Nitto NeoGens 235/40/18 - PTP HPFP Internals - CS Springs - CX FMIC - Snow Performance Stage 2 Meth Kit D05 - ITV22- Tuned by the FREEK
drummerboy1864 is offline   Reply With Quote
 Old 04-17-2012, 09:14 PM   #2
Dmurray06's Avatar
Posts: 3,279   (View Stats)
My bet is 350 ish is safe for stock internals. Over 400 an it's touch and go. I know there are tons of people on stock internals and ~350.
 Old 04-17-2012, 09:14 PM   #3
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
big turbo stock block thread
'08 CWP MS3 w/ T3 3071r
Broxer (04-18-2012), dereeek (04-18-2012), xhymer (04-18-2012)
 Old 04-17-2012, 09:16 PM   #4
m4tic's Avatar
Posts: 4,928   (View Stats)
You are not damaging the fuel pump... You just reach its flow limit
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
Tokay444 (04-18-2012)
 Old 04-17-2012, 09:20 PM   #5
Nefarion's Avatar
Posts: 451   (View Stats)
Nefarion is the leader of the worldNefarion is the leader of the worldNefarion is the leader of the worldNefarion is the leader of the worldNefarion is the leader of the worldNefarion is the leader of the worldNefarion is the leader of the worldNefarion is the leader of the worldNefarion is the leader of the worldNefarion is the leader of the worldNefarion is the leader of the world
Groaned at 41 Times in 8 Posts
@m4tic wrong internals. OP means Rods and Pistons...not fuel pump internals
2010 Velocity Red Mazdaspeed 3
Engine: Cobb AccessPort - Corksport SRI+TIP - TRZ Dogbone RMM - JBR Shift Bushings - JBR Stage 1 Short Shift Plate - JBR Stage 1 Heavy Shift Knob - Autotech Internals - Denso Iridium ITV22 Spark Plugs - Raceroots Catless Long Downpipe - Custom 3" Catback Exhaust - Corksport Front Mount Intercooler - VTCS Delete - EGR Delete - JBR OCC - Turbosmart Dual Port BPV
Appearance: Painted Emblems - Eibach Springs - Smoked Headlights - Painted Fog Light Surrounds - Yellow Fogs - Gold Enkei RPF1 17x9 Wheels - 255x40 Hankook V12 Tires
PERM TUNE - SOCKS
Nefarion is offline   Reply With Quote
The Following User Says Thank You to Nefarion For This Useful Post:
drummerboy1864 (04-17-2012)
 Old 04-17-2012, 09:23 PM   #6
not worried about damaging the fuel pump. But I assume running a big turbo build... my fuel pressure is gonna drop to like 900... :-( cant have that
my only worry is really bending a rod pushing ~350~
 Old 04-17-2012, 09:26 PM   #7
Dmurray06's Avatar
Once you get pump internals, your pressure will hold strong.
 Old 04-17-2012, 09:35 PM   #8
m4tic's Avatar
Reading comprehension < me
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 04-17-2012, 09:38 PM   #9
Well wtf.. We need different terms...
We should just say rods when referring to engine guts
Im just wondering if anyone is having issues with stock rods pushing over 350whp and about what point do our rods start bending
 Old 04-18-2012, 12:09 AM   #10
m4tic's Avatar
they start bending when your tune starts sucking. detonation, low rpm high cyl pressure and unchecked boost (hi boost on stock map sensor for example) kills engines.
2017 Daytona 392
2007 MS6 w/ Cheez
The Following 3 Users Say Thank You to m4tic For This Useful Post:
rfinkle2 (04-20-2012), Tokay444 (04-18-2012), Vader (04-20-2012)
 Old 04-18-2012, 04:20 AM   #11
StayBroke's Avatar
Posts: 2,075   (View Stats)
I say around 380 to 415 on a very solid tune will last decent miles. Im running a gt3076 so just look at my thread time to time. When i get done with my tune i will post vdyno numbers and you can get an idea.
I also have been told that keep up with your maintenance and you will be good to go.
And one more thing, you really want have to worry about load down low as in full boost on a reg 3076r will be around 3800 to 4000rpm.
The Following User Says Thank You to StayBroke For This Useful Post:
 Old 04-18-2012, 05:08 AM   #12
kmac's Avatar
Posts: 1,792   (View Stats)
Nope, stock internals. It can't be done.
First 500whp stock block mazdaspeed3 (503whp 423wtq)
<3 Tokay.
The Following 3 Users Say Thank You to kmac For This Useful Post:
Alpha (04-18-2012), rfinkle2 (04-20-2012), Tokay444 (04-18-2012)
 Old 04-18-2012, 05:19 AM   #13
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
I wouldn't push over 400whp on my own ms3 on the stock internals. When my oem turbo goes, I will replace it with either a bnr 1 or bnr 3, amd maybe push a max of 350whp.
 Old 04-18-2012, 06:45 AM   #14
travis9935's Avatar
Posts: 371   (View Stats)
travis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond repute
Groaned at 41 Times in 24 Posts
So pretty much below 2000 rpm 100% throttle is what the main reason for rod carnage is from? Why don't Mazda use stronger rods? Genone & genpu both?
HT programmer, Mazdaspeed CAI, Turbosmart Dual port Bpv, Corksport Test pipe back exhaust, HTP TIP, Autotech CDFP internals, CP-E TMIC, Cobb Springs, Koni yellow struts, SU RMM, Ts shift plate, prosport bg, 10k headlights, 3k fogs, OZ Ultraleggera HLTs, Pioneer nav/dcs......On the way; Devils Own Stage 2
travis9935 is offline   Reply With Quote
 Old 04-18-2012, 10:36 AM   #15
6oost3d's Avatar
Posts: 151   (View Stats)
6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world
I had stock internals and dynoed 380 whp with a gt3076 drop in, it ran fine. After adding timing and e85, a rod shot out through the back of the block and another piece of it through the oil pan. I guess 380 was good haha.
2006 Mazdaspeed6 GT
GTX3582 T3 .82 A/R // Wiseco Pistons // K1 Rods // H11 Head Studs// Steedspeed Top Mount Manifold // TiAL MVR // TiAL MVS // PERM Top Mount Kit // NGK plugs // Custom FMIC // Cobb AP // Bosch 3 Bar MAP// Magnaflow Exhaust // MSD Dashhawk // RPM Springs //JBR STG 2 OCC // JBR EGR Delete //Autotech Fuel Pump Internals // SU Motor Mount // Prosport Boost Guage // ACT 6 Puck //Fiber Images Carbon Fiber Hood // Snow Performance Stage 2 WMI, d10 & d12 nozzles // Corn Fed
516whp/476tq - Mega Meat 2013
6oost3d is offline   Reply With Quote
The Following 2 Users Say Thank You to 6oost3d For This Useful Post:
rfinkle2 (04-20-2012), SLOWHATCH (04-18-2012)
 Old 04-18-2012, 10:47 AM   #16
ClutchEngaged's Avatar
Posts: 186   (View Stats)
ClutchEngaged is the leader of the worldClutchEngaged is the leader of the worldClutchEngaged is the leader of the worldClutchEngaged is the leader of the worldClutchEngaged is the leader of the worldClutchEngaged is the leader of the worldClutchEngaged is the leader of the worldClutchEngaged is the leader of the worldClutchEngaged is the leader of the worldClutchEngaged is the leader of the worldClutchEngaged is the leader of the world
Because it would most likely push the price up to more than they are willing to sell it for. It fits into a nice niche segment at the current price, and that is Mazda's goal.
ClutchEngaged is offline   Reply With Quote
 Old 04-18-2012, 11:37 AM   #17
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
stock motors blow so i think mazda pushed the envelope too far even at the stock power levels. i detuned my car for this reason.
94 M
MS6
IS350
 Old 04-18-2012, 11:53 AM   #18
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
400 seems to be the breaking point. However, @superskaterxes was pushing 430+ for a while before his went boom.
The Following User Says Thank You to RichieRichness For This Useful Post:
EdgeAutosport.com (04-18-2012)
 Old 04-18-2012, 11:54 AM   #19
I dunno guys Ive been over 450 for 25k for a long time and I beat the shit out of my car. With a solid tune a good maintenance there is nothing to worry about
The Following 7 Users Say Thank You to EdgeAutosport.com For This Useful Post:
Broxer (04-18-2012), Manny3 (04-18-2012), MS3KO (04-18-2012), rfinkle2 (04-20-2012), RichieRichness (04-18-2012), StayBroke (04-18-2012), xhymer (04-18-2012)
 Old 04-18-2012, 11:58 AM   #20
Groans: 35
yeah I was referring to the MS6 awhp. However, it may be the tq numbers to look out for.
The Following 2 Users Say Thank You to RichieRichness For This Useful Post:
EdgeAutosport.com (04-18-2012), rfinkle2 (04-20-2012)
 Old 04-18-2012, 12:00 PM   #21
yup exactly I was putting down 439wtq but again its all about the tune and we know you know your shit
 Old 04-18-2012, 12:32 PM   #22
StayBroke's Avatar
I am assuming you have a ms6, if so i would have been happy with 380 awhp.
On a ms3 i still believe around 400 is a decent spot to be around.
 Old 04-18-2012, 12:47 PM   #23
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
There was another guy with stock internals pushing like 500+whp at 30PSI with some E85 mix (dturbo I think was his nickname). But this discussion is only about numbers, and pretty much all the people think only about more power when start tuning and ditch comfort, drivability and reliability in the closet.
If you're concerned about your stock rods I'd say to consider a more efficient setup with a 3071 turbo or similar. 3076 spools too late (3800-3900'ish) and you will run out of RPM's just when starting to make good power. A 3071 spools around 3200-3400 (mine spools around 3350), so you'll still be in the safe area with better driveability.
If you switch to forged and lighter rods then a 3076 or a gt35 makes much more sense IMHO.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 04-18-2012, 01:38 PM   #24
kmac's Avatar
Any mazdaspeed making over 400 whp on a stock block is on borrowed time It's only a matter of time before it pops. I'm lucky that's all there is to it.
<3 Tokay.
Lex (04-20-2012), Realgib3 (04-18-2012), rfinkle2 (04-20-2012)
 Old 04-18-2012, 01:39 PM   #25
Realgib3's Avatar
Posts: 2,443   (View Stats)
This is ridiculous post full if misinformation. "Run out of rpm when u finally get into power on a 76" hahaha
The Following 3 Users Say Thank You to Realgib3 For This Useful Post:
802MS3 (04-18-2012), RichieRichness (04-18-2012), Vader (04-20-2012)
 Old 04-18-2012, 02:34 PM   #26
6oost3d's Avatar
Yea its an ms6, I think it was putting down 372 for tq. 380 is fun..
2006 Mazdaspeed6 GT
 Old 04-18-2012, 02:47 PM   #27
ColonR's Avatar
Posts: 1,453   (View Stats)
ColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the world
i was running that setup almost exactly but with a catless dp etc and was making about 350awhp so about 400 crank and it was running like a champ
1992 miata, track beast here I come with 2 bride seats!! (current)
3076r speed6 owner (traded)
2000 camaro 415rwhp thru midwest chassis fab (sold)
ColonR is offline   Reply With Quote
The Following User Says Thank You to ColonR For This Useful Post:
drummerboy1864 (04-19-2012)
 Old 04-18-2012, 03:54 PM   #28
mituc's Avatar
Groans: 111
The idea was more like, why have only 2.5k rpm to play with when you can have 3k or more? On stock rods you're going to limit the boost at some point anyway, and both these turbo's can boost up to that point in the last 3rd (at least) of the rev range.
 Old 04-20-2012, 10:35 AM   #29
m4tic's Avatar
Oh you'll need my EWG manifold if you want to run boost that low on a 3076... Otherwise you'll creep to 24-25 psi.
2017 Daytona 392
2007 MS6 w/ Cheez
drummerboy1864 (04-22-2012)
 Old 04-20-2012, 11:10 AM   #30
http://www.mazdaspeedforum.org/forum/foru...al-way-111319/
TheBunk likes this.
 Old 04-20-2012, 01:32 PM   #31
Pu Manchu's Avatar
Groans: 546
...trade it for a 5.0?
94 M
MS6
IS350
Running Stock loudneighbor Gen2 MS3 General Discussion 40 04-17-2012 01:44 PM
Whats a stock hpfp with stock internals worth? mutiger93gt MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 01-15-2012 08:14 AM
Anyone running the HPFP internals? AtTheDriveIn Mazdaspeed3/6 General Discussion 7 03-02-2011 11:07 PM
Running TIP wth Stock Airbox? Silver Ecstasy 2010 MS3 - Turbo Induction 14 02-19-2011 09:35 AM
How many ppl running BT's with stock block? SpeedSixxx MazdaSpeed 3/6 - Turbo Induction 20 11-08-2009 12:30 PM
Page generated in 0.48151 seconds with 36 queries
